Nikon has released Capture NX version 2.4.6. The latest update adds Raw image support for the recently announced entry-level D3300 and the improved white balance adjustment options can now match the 'Auto 1' setting found in newer DSLR and Coolpix cameras. Version 2.4.6 also expands Fine Adjustment range from 4132–7042k to 2500–7042k when using the Direct Sunlight option for Daylight.
Capture NX 2.4.6 modifications include:
  • Support for RAW images captured with the D3300 has been added.
  • Advanced settings, such as Sharpening, under Camera Settings > Picture Control in the Develop section of the Edit List palette can now be adjusted, even when Unchanged is selected for Picture Control when RAW images are opened.
  • The following modifications and additions have been applied to White Balance > New WB in the Camera Settings portion of the Develop section in the Edit List palette.
  • An Auto 1 option has been added to White Balance > New WB options. Capture NX 2 adjusts white balance for colors similar to those achieved in images captured with a camera's Auto 1 (Normal) * white balance setting.
    • However, only RAW images captured with the following cameras are supported.
    • The D7000 and later digital SLR cameras.
    • Advanced cameras with interchangeable lenses.
    • The COOLPIX A as well as the COOLPIX P7100 and later COOLPIX cameras that support recording in the NRW format. *Auto white balance setting with cameras that do not offer an Auto 2 (Keep warm lighting colors) option.
    • Adjustment units available with the Tint option have been changed from 1 to 0.01 for more precise specification.
    • The adjustment range for Fine Adjustment when Direct sunlight is selected for Daylight has been expanded from 4132–7042k to 2500–7042k.
    • Adjustment using Fine Adjustment and Tint is now possible when Recorded Value, Auto 1, Auto 2, or Underwater is selected.
Windows version only
  • An error occurred when XMP/IPTC files created with Capture NX 2.4.3 or earlier were opened:
  • Details specified in the Print layout dialog and page setup dialog displayed with selection of Page Setup... in the File menu were not applied.
Macintosh version only
  • When image files saved to a disk formatted using the FAT32 architecture were edited and saved, editing details were not applied.
  • Support for Mac OS X version 10.6 has been eliminated.
Get the update:
