Sony has announced the Alpha 7 II, which the company has managed to keep very close to its vest. The big story on this 24MP full-frame mirrorless is its 5-axis sensor-shift image stabilization - the first of its kind in a full-frame mirrorless camera. Sony claims that this IS system can reduce shake by 4.5 stops using the CIPA standard. If an E-mount lens with OSS is attached, the camera will detect it and use a combination of in-lens and in-body stabilization.
Like the original a7, the a7 II features 117 phase detect and 25 contrast detect points on its CMOS sensor but Sony is claiming a 30% improvement in the a7 II's AF speed and 1.5x better tracking performance than its predecessor. Sony says this is thanks to its 'proprietary image analysis technology' using more information from a scene to keep focus locked on a subject.
On the video front, the Alpha 7 II now supports the XAVC S codec, which can record 1080/60p video at 50Mbps. The camera also supports S-Log2 to capture a wide dynamic range in video for grading.
From a design standpoint, the biggest changes are the grip - which is larger - and the relocation of the front command dial to a position on the forward edge of the grip. The shutter release button has been moved to a more natural position on the grip and the front panel is now magnesium alloy instead of plastic. The lens mount has also been reinforced, for more stability when using heavy lenses.
The a7 II is expected to ship in Japan on December 5th. No word yet on availability in other regions.
Sony Alpha 7 II Specifications
Body type
Body typeSLR-style mirrorless
Body materialMagnesium alloy
Sensor
Max resolution6000 x 4000
Other resolutions6000 x 3376, 3936 x 2624, 3936 x 2216, 3008 x 1688, 3008 x 2000
Image ratio w:h3:2, 16:9
Effective pixels24 megapixels
Sensor photo detectors25 megapixels
Sensor sizeFull frame (35.8 x 23.9 mm)
Sensor typeCMOS
ProcessorBionz X
Color spacesRGB, AdobeRGB
Color filter arrayPrimary color filter
ISO100-25600
Boosted ISO (minimum)50
White balance presets10
Custom white balanceYes
Image stabilizationSensor-shift
Image stabilization notes4.5 stops
Uncompressed formatRAW
JPEG quality levelsExtra fine, fine, standard
File format
  • JPEG (DCF 2.0, EXIF 2.3)
  • RAW (ARW 2.3)
Image parameters
  • Standard, Vivid, Neutral, Clear, Deep, Light, Portrait, Landscape, Sunset, Night Scene, Autumn Leaves, Black & White, Sepia
Optics & Focus
Autofocus
  • Contrast Detect (sensor)
  • Phase Detect
  • Multi-area
  • Center
  • Selective single-point
  • Single
  • Continuous
  • Face Detection
  • Live View
Autofocus assist lampYes
Digital zoomYes (4)
Manual focusYes
Number of focus points117
Lens mountSony E (NEX)
Focal length multiplier1×
Screen / viewfinder
Articulated LCDTilting
Screen size3
Screen dots1,230,000
Touch screenNo
Screen typeXtra Fine LCD
Live viewYes
Viewfinder typeElectronic
Viewfinder coverage100%
Viewfinder magnification0.71×
Viewfinder resolution2,359,000
Photography features
Minimum shutter speed30 sec
Maximum shutter speed1/8000 sec
Exposure modes
  • Auto
  • Program
  • Aperture priority
  • Shutter priority
  • Manual
  • Scene Selection
  • Sweep Panorama
  • Movie
Scene modes
  • Portrait, Landscape, Macro, Sports Action, Sunset, Night Portrait, Night Scene, Hand-held Twilight, Anti Motion Blur
Built-in flashNo
External flashYes (via Multi Interface shoe)
Flash X sync speed1/250 sec
Drive modes
  • Single, continuous, speed priority continuous, self-timer, bracketing (AE, white balance, DRO)
Continuous drive5.0 fps
Self-timerYes (2 or 10 sec; continuous (3 or 5 exposures))
Metering modes
  • Multi
  • Center-weighted
  • Spot
Exposure compensation±5 (at 1/3 EV, 1/2 EV steps)
AE Bracketing±5 (3, 5 frames at 1/3 EV, 1/2 EV, 2/3 EV, 1 EV, 2 EV steps)
WB BracketingYes
Videography features
Resolutions1920 x 1080 (60p, 60i, 24p), 1440 x 1080 (30p), 640 x 480 (30p)
FormatMPEG-4, AVCHD, XAVC S
Videography notesSupports XAVC S codec (50Mbps) and S Log2 flat picture profile
MicrophoneStereo
SpeakerMono
Storage
Storage typesSD/SDHC/SDXC, Memory Stick Duo/Pro Duo/Pro-HG Duo
Connectivity
USB USB 2.0 (480 Mbit/sec)
HDMIYes (micro-HDMI port with 4K still, uncompressed video output)
Microphone portYes
Headphone portYes
WirelessBuilt-In
Wireless noteswith NFC and wireless control via PlayMemories Mobile app
Remote controlYes (wired)
Physical
Environmentally sealedYes
BatteryBattery Pack
Battery descriptionNP-FW50 lithium-ion battery and charger
Battery Life (CIPA)350
Weight (inc. batteries)599 g (1.32 lb / 21.13 oz)
Dimensions127 x 96 x 60 mm (5 x 3.78 x 2.36)
Other features
Orientation sensorYes
Timelapse recordingNo
GPSNone
