Cosina has announced a slightly revised version of its ultra-fast normal prime for Micro Four Thirds cameras. The Voigtländer Nokton 25mm F0.95 Type II gains an aperture ring mechanism that is switchable between clicked and clickless operation, a desirable feature for movie makers (and previously seen in its 17.5mm F0.95 and 42.5mm F0.95 stablemates). The optics are unchanged, but the updated lens is slightly heavier and larger in diameter. It will be available in March.
Voigtländer Nokton 25mm F0.95 Type II specifications
Principal specifications
Lens typePrime lens
Max Format sizeFourThirds
Focal length25 mm
Image stabilisationNo
Lens mountMicro Four Thirds
Aperture
Maximum apertureF0.95
Minimum apertureF16.0
Aperture ringYes
Number of diaphragm blades10
Aperture notesSwitchable stepped / stepless aperture control
Optics
Elements11
Groups8
Focus
Minimum focus0.17 m (6.69)
AutofocusNo
Full time manualYes
Distance scaleYes
DoF scaleYes
Physical
Weight435 g (0.96 lb)
Diameter61 mm (2.39)
Length70 mm (2.76)
Materialsmetal barrel, metal mount
SealingNo
Colourblack
Filter thread52.0 mm
Tripod collarNo
Other
NotesManual focus only
