As part of its 'AW' launches, Nikon has announced the Nikkor 1 AW 10mm f/2.8 and 1 AW 11-27.5mm f/3.5-5.6 lenses. Both lenses are existing designs built into waterproof, shockproof housings and are only compatible with the Nikon 1 AW1 body. The 1 AW 10mm f/2.8 offers a 27mm equivalent field-of-view and will be sold separately for around $200/£300/€319. The Nikkor 1 AW 11-27.5mm zoom offers a rather limited 30-74mm equivalent range and will only be available as part of a kit with the camera - meaning there are no image-stabilized AW lenses yet.
Interestingly, Nikon says the AW 10mm is waterproof to a depth of 20m (65ft), which is deeper than the 1 AW1 body is rated to.
Jump to:
Press Release:
Nikon launches the world’s first waterproof/shockproof interchangeable lenses
I AM ADVENTURE-PROOF
RRP and sales start dates:
1 NIKKOR AW 10mm f/2.8: £299.99 / €359
1 NIKKOR AW 11-27.5mm f/3.5–5.6 is part of a kit only, please see combinations below:
Nikon  1 AW1 + 11-27.5mm f/3.5–5.6: £749.99 / €899
Nikon  1 AW1 + 11-27.5mm f/3.5–5.6 + 10mm f/2.8: £949.99 / €1149
Sales Start Date: 10th October 2013
London, UK , 19th September 2013 Nikon today announces the world’s first water/shockproof interchangeable lenses1 for dedicated use with the brand new water/shock/freeze-proof Nikon 1 AW1 system camera.
The 1 NIKKOR AW 11–27.5mm f/3.5–5.6 lens is an action-loving 2.5x zoom lens, whilst the 1 NIKKOR AW 10mm f/2.8 lens is a ready-for-anywhere fast wide-angle lens. Both lenses are waterproof to 15 m and 20 m respectively2, shockproof from heights of up to 2 m3, and freeze-proof for temperatures down to -10°C.4
Perfect for shooting epic adventures or everyday action, these two lenses combine with the Nikon 1 AW1 camera to give active people stunning images. Whether shooting in the city, or on an adventure weekend away, users will stand out from the crowd and capture photos and movies that are sure to impress.
Thuan Bui, Product Manager for Nikon 1 products at Nikon UK says: “If you have a strong sense of style and a taste for adventure, the new Nikon 1 AW system is perfect for capturing your lifestyle. It’s fast, portable, and flexible, and the water/shock/freeze-proof build of both the camera and the lenses has been achieved at no cost to image quality, so you can enjoy superior results, even when you shoot underwater.”
He continues, “Whether you use the wide-angle or the zoom, you’ll enjoy the freedom that comes with shooting underwater without using waterproof housing, and when you’re capturing the action on land, there’s no need to worry about accidently dropping your gear, either.”
1 NIKKOR concept
1 NIKKOR lenses capture life with exceptional sharpness. Designed with active lifestyles in mind, the growing range covers a wide variety of scenes, and each lens is optimised for movie recording. Combined with the portability, power, and speed of Nikon 1 cameras, the small size of the 1 NIKKOR lenses truly sets the Nikon 1 system apart.
1 NIKKOR AW 11–27.5mm f/3.5–5.6: Ready for anywhere
Come rain, shine, or murky underwater environments, this strong and stylish 2.5x zoom lens is an ideal lens for capturing a range of different scenarios. From casual snapshots to portraits and distant subjects, the 11–27.5mm zoom range (35mm equivalent: 30–74mm) covers most commonly used focal lengths, enabling great photos and movies to be captured at any moment. A wide zoom ring with knurled anti-slip surface facilitates smooth zooming, even when the photographer is wearing gloves. The tough build and luxurious metallic exterior of this lens complements the pristine looks of the Nikon 1 AW camera perfectly. As the standard kit lens for the Nikon 1 AW1 system, it comes in white, black, and silver to match the camera.
1 NIKKOR AW 10mm f/2.8: Fast wide-angle action
On land or underwater, the robust, stylish, and fast 1 NIKKOR AW 10mm f/2.8 wide-angle lens captures stunning wide-angle shots in any environment. Thanks to its large maximum aperture of f/2.8, it’s a great way to bring low-light action to life and single out subjects by capturing images with beautiful bokeh. This lens does a great job of capturing sweeping vistas from the top of mist-covered mountains, and the close focusing distance of 0.2 m makes it ideal for shooting close-ups in murky underwater environments. Available in black, this lens has a tough build and a luxurious metallic exterior that complement the pristine looks of the Nikon 1 AW camera perfectly.
Superior image quality
Both the new 1 NIKKOR AW lenses feature Nikon 1 optics optimised for sharp images across the entire frame. In order to ensure superior resolution and contrast, the zoom lens boasts an aspherical lens element and an ED glass element; the wide-angle lens incorporates two aspherical lens elements. In keeping with the wider range of 1 NIKKOR lenses, both of the new 1 NIKKOR AW lenses maintain the convenient portability of the Nikon 1 system, without sacrificing image quality.
Fully protected
Both lenses have an extra layer of glass in front of the lens in order to protect against water and dust, and the zoom lens also boasts rubber sealing around the zoom ring. An O-ring around the camera’s lens mount protects the camera’s sensor from water and dust. When shooting with the Nikon 1 AW1 camera and a regular 1 NIKKOR lens, the O-ring protector (supplied in the camera’s body cap) can be used to protect the camera’s lens mount.
The 1 NIKKOR lineup
The new 1 NIKKOR AW lenses are for dedicated use with the Nikon 1 AW1. All regular 1 NIKKOR lenses are compatible with the Nikon 1 AW1 as well as every other Nikon 1 camera in the range. For even more possibilities, you can use a NIKKOR lens in combination with the FT1 mount adapter.5
The current 1 NIKKOR lineup consists of 11 different lenses. The ultra-fast 1 NIKKOR 32mm f/1.2 medium-telephoto lens is the current flagship and makes a stunning portrait lens. It sits alongside a bright 18.5 mm lens with fast f/1.8 maximum aperture, a 10–100mm PD-ZOOM lens that’s made to make movies, and an ultra-wide 6.7–13mm zoom lens. Compact kit lenses are available in the same colours as the Nikon 1 camera bodies and cover a wide range of scenes: Like all 1 NIKKOR lenses, they provide the perfect balance of portability, power, speed, and quality, and are optimised for movie recording.
Accessories
Optional accessories for the 1 NIKKOR AW 10mm f/2.8 wide-angle lens include the HN-N103 screw-on Lens Hood (40.5 mm) and the CL-N101 Lens Soft Case.
Optional accessories for the 1 NIKKOR AW 11–27.5mm f/3.5–5.6 zoom lens include the HN-N103 screw-on Lens Hood (40.5 mm) and the CL-N101 Lens Soft Case.
FOOTNOTES
1 The new 1 NIKKKOR AW lenses are the world's first water/shockproof lenses among lenses for digital cameras with interchangeable lenses available (as of 9th August 2013); based on Nikon research
2 In-house tests have demonstrated JIS/IEC Class 8 (IPX8) waterproof performance; when attached to a waterproof camera.
3 Shockproof to resist a drop from a height of 2 m/6.6 ft (Has passed in-house tests to MIL-STD-810F Method 516.5: Shock standard; when attached to a waterproof camera)
4 When the lens is attached to the camera, in-house tests have demonstrated JIS/IEC Protection Class 8 (IPX8) waterproof performance to 15m (1 NIKKOR AW 11–27.5mm f/3.5–5.6) or 20 m (1 NIKKOR AW 10mm f/2.8) and shock resistance to MIL-STD-810F Method 516.5: Shock standard.
5 NIKKOR lenses mounted on the FT1 mount adapter have a 2.7x focal length crop factor, so you get a resulting angle of view that's over twice as long. For accurate information about compatibility with F-mount NIKKOR lenses, please refer to the manual.
Nikkor 1 AW 10mm f/2.8 & Nikkor 1 AW 11-27.5mm f/3.5-5.6 specifications
 Nikon 1 Nikkor AW 10mm f/2.8Nikon 1 Nikkor AW 11-27.5mm f/3.5-5.6
Principal specifications
Lens typePrime lensZoom lens
Max Format size1″
Focal length10 mm11–28 mm
Image stabilisationNo
Lens mountNikon 1
Aperture
Maximum apertureF2.8F3.5–5.6
Minimum apertureF11F16
Aperture ringNo
Number of diaphragm blades7
Aperture notesrounded blades
Optics
Elements68
Groups56
Special elements / coatings2 Aspherical elements1 aspherical element, 1 ED glass element
Focus
Minimum focus0.20 m (7.87)0.30 m (11.81)
Maximum magnification0.06×0.1×
AutofocusYes
Motor typeMicromotorStepper motor
Full time manualUnknown
Focus methodInternal
Distance scaleNo
DoF scaleNo
Physical
Weight118 g (0.26 lb)182 g (0.40 lb)
Diameter61 mm (2.4)63 mm (2.48)
Length30 mm (1.18)57 mm (2.22)
MaterialsMetal barrel, metal mount
SealingYes
ColourBlackBlack, silver, white
Zoom methodRotary (internal)
Power zoomNo
Zoom lockNo
Filter thread40.5 mm
Hood suppliedNo
Tripod collarNo
Optional accessoriesLens hood, screw-on NC filter, soft lens caseLens hood, screw-on NC filter, soft case
Other
NotesWaterproof to 20m, shockproof from 2m, freezeproof to -10C/+14FWaterproof to 15m, shockproof from 2m, freezeproof to -10C/+14F
Additional images
