Think Tank Photo has announced the Sub Urban Disguise series of camera shoulder bags, to be available in February. These bags feature flip-top lids that open away from your body, front organizer pockets, stretchable side pockets and will be available in four sizes. The company has also announced an updated version of its Change-Up multi-function camera bag scheduled to be available around the same time. Prices and availability information to be confirmed.
Press Release:
Sub Urban™ Disguise Premium Quality Shoulder Camera Bags to Be Released
In February, we will release a new concept in premium quality camera shoulder bags, the Sub Urban Disguise™.  The Sub Urban Disguises are designed for the professional photographer seeking smaller capacity camera bags and amateur photographers upgrading their bodies or using one to two lenses along with their new body.
The Suburban Disguise series will be available in four sizes:  the Sub Urban Disguise™ 5, Sub Urban Disguise™ 10, Sub Urban Disguise™20, and Sub Urban Disguise™30.  Their features include a flip-top lid that folds away from the body to provide quick and unencumbered access to gear. The series meets the high-quality design standards of the original Think Tank Urban Disguise® series, but for smaller gear or photographers who want to travel light.
Gear Profiles
  • Sub Urban Disguise™ 5 holds a regular size DSLRs with one to two small telephotos or primes, or a D700 with a 18-200 attached.  It also accommodates Micro 4/3rds, Leica and Sony NEX systems. Great for Strobists as it fits two to three pro-size flashes.
  • Sub Urban Disguise™ 10 holds a regular size DSLRs with two to three small telephotos or primes, or a D700 with a 18-200 at­tached.  It also fits three pro-size flashes.
  • Sub Urban Disguise™20 holds regular size DSLRs with three to four small telephotos or primes or a D700 with a 18-200 at­tached.  It fits four to five pro-size flashes.
  • Sub Urban Disguise™30 fits a regular size DSLR and two to four standard telephoto lenses, or a D700 with a 24-70 2.8 attached.  It can also hold an iPad or similarly-sized tablet.
Key features include:
  • Flip top lid opens away from your body, providing easy access to gear
  • Cleanly styled design, does not look like a traditional camera bag
  • Highest quality materials
  • Designed to easily fit DSLR equipment
  • Large padded front pocket
  • Easily accessible front organizer pocket
  • Stretchable side pockets fit a water bottle
  • Padded zippered pocket to accommodate an iPad or similarly-sized tablet (Suburban 30 only)
  • Padded non-slip flexible shoulder strap
  • Poly-ballistic fabric ensures durability
  • High quality YKK zippers
  • Seam-sealed rain cover included in front pocket
  • Business card slot
Materials:
Sub Urban Disguises’ all fabric exterior is treated with a Durable Water Resistant coating while the fabric underside is coated with Polyurethane for superior water resistance.  It also uses YKK® RC Fuse zippers, 1680D ballistic polyester, 600D brushed polyester, 420D high-density nylon, Ultra-stretch pockets, antique nickel plated metal hardware, 3-ply bonded nylon thread.  The interior features removable closed cell foam dividers, 200D polyester, PU backed velex liner, 2x PU coated nylon 210T seam-sealed taffeta rain cover, 3-ply bonded nylon thread.
Specifications:
  • Internal Dimensions: 6.6” x 7.4” x 5” (16.8 x 18.8 x 12.7 cm) (W x H x D)
  • External Dimensions: 8” x 8.5” x 6.4” (20.3 x 21.6 x 16.3 cm) (W x H x D)
  • Maximum weight (with all accessories): 1.1lbs (0.5kg); Minimum weight: 1.0lb (0.4kg)
  • Internal Dimensions: 8.8” x 7.4” x 5” (22.4 x 18.8 x 12.7 cm) (W x H x D)
  • External Dimensions: 10.5” x 8.5” x 7” (26.7 x 21.6 x 17.8 cm) (W x H x D)
  • Maximum weight (with all accessories): 1.4lb (0.6kg); Minimum weight: 1.2lb (0.5kg)
  • Internal Dimensions: 11” x 7.4” x 5” (27.9 x 18.8 x 12.7 cm) (W x H x D)
  • External Dimensions: 12” x 8.5” x 7” (30.5 x 21.6 x 17.8 cm) (W x H x D)
  • Maximum weight (with all accessories): 1.6lbs (0.7kg); Minimum weight: 1.3lb (0.6kg)
  • Internal Dimensions: 11” x 9.5” x 5” (27.9 x 22.9 x 12.7 cm) (W x H x D)
  • External Dimensions: 11.5” x 10” x 7.3” (29.2 x 25.4 x 18.5 cm) (W x H x D)
  • iPad pocket: 10.7” x 8.5” x .8” (27.2 x 21.6 x 2 cm) (W x H x D)
  • Maximum weight (with all accessories): 1.5lb (1.0kg) ; Minimum weight: 2.3lb (0.7kg)
