Sony has announced the NEX_FS700 pro-grade 4k-capable E-mount camcorder. The camera will initially offer 1080p video, switchable between 50Hz and 60Hz frame rates (including 60p, 50p, 60i and 24p). A later upgrade will enable 4k capture and Raw output from its built-in 3G-SDI connector. The camera is also able to capture slow-motion footage, shooting at up to 960 fps at reduced resolution (240fps in Full HD). It also offers built-in 2- and 4-stop ND filters (which can be combined), to allow lenses to be used at wide apertures in bright light.
The camera is based around a 11.6MP 'Super-35mm' sensor. The Super 35mm format is 13.3mm x 23.6mm - essentially the same as a 16:9 crop taken from an APS-C sensor. EOS HD is reporting a price of around $8k.
Jump to:
Press Release:
Sony expands NXCAM line up with new Full-HD super slow motion camcorder
PARK RIDGE, N.J., April 2nd, 2012 – Sony is pushing the creative boundaries once more with the new NEX-FS700 Full-HD Super Slow Motion camcorder, the latest in Sony’s line-up of NXCAM interchangeable E-mount camcorders. The new Super 35mm model is designed for high-speed shooting and is capable of capturing footage at up to 960 frames per second. The camcorder also features a range of capabilities such as 3G HD-SDI output and built-in ND filters. Additionally, it also offers several creative options, shooting styles and enhanced ergonomics – all based on customer feedback – to deliver a flexible production tool that fits seamlessly into a variety of shooting applications.
“The NEX-FS700 opens the door to a new world of creative shooting,” said Bill Drummond, Strategic Marketing Manager, Sony Europe. “You can record beautiful high speed Full-HD movies with the freedom of choosing interchangeable lenses. The NEX-FS700, with its super slow motion mode, is ideal for pop promos, commercials and documentaries as well as sports and a variety of events productions.”
The camcorder delivers Full-HD quality images at 120 and 240 frames per second in an 8 or 16 seconds burst mode respectively. The NEX-FS700’s high sensitivity and low noise shooting capability makes super slow motion shooting more convenient without additional equipment. 480 fps and 960 fps rates at reduced resolution are available for faster frame rate recording.
The NEX-FS700 camcorder uses a new 4K “Exmor” Super 35 CMOS sensor (total 11.6 million pixels). This high-speed readout chip is optimised for motion picture shooting, giving high sensitivity, low noise and minimal aliasing.
The NXCAM’s E-Mount flexibility is designed to accept virtually all SLR and DSLR 35mm lenses, with the use of simple, inexpensive adapters without optical degradation. FS series owners can make use of their existing lenses and add more lenses without being forced on a brand or mount.
Users can capture high-quality still images with the NEX-FS700. The camcorder also includes face detection and auto focus to help ensure the subject is always kept in focus.
NEX-FS700 operators can take advantage of the camcorder’s built-in ND filters, with a newly designed wheel that rotates across the sensor like a turret. The wheel includes positions for Clear, 1/4 (2 Stop), 1/16 (4 Stop), and 1/64 (6 Stop).
The camcorder is 60/50Hz switchable to give people the freedom of working in any geographic region without being restricted to only PAL or NTSC recording.
The NEX-FS700’s 3GHD-SDI and HDMI connectors can output Full-HD 50p and 60p, in addition to standard HD 60i, 24p, 25p or 30p frame rates with embedded time code and audio. 3G HD-SDI can output native 23.98, 25, 29.97 progressive signals; users can choose to output PsF over the 3G HD-SDI. Thanks to flexibility of the digital ports virtually any external recorder can be connected.
Users can save up to 99 camcorder profile settings on a memory card and can copy the same setting to multiple units. Compatible media includes MS and SD memory cards and Sony’s HXR-FMU128 flash memory unit that attaches to the camcorder.
The NEX-FS700 features include a robust detachable top handle, secured by a pair of screws (a cold shoe, plus two sets of 1/4 and 3/8 inch holes) that allow heavy accessories to be mounted. The handle is attached with a rosette mount.
A key element of the handle is an “active grip” that features four buttons for commonly used functions – expanded focus, auto iris, still capture and Recording Start/Stop – so users can easily operate the camcorder while holding it. Function buttons are also enlarged to make operating easy, even while wearing gloves.
The camcorder’s enhanced durable design also includes anchor points for compatibility with third party accessories.
Sony is planning a future firmware upgrade that will enable the NEX-FS700 to output 4K bit-stream data over 3G HD-SDI when used with an optional Sony 4K recorder.
The NEX-FS700 is planned to be available in June 2012.
Additional images
