Sigma has announced a new telephoto lens to add to its DG range with the 135 - 400mm F4.5-5.6 optic. The multi-layered-coated lens, designed to reduce flare and ghosting, has SLD (Special Low Dispersion) glass elements that provide correction for all types of aberration throughout the entire zoom range. Its rear focus system ensures high performance stability and ease of use. The price will be £479.99.
Press Release:
135-400mm F4.5-5.6 DG
Sigma 135-400mm F4.5-5.6 DG lens
Compact ultra-telephoto zoom lens, optimized for digital SLR cameras.
  • The new multi layer lens coating and lens design reduce flare and ghosting.
  • An aspherical lens and SLD glass elements provide correction for all types of aberration throughout the entire zoom range.
  • The rear focus system ensures fast AF speed.
Sigma Corporation is pleased to announce the launch of the new 135-400mm F4.5-5.6 DG lens. This compact ultra-telephoto zoom lens is optimised for digital SLR cameras. The new multi layer lens coating and lens design reduce flare and ghost, and also creates an optimum color balance and better picture quality through the entire zoom range. This lens uses one aspherical lens and three SLD (Special Low Dispersion) glasses for excellent correction of various chromatic aberrations. It provides excellent image quality for digital and film SLR cameras. Rear focus system ensures high performance stability and ease of use. Since the front of the lens does not rotate during focusing, a circular polarizing filter can be easily attached and use. A removable tripod collar is included as a standard component
SPECIFICATIONS:
Focal Length: 135-400mm F4.5-5.6DG
Minimum Aperture: F32
Lens Construction: 13 Elements in 11 Groups
Angle of View: 18.2°- 6.2°
Number of Diaphragm Blades: 9pcs
Minimum Focusing Distance: 200-220cm (78.7-86.6”)
Maximum Magnification: 1:5.3
Filter Size: 77mm
Lens Hood: Bayonet Type Hood
Dimensions: Diameter 88.5mm (3.5”) x Length 183.6mm (7.2”)
Weight: 1245gr/43.9oz
• The appearance and specifications are subject to change without notice.
