Canon EOS-1D X overview
By R Butler | Published Oct 18, 2011 |
The Canon EOS-1D X is the latest in the company's professional range of DSLRs. Its job is to replace both the sports-orientated 1D series and the high-resolution, studio-focused 1DS range of cameras. As is usual for upgrades in this class of camera, the changes are incremental and subtle but aim to raise the bar of what is possible.
The biggest specification change to the 1D X is its new sensor - an 18MP full-frame CMOS chip capable of shooting at 12 frames per second. This represents a big change over the 1D Mk IV (it represents a move away from the smaller APS-H format that Canon has previously used in its sports cameras), and a decrease in pixel count compared to the 1DS series. However, as Rick Berk, Technical Specialist in Canon USA's Pro Engineering and Solutions Division says: 'there's more to image quality than just resolution.'
The move from APS-H up to full-frame is enabled by a sensor with faster data readout explains Chuck Westfall, Technical Advisor in Canon USA's Pro Engineering and Solutions Division: 'The new sensor has 16-channel, dual line readout, compared to 8-channel, single line designs in the previous generation of chips.' This lets the company offer a large sensor (and the low-light capability that brings) for 1DS users, with the fast capture speeds that current 1D Mk IV users need. 'It's clear the time has come for the 1DX to replace the whole 1D series,' says Westfall.
Under the skin, the big change is the more sophisticated metering sensor. A move from the 1D Mk IV's sensor to a new 100,000 pixel unit affords the camera a much better understanding of the scene and this information is fed into the camera's autofocus system to improve the quality of its AF tracking. This isn't a new idea (Nikon's sports cameras have done something similar for several generations), but it's a sensible way of improving what's already an impressive system.
Autofocus changes
The other big change to autofocus is simpler configuration. The 1D X does away with the complex inter-related network of custom settings that defined AF behavior in previous models, instead offering six presets for different shooting situations (see table below). Each of these can be adjusted for 'Tracking sensitivity' (which defines how doggedly the camera attempts to stick with the originally chosen target or whether it will re-focus on nearer subjects if they cross in front of the target), 'Acceleration/Deceleration tracking' and AF point auto selection (how readily the camera should move off the selected AF point).
Westfall acknowledges the complexity of the previous systems could prevent users getting the most out of previous cameras: 'A common response to the 1D III and 1D IV was that people loved the idea of a high spec AF system but they wanted an easier way of get the most out of it. The improvements from the 1D III to the 1D IV were substantial but also incremental - to make a bigger step forward this time we needed to start from scratch.'
Canon EOS-1D X AF mode presets, defined by subject behavior:
1. Versatile multi purpose 4. Subjects that accelerate or decelerate quickly
2. Continue shooting, ignore obstructions 5. Erratic Subject Movement
3. Instantly refocus suddenly with obstructions 6. Subjects that change speed and move erratically
In addition to making the system more accessible, the 1D X has the first entirely new AF arrangement since the launch of the (film-era) EOS 3 in 1998. The new 61-point AF sensor has 21 cross type AF points at the center, which are sensitive enough to be used with lenses with maximum apertures as slow as F5.6. The central five of those points also have diagonal AF elements that are active with F2.8-and-faster lenses. All other AF points are sensitive to horizontal detail with lenses faster than F5.6, while 20 of these (in two flanks towards the outer edges of the sensor), act as cross-type points with F4 maximum aperture lenses or faster.
As with the EOS 7D, the AF point selection can be narrowed-down to a series of sub-sets of local AF points. It's also possible to adjust what factors are considered during AF tracking: AF info only, AF and color information or AF and face detection information.
Getting a sense for the sensor
When asked to for the biggest improvement in the new camera, Westfall stresses that every aspect of the camera has been re-assessed but finally concludes: 'If you had to highlight just one thing, I'd say the sensor. It's a new level for us in terms of image quality.'
'There's a couple of things that we consider when we think about IQ: number one on this sensor is noise. It's clear the noise level is better than in the 1D Mk IV or the 1DS III. The pixel size is larger than in the 1DS III or 5D Mark II (6.95 microns, versus 6.4) and the difference is even more striking compared to the 5.7 micron pixels in the 1D Mark IV. That helps us in terms of light capturing ability and increases the signal to noise ratio. In turn, that does nothing but help the dynamic range of the camera.'
And its this improvement in image quality that Westfall believes will make the 1D X appeal to 1DS as well as 1D users. 'I think the factor that's going to make that a reality is the noise level is better than anything we've seen before. With cleaner images, people are going to feel much more comfortable up-rezing an image. Not many people need a 21MP file to begin with, so they're going to love the IQ of this camera and the quality's good enough that those people who do need those huge files will find the images clean enough to use them.'
Changes to the body
The body of the 1D X closely resembles previous 1D cameras, but close examination reveals a series of changes. The most significant is perhaps the addition of a second joystick on the rear of the camera, to ensure all functions remain available when using the portrait orientation grip. The camera also features twin buttons next to the lens, in either orientation. These are customizable, allowing you to access features such as the electronic level gauge or jump to registered AF point.
Beyond this, the camera gains a direct live view button, a 'Q' button to jump to the 'Quick' function menu, and has had its flash exposure lock button re-dedicated as a customizable function button.
Processing power
As you'd expect, the camera's processing has received a considerable refresh, Westfall explains: 'You've got dual Digic 5+ processors, which our engineers are telling us are 17x faster than the Digic 4s used in the existing models.' In addition, the metering sensor, given its added complexity and the need to interpret its output to feed into the AF system, gets its own Digic 4 processor.
This processing power allows the camera to conduct a wider range of lens corrections. In addition to the vignetting correction that could be conducted by the 1D Mark IV, lens profiles can be uploaded using EOS utility and the camera will correct for geometric distortion and chromatic aberration (both lateral and axial) in real-time. These corrections are all optional and can be engaged separately.
Another benefit of more processing power, combined with an improved sensor is an expansion of ISO range, says Westfall: 'The ISO range on this camera, just the standard range, goes from 12,800 on the 1D Mark IV and 1600 on the 1DS Mark III, up to 51,200. And this can be expanded up to 204,800 - that's going to be an enabler of all sorts of new possibilities for a lot of people.'
The final processing option is the ability to shoot multiple exposure images. Four combination methods are available, which can be used to create composite images either from consecutive shots or from an existing Raw file and an additional exposure.
All about speed
The faster sensor and greater processing power are combined with a new carbon fibre shutter and revised mirror mechanism to allow 12 frame per second continuous shooting. The camera can shoot at 14fps if you're happy to lock the mirror up (and hence lock focus), and capture only JPEG images. The shutter has a rated lifespan of 400,000 cycles (a 30% improvement on before, despite the additional demands of the faster continuous shooting). The company also says it should be more accurate at high shutter speeds. It also offers an X-sync speed up to 1/250th of a second.
At first, the move from 10 to 12 frames per second doesn't sound terribly impressive - until you remember that the camera is now based around a larger sensor, so there's a much bigger mirror to move. Westfall is keen to stress this: 'The high-speed rate is greatly improved. Our full-frame cameras up until now have only been able to offer up to five frames per second, whereas this can shoot at 12fps, or 14 if you're willing to shoot JPEG. The 1D X means you can have full-frame quality and high speed.'
The EOS-1D X gains twin customizable buttons next to its lens mount - one set for each orientation
In the frame to be flagship
Of course it's no longer enough for a camera at this level to just be able to shoot stills, and the EOS-1D X is Canon's most capable movie shooter yet. Although the headline spec (1080p at 30, 25 or 24 frames per second), isn't exactly groundbreaking, it's clear that Canon has had movie shooters in mind.
The 1D X offers two compression options, including 'All-I,' a very low compression format that offers high image quality and editability but at the cost of immense files (a 16Gb card will hold around 6 minutes of footage). The alternative is a more standard IPB compression that takes up around 1/12th of the space. To prevent these large files limiting the camera, the 1D X is the first Canon to be able to split a single piece of footage into multiple files, overcoming the 4Gb limit of the card file system, and allowing videos of up to 29 minutes, 59 seconds to be recorded.
In addition the camera can keep track of how long it has been recording, using standard timecoding methods. There's also greater-than-ever control over the microphone input volume, with 64 manually selectable levels, auto and a wind-cut filter. It's also possible to mute sound recording while shooting.
Westfall believes the 1D X has the features that pro shooters will want: 'I think people are looking for a balance between cost and performance - the cameras offering 60P at the kind of bit rates that we can offer tend to be in a higher price bracket. And we can offer 720p at 60 frames per second,' he says.
'People we're dealing with are tending towards using 24 - to match the filmic look. There are cameras offering 60P in the consumer market but they haven't got the bit rate we're offereing. Many of them are limited to less than 30mbps while we're bumping up against 50. This is a clear difference - we think this product keeps moving the ball forward. With this product the focus was improving the compression. The other thing people were requesting was the ability to shoot longer clips and on this model we can shoot for up to nearly 30 minutes.'
'Within this range of products we offer, this is going to assume the flagship postition,' he says: 'It will be the most desirable product for people wanting movie shooting in a DSLR.'
Any other business
Beyond the big changes is a move to twin CF cards. As before these can either be set to duplicate images onto both cards or overflow from one to the next. You don't have the option of separately storing movies and stills, however. The upgrades to the camera also extend to a revised dust-reduction system for the sensor. The wave-motion of the shake system is being called 2nd generation dust prevention by Canon.
Another change to the 1D X's storage is the addition of an Ethernet 1000 Base-T network port. This allows faster transfer speeds and the use of longer cables (the limit is 100m, rather than around 3.5m for USB).
The final significant change is another gain from the EOS 7D - an electronic overlay on the viewfinder, allowing AF points and the level gauge to be shown in the viewfinder. Other than that, the camera retains essentially the same viewfinder specs as the 1DS Mark III - a huge 0.76x, 100% coverage pentaprism that 1DS users will be familiar with and 1D series owners will really appreciate after years of using cropped APS-H finders.
43
Flag as inappropriate
Share:
Print view
Comments
Total comments: 289
12
kshitijnagar
By kshitijnagar (Feb 16, 2012 at 16:30:26 GMT)
What we all need is this!
http://www.youtube.com/watch?v=JstJAxtubEA
0 upvotes
snake_b
By snake_b (Feb 16, 2012 at 13:59:34 GMT)
Where;s the review?
0 upvotes
metallaro1980
By metallaro1980 (Feb 7, 2012 at 21:56:19 GMT)
fortunately, i use Carl Zeiss/Leitz lenses more than Canon lenses on my eos 5d2
i have ony the Canon 100/2.
I don't have 135L but in general I don't like this focal.
for me my APO-Telyt-R 180/3.4 is definitely better than all other Canon lenses (for example: all 70-200 and 200/2.8)
and about my Planar 1.4/50 Contax...this is a lens in all effects !!!
in photography are more importants the colours and sharpness instead of flash AF of this 1dx..but some Canon lenses have mummy colours.....
it is simply: a ferrari (1dx) with cheap pneumatic (canon lenses)
the 135L and 200 f/2 maybe are very good...but with wide-angle, Canon is behind Zeiss/Leica...the elmarit-r 28mm rom or Distagon 28mm...the elmarit-r 19mm rom..or Distagon 1.4/35mm or the new Distagon 21mm ... you will live in another world !!!
Comment edited 2 times, last edit 9 minutes after posting
0 upvotes
yabokkie
By yabokkie (Feb 10, 2012 at 14:17:32 GMT)
Zeiss/Leica were kicked out of the business 40 years ago. why should anyone get a German when you can have Japanese?
0 upvotes
dark goob
By dark goob (Feb 13, 2012 at 07:59:08 GMT)
I got both: Leica Summilux-D 25mm f/1.4 on Olympus E-5. Stabilized.
I do live in another world.
0 upvotes
Calgary Guy
By Calgary Guy (Feb 4, 2012 at 04:07:44 GMT)
"Tell the Truth": Are you so much of a looser to utter such nonsense?
Facts are that both these manufacturers sell prime equipment . We all reap the fruit from this fierce competition between these giant companies. Both these companies keep each other on their toes and that is good. You gain in one aspect and loose in another aspect.
What made the Nikon D700 better for some? For sure the focus points.
What made the Canon 5DMrk2 better for others? For sure the mega pixels.
So what makes the Canon 1Dx the likely winner over the Nikon D4?
It wins in three aspects: Megapixels, number of focus points and the higher shutter speed. The penalty is $800.00 which is tough.
So for you Mr "Tell the Truth" that sold your Canon lenses for Nikon lenses...: Go buy yourself a D4. You will have an excellent camera most people will envy..., except for the Canon 1Dx owners because they will know they bought the winner in this supreme category!
And for the record: I ordered my 1Dx today. Deposit paid.
1 upvote
Maloy
By Maloy (Feb 8, 2012 at 20:47:54 GMT)
Guys, you're arguing about nothing. To each his own. Why rant about something not satisfying your needs, if you can afford to simply throw away a camera and lenses worth several thousand dollars.
And why prove that A is better than B if A and B are there to compete.
Personally, I don't understand how someone can be a "fan of the brand". I only buy what's GOOD, not what has a certain logo on its front. And my limited experience with cameras shows that there is always a huge market for both selling and buying second hand cameras and lenses.
Actually, I don't really understand how someone can pay the deposit on something that nobody really held in their hands yet, but, again, to each his own.
So what this fuss is all about, really? Peace!
0 upvotes
Johnk781
By Johnk781 (Feb 11, 2012 at 00:39:55 GMT)
Where did you order it? I noticed today that it has been pulled from B&H and Adorama websites.
0 upvotes
tell the truth
By tell the truth (Jan 31, 2012 at 07:32:30 GMT)
canon you should be Ashamed ! You state you start from scratch on a new auto focus system!! The Truth is your last bodies #3 and#4 were beta bodies we tested for you in the field at our thousands of dollars expense , and we proved to you how poor they were. Now you say this will shoot at 12 frames a second and auto focus the hole time ,while Nikon says you can not focus past 10 frames a second! Now who am I to believe Nikon who I switched to, the best camera I have ever used ,,or should I believe you , the makers of my best door stop camera I have ever had.The #4 body also was way off on exposure, to such a point you could not give me one! It really is sad,, I was a super loyal canon guy with tons of canon glass. You forced me away from your products, with SIR IT IS UP TO SPEC ! I really should thank you . The NIKON is at least 5 years ahead of your canon! So count me out on this DOOR STOP DREAM MACHINE ! The best news I have heard so far is canon 's president just stepped down!
0 upvotes
KGC2
By KGC2 (Feb 12, 2012 at 19:06:40 GMT)
Wow. Bitter much?
0 upvotes
munro harrap
By munro harrap (Jan 15, 2012 at 15:46:01 GMT)
the 24-70 and 24-105 and the 17-40 are not good enough and badly need redesign. Primes and longer zooms are OK, but for PJ work, and weddings etc these lenses need to be first class. Nobody would buy adaptors and fit other lenses losing autofocus otherwise, and it is this problem that makes me hesitate, and no other-if the dodgy AF my MkII really has been cured and the colours have accuracy at last.
You might have had the luck to get good ones, but more recently demand has affected quality-it is no secret, and this and the innacurate colour is still a big problem when you contemplate paying out as much as a small car now costs (with a 5 year warranty) for a 1DX you can confidently use with one of these zooms. And it is only guaranateed for a year AND costs much more in the UK than in the USA (still)
0 upvotes
Teila Day
By Teila Day (Jan 15, 2012 at 22:07:43 GMT)
Few people looking at the end product give a hoot about *ultra* image quality when looking at PJ photographs as much as they are simply getting a nice (not fine art gallery quality) visual presentation of something newsworthy.
The 24-70 and 24-105 are EASILY quality enough lenses to mount to this new 18mp camera. Here in the U.S., small cars (even ones that people are not eager to own) cost a good bit more than a new 1Dx.
People (such as myself) buy adapters because many times it's financially better to put a pro lens from Nikon that you already own on the Canon, instead of buying the Canon version. Also, does Canon have a 14-24 f/2.8 zoom lens of excellent quality? No, but Nikon does and those are two major examples that have nothing to do with the quality of Canon's lenses.
Perhaps you need to get your equipment calibrated whether by Canon or by doing a micro adjust yourself.
0 upvotes
KAllen
By KAllen (Feb 9, 2012 at 08:54:32 GMT)
I would like to think Canon learned a good lesson from the previous D/Ds range. A lesson at our expense. On paper this looks a very good camera, then again so did my DsmkIII. I'm tempted to run a Nikon system alongside my Canon to see which I like the most.
Canon need more than words to win me over.
If we are to believe the PR, then the 5D replacement will also have less pixels than now. So if the 8000 at 36mp is very good, Canon will not have much to sell anyone.
I agree with the "Up to spec" retort.
What would make me angry is the response to focus issues was always "we've never heard of a problem" When I could name a list of colleagues who had exactly the same complaint.
0 upvotes
Majikthize
By Majikthize (Feb 17, 2012 at 13:54:41 GMT)
I shoot landscapes and events with my 17-40 on a 1Ds MKII and am very happy with IQ. Slightly soft toward the corners on FF, but really remarkably good for a superwide zoom. In terms of sharpness and contrast, it's close behind the 35mm f2 and well ahead of the 28-135. It has a bit of distortion that's easily corrected in post-production. If you want better performance than this, you have to go prime. Now, if Canon would just step up it's game with its wide primes...
0 upvotes
pedrofp
By pedrofp (Jan 12, 2012 at 14:45:12 GMT)
p
Comment edited 43 seconds after posting
0 upvotes
astonsa
By astonsa (Jan 6, 2012 at 18:57:36 GMT)
didn't see usb specs is it usb 3.0 or usb 2.0?
is there a wifi option?
0 upvotes
john
By john (Dec 29, 2011 at 03:13:46 GMT)
I just a little worry about their lens, all their lens even the 'L' ones have some kind of plastic coating, it degrade after some years and produce bluury images, I own a canon 28-70 f2.8L, after 5 years of use, the images started to look soft, I look through the lens, it seem like one of the elment have some softner effect, I took it to cann and they say that it is non fixable.
I also own alot of other lens like minolta 50mm f1.8, nikon 50mm f1.8, nikon 28-85, 18-200vr, pentqax 120mm, none produce this kind of problem
0 upvotes
Mtsuoka
By Mtsuoka (Jan 1, 2012 at 15:55:18 GMT)
wow you must have super power to be able to observe one particular element of the lens by just looking at it!
what's the name of your super power? is it called "fanboyism"?
Comment edited 39 seconds after posting
5 upvotes
Majikthize
By Majikthize (Feb 17, 2012 at 13:38:00 GMT)
More likely, you kept it in a dark, humid, non-ventilated place, and fungus grew on the glass inside the lens.
0 upvotes
JeepDaddy
By JeepDaddy (Dec 24, 2011 at 08:58:05 GMT)
I want one to say the least. I wish they didn't make the announcement so far in advance of its release. They will probably be late anyway. They are late already on the new 500mm f4 II lens. When is this going to get here?
0 upvotes
snake_b
By snake_b (Nov 22, 2011 at 19:49:00 GMT)
For argument's sake, I really wonder if the final IQ of this cam is lightyears beyond a Pentax K5, for instance. Same for the Nikon D3, for that matter.
0 upvotes
Mtsuoka
By Mtsuoka (Jan 1, 2012 at 15:57:21 GMT)
it won't be a light year, but the difference "should" be observable at least, I guess
0 upvotes
snake_b
By snake_b (Nov 22, 2011 at 19:46:09 GMT)
What "second joystick" on the back is DPR referring to?
0 upvotes
Matt_3D
By Matt_3D (Nov 23, 2011 at 06:05:28 GMT)
There is one above the wheel and one to the bottom right of the wheel.
0 upvotes
munro harrap
By munro harrap (Nov 6, 2011 at 23:31:39 GMT)
I use a 1Ds MkII. I cannot get good lenses for it. I have returned a 17-40mm, a 100-400mmL, and a 70-200mmL recently, and have tried out four 24-70mmL-none of which is as good as my old 24-85mmUSM, and have tried out 3 24-105mmL, lenses and bought 2 which were returned, as like the tryouts, they were soft and quite hopeless at the longer lengths across the frame.
So I fully understand the current problems Canon users have, none of which a new body addresses. The lenses are poor.
I am saving for a new machine, but why bother? as without the optics to match there is little point. Dealers box them so badly they get damaged (must be deliberate- you cannot do that by accident) .
Some lenses may be OK, but this new machine needs lenses that cover 35mm not the EF ones designed for cinema HD 2 Megapixel formats, and everyone is waiting for those. At the moment, its a con.
0 upvotes
bbackspin
By bbackspin (Nov 17, 2011 at 00:42:19 GMT)
i'm not sure why that is the case for you. But I have used loads of L lens with 5d, 5d2 and also 1ds2 just like yourself and quite frankly the lens are spot on sharpness. In saying that though, my 1ds2 tends to misfocus every now and then, compare to 5d and 5d2 focus 100% accurately. Maybe you should get your 1ds2 calibrated ? Just a suggestion
5 upvotes
Boris
By Boris (Nov 19, 2011 at 23:38:00 GMT)
I use a 1Ds MkII daily w/ 135f2,85f1.8,sigma70f2.8,70-200f4,28f1.8 and sigma12-24mk2. I have no problem getting sharp images as long as I keep the shuter speed up....even the cheap 28-135IS is sharp on my 1Ds MkII!
1 upvote
JonHob
By JonHob (Nov 29, 2011 at 10:18:42 GMT)
Hi Munro
I'm in 'the trade' and get a lot of people say the same. It annoys me a little that it's always the lenses that get blamed. I've been to a factory in Japan to see how these lenses are made and how each and everyone is hand assessed.
A friend has a 7D and she kept blaming her lenses. Letters and emails went to Canon and after taking it all to a repair center it turned out it was actually the body's sensor that wasn't flat to the lens mount. It wouldn't have mattered what lens would have gone on the body, the images would have been soft.
To me, if you have 4 L series lenses which are 'hopeless' and a 24-85mm which is OK, you just have been lucky with that lens/body combo.
I've had customers try numerous lenses on a body in my store only to dismiss them. My advice is get the body back to Canon and send all your lenses too and get them all set up together. I'm not saying some lenses are not out, but to get 4 all out, I would start looking at the camera IMHO.
Regards Jon
1 upvote
Mtsuoka
By Mtsuoka (Jan 1, 2012 at 16:01:43 GMT)
as JonHob said, check your camera, the 24-85 is not a great performer anyway
0 upvotes
Applehead
By Applehead (Jan 11, 2012 at 03:06:38 GMT)
The larger sensor cameras, frankly, are exposing the limitations of all lenses, and this is true for all manufacturers. If you play with the microadjustments for lenses, and do it consistently, in a variety of conditions, I think you will find that there are many variables which impact the lens sharpness from one day to another. Temperature, humidity, a myriad of factors impact it. I have thought a certain region of a lens was less sharp, only to find that in another shoot, it's right on target. I'm not denying your experience, but I think it may be an unusual experience, and it may have more variance involved in the evaluation process than you might realize. The testing labs and media have not had the same experience by and large. Again, we will see more variance in the camera/lens combo sharpness as the new larger sensors expose the variance that has always been there, and in fact, to a much larger degree in the past than currently in the latest pro lenses.
Comment edited 2 minutes after posting
0 upvotes
meland
By meland (Jan 16, 2012 at 11:29:02 GMT)
Munro Harrap - may I suggest you read this article? I think it probably explains the root of your issue
http://www.canonrumors.com/tech-articles/this-lens-is-soft-and-other-myths/
I hope that helps.
0 upvotes
dtkorab
By dtkorab (Nov 4, 2011 at 15:46:04 GMT)
I am asking for your patience and experience. I am a newborn photographer and I need a better camera. Considering current and new line-up Canon, what would you suggest. I shoot hand held natural daylight, often low light, and, like everyone else, I need perfect focus. Weight matters, but image quality trumps all. Need to get the shot in a split second. Frequently use 24-70 mm f/2.8. Thank you for taking the time to consider this question.
0 upvotes
Rianeli
By Rianeli (Nov 7, 2011 at 19:06:24 GMT)
5DMKII - Still one of the best cameras around and at a good price point.
1 upvote
snake_b
By snake_b (Nov 22, 2011 at 19:47:36 GMT)
Only problem is the sensor dust issue.
0 upvotes
Applehead
By Applehead (Jan 11, 2012 at 03:17:04 GMT)
Another vote for the 5D Mark II. No sensor dust issue (haven't heard of that one), and the image quality is outstanding.
1 upvote
ratz2plt
By ratz2plt (Jan 19, 2012 at 05:04:39 GMT)
The 5D MkII is a Great camera!
I of course am dreaming of getting a 1D X now but the 5D MkII is great. Maybe when we get our next big job we can get the 1D X? :)
0 upvotes
METROMODEPHOTO
By METROMODEPHOTO (Oct 28, 2011 at 13:16:36 GMT)
IT WOULD BE NICE FOR A CHANCE IF ALL SLR MANUFACTURERS MADE D-SLR WITH FULL SIZE SENSORS AND GET RID OF THESE APS SENSORS ONCE AND FOR ALL. EVERY CAMERA SHOULD HAVE A FULL SIZE 35MM SEMSORS ONCE AND FOR ALL!
6 upvotes
Mtsuoka
By Mtsuoka (Jan 1, 2012 at 16:02:49 GMT)
it is good as long as lens cost/body cost is under control..
0 upvotes
Applehead
By Applehead (Jan 11, 2012 at 03:15:52 GMT)
There's a good reason for APS sensors. They provide benefits in exchange for specific tradeoffs, and obviously, many people like that value proposition. To each his/her own.
0 upvotes
ratz2plt
By ratz2plt (Jan 19, 2012 at 05:07:02 GMT)
At this point going to all full sized sensors would take DSLR's out of the hands of all but pros due to price.
Maybe someday when the cost of manufacturing comes down.
But there are some advantages to the APS sized sensors that some like.
0 upvotes
tszabon
By tszabon (Oct 24, 2011 at 21:44:28 GMT)
have you seen any sample photos? would be great to see how it works at high ISO.
0 upvotes
tipit08
By tipit08 (Oct 23, 2011 at 15:14:51 GMT)
Just can't understand why they would announce a camera as important as this one... 5 months ahead of time ???
0 upvotes
DanCart
By DanCart (Oct 23, 2011 at 17:25:45 GMT)
Considering that this camera will cost more than 5000 euros, this gives people enough time to start saving for it or to go and apply for a loan etc
8 upvotes
Mathias Japri
By Mathias Japri (Oct 29, 2011 at 07:13:08 GMT)
so people that planning to switch to nikon will reconsider.
3 upvotes
Poss
By Poss (Oct 31, 2011 at 04:39:54 GMT)
It shows what you have in the pipeline and keeps your existing pro base from wondering if you're alive as a manufacturer or not.
Quite unlike Nikon actually.
2 upvotes
affclga
By affclga (Nov 5, 2011 at 14:27:42 GMT)
Agreed. There has been a steady stream of professionals abandoning Canon for Nikon. The 1DX is a direct response, bettering (at least on paper) the Nikons in what had been regarded as their advantages. The announcement appears intended to stem defections.
1 upvote
Zabih
By Zabih (Oct 22, 2011 at 06:05:18 GMT)
This is an important technology point, and I hope to can buy it!
0 upvotes
marsbar
By marsbar (Oct 22, 2011 at 15:28:28 GMT)
There are always important technology points! Hate to say it, but this "hype" over the latest and greatest, never ends... wait two years... 1D XT... :)
1 upvote
BW18
By BW18 (Oct 21, 2011 at 11:51:59 GMT)
Have a Canon and I love it (5D). Someday when I have the $$ I will get a second body. I am a photographer. It is frustrating to hear that all the camera manufactures are adding video. Perhaps there is a need for some, but give me a break! While reading this article it sounded great until "…it's clear that Canon has had movie shooter in mind." If I want to shoot movies I will use a movie camera! Thoughts anyone?
3 upvotes
RawDogg
By RawDogg (Oct 23, 2011 at 00:24:26 GMT)
The HD Video on my 5DMII is Awesome. But I do agree with you. Much easier to use an HD Camcorder. (by canon)
1 upvote
Jeremy Loy
By Jeremy Loy (Oct 23, 2011 at 08:23:07 GMT)
why must we have video mode on a camera? We are taking photos and not the video. Can we have a "pure" camera for photo only?:
Comment edited 25 seconds after posting
1 upvote
DanCart
By DanCart (Oct 23, 2011 at 17:35:37 GMT)
Yes as photographers its not the most the most exciting thing but I think HD on SLRs is great because you no longer need to buy a camcoder for great video and you wont have to carry 2 cameras, just use your SLR for both- how convenient! Another plus is that photographers wanting to branch out into making movies wont have to invest in new cameras and one other advantage of shooting movies on SLRs is the huge abundance of lenses you can use compare that to regular video cameras!
Oh and its more economical to buy a SLR and some lenses compared to renting or even buying professional video cameras
2 upvotes
MaciekM
By MaciekM (Oct 23, 2011 at 18:07:55 GMT)
There should be an option to buy Camera with HD capabilities or without so soe photographers wouldn't be forced to pay for functions the will not use.
3 upvotes
DanCart
By DanCart (Oct 23, 2011 at 18:46:20 GMT)
Sigma DSLR cameras are pretty decent for people who want no frills cameras with no live view, no HD,low megapixels and are willing to look past lack of high ISO capability ........I dont mean to play devils advocate for Canon but what people will be paying for is the High ISO, improved processor as well as the HD , I think HD is an afterthought ...if they dont improve it competitors will outperform them and Canon users might complain and besides since Canon produce the best video on SLRs they have to keep improving it to remain the best
1 upvote
vladimir vanek
By vladimir vanek (Oct 25, 2011 at 23:31:19 GMT)
The movie shooting functions are only a matter of software, there's no extra hardware needed to shoot movies. Thus there are no additional costs to produce a HDSLR versus a DSLR without movie shooting functions. And, at the same time, the product is more competitive - wider range of potential buyers - for free.
2 upvotes
Pasadena Perspective
By Pasadena Perspective (Oct 27, 2011 at 01:48:39 GMT)
BW18, Jeremy Loy, MaciekM:
I have to agree with vladmir vanek. here. if the camera were negatively compromised in any way as a stills camera in order to facilitate the video side, then there would be real cause for concern. But at no point do we a direct correlation between the addition of video functions and either an increase in price or decrease in stills performance.
The EOS-1D X is launching at the same price point as the EOS-1DsMKIII. There is no premium for the video features. They have been added on for free.
Most of the new features that make the EOS-1D X attractive are on the stills side: faster burst shooting rate, improved ISO performance, alleged better auto-focus, etc.
To complain about the addition of video because you don't use would be like a landscape or artistic photographer complaining about paying for improved auto-focus when they prefer to use manual focus.
2 upvotes
diabolik
By diabolik (Nov 1, 2011 at 15:46:11 GMT)
Hai proprio ragione
0 upvotes
Mtsuoka
By Mtsuoka (Jan 1, 2012 at 16:05:42 GMT)
that's Sony's excuse for not having video mode in A900
if you don't use it, just turn that off
0 upvotes
WillieG
By WillieG (Jan 6, 2012 at 19:44:09 GMT)
Well said BW18.
Do you others actually believe what you're saying? No extra costs involved to add video?
What about extra programming time to add menus to support video and its settings. What about changes to the body to cram in extra buttons? What about designing a sensor that will run continuously without melting down from overheating? There are substantial extra costs involved in adding video to a DSLR. I'd like to see Canon offer two 1D X cameras - one with video and one without. Then we'll see if the buyers in this price range are willing to pay for the amateurish video function. I suspect that video in cameras at this level would be gone in a year.
0 upvotes
meland
By meland (Jan 16, 2012 at 11:42:21 GMT)
Actually it costs Canon (and other manufacturers as well) virtually nothing extra in terms of manufacturing costs to add video. As a stills photographer that never uses video I don't see any advantage to me either but provided functionality of stills operation is not compromised there's not a problem. Of course the addition of video may be very important to some people and that's fine - it certainly has provided a marketing usp for Canon and others.
The only thing I can think of where video does make a negative difference for stills is with the adoption of power zooms (which I guess are probably necessary for for smooth zooming on video). For stills these are a pain - too slow and unresponsive.
0 upvotes
skrulm8
By skrulm8 (Jan 22, 2012 at 11:20:07 GMT)
And how much would a movie camera offering similar quality and lens selection cost? Would you be able to get it for less than ten 5D Mk IIs?
0 upvotes
magus424
By magus424 (Feb 14, 2012 at 18:53:53 GMT)
People thinking that it would save money to skip video show a severe lack of reasoning - the firmware already has video support thanks to every other camera, and the most that might ever be on a camera button-wise that's dedicated to video is a switch from camera to movie mode. A whopping $0.20 worth of plastic, and maybe $1 or so worth of electronics to handle the signal.
There's no way it would be a large enough drop to make it worth dropping support. Not to mention it would cost Canon *more* to keep two manufacturing processes for the two different bodies, just to *remove* a feature.
0 upvotes
Clarrie
By Clarrie (Oct 21, 2011 at 02:22:44 GMT)
It will be interesting to see the specs of the inevitable Sony SLT A99.
1 upvote
skrulm8
By skrulm8 (Jan 22, 2012 at 11:26:29 GMT)
that translucent mirror thing is a disaster... it means that whatever sony comes up with, it's going to be 30% worse in low light than its peers... not my kind of tradeoff!
0 upvotes
ABETTERDJANDPHOTOGRAPHER
By ABETTERDJANDPHOTOGRAPHER (Oct 20, 2011 at 22:19:46 GMT)
You should all sell your Canon gear on ebay and buy some MINOLTA lenses and that 24MP SONY A77 everybody is going nuts about. It may not be the best at high ISO but everywhere else it really rocks for only $1400.
1 upvote
Mtsuoka
By Mtsuoka (Jan 1, 2012 at 16:07:47 GMT)
I don't like the build of A77 and I "still' prefer OVF and I don't think half mirror is the final answer (hate losing light)
Comment edited 15 seconds after posting
0 upvotes
kufelt
By kufelt (Oct 20, 2011 at 22:04:41 GMT)
No review so far mentions AF in video mode....
I was wondering if $6800 is enough money to spend in order to get usable continuous autofocus in movie mode? Obviously my 7D I spent $2000 only on the day it was launched was way too cheap for that.... Same with my buddy's 1D MkIV - he spent only $5500.....
Or should we switch to Sony??
0 upvotes
vladimir vanek
By vladimir vanek (Oct 25, 2011 at 23:32:46 GMT)
Yes, switch to Sony if you want a camcorder. This is a camera, remember?
2 upvotes
Roberto Coin
By Roberto Coin (Oct 31, 2011 at 19:46:22 GMT)
A Panasonic Lumix GH2 will do all of that -- autofocus and even outperforms a 5D MK II.
0 upvotes
Mtsuoka
By Mtsuoka (Jan 1, 2012 at 16:08:34 GMT)
get the C300
0 upvotes
Zalllon
By Zalllon (Oct 20, 2011 at 17:19:38 GMT)
The capability of high ISO hopefully means that mid level range will be much cleaner. Shooting a wedding at the time where no flash is allowed in a candle lit church. Sure you can use a fast lens and hope your eyes are in focus with a shallow DOF, but bumping up the ISO to 6400 for a clean image and an additional DOF is a welcome option. At this level, I would've hoped for built in Wifi for studio use, instead of expensive options. Eye-fi doesn't work well in my 1Ds MKIII so I use tethered if I'm not working with people.
1 upvote
Paul Guba
By Paul Guba (Oct 20, 2011 at 13:33:24 GMT)
You know I have been taking pictures for 25 years and have yet to feel the need for 6 digit ISO. Perhaps when I get paid to photo a coal mine. Call me a minority but I would actually like lower ISO, like 32 or 16 I would find it quite useful in studio and with landscapes. That said I shoot nikon and canon and both are fine tools and I don't really give one the edge over the other. I don't have much need for video but it seems that is the biggest thing Canon is offering. Much of the changes are to increase video performance so they must see that as important.
Its not about the camera. Go take pictures.
4 upvotes
andreas_d
By andreas_d (Oct 20, 2011 at 16:40:38 GMT)
You sound like that guy from the 19th century who said nobody needed a device called "the telephone."
I couldn't agree more that a camera is just a tool - but a better tool in good hands will help deliver results never before possible.
1 upvote
azlee
By azlee (Oct 21, 2011 at 13:23:41 GMT)
I agree with both Paul and andreas_d, and totally agree with Paul for the need for a lower ISO. The need for ND filters is really old school.
0 upvotes
Derek Clarke
By Derek Clarke (Jan 22, 2012 at 18:59:17 GMT)
I'm not sure why you would want lower ISO support when you can still buy ND filters!
It isn't the same as pushing the ISO upwards.
0 upvotes
Eric8255
By Eric8255 (Jan 23, 2012 at 22:30:16 GMT)
I totally agree - a genuine lower Iso is of far more use than six digit ISO - unless you are operating a speed camera or for surveillance where iq is not required.This is what canon say it is for!!
0 upvotes
whp
By whp (Oct 19, 2011 at 20:30:13 GMT)
If Hasselblad keeps dropping prices while increasing performance and megapixels, Canon and Nikon are both going to be selling cameras to just the Ashton Kutchers of the world and not working pros.
As for photojournalists using Canon and Nikon, well, I call them the working homeless. Many of them just use the consumer models as they are paid peanuts because their industry doesn’t know how to move from paper to web. Newspapers seem to throw out all of their design principles and ethics when publishing online, New York Times website excluded.
Comment edited 1 minute after posting
6 upvotes
BW18
By BW18 (Oct 21, 2011 at 11:56:58 GMT)
BINGO…give me a quality camera at an affordable price without all the excess bells and whistles. A Photographer just wants to shoot, not take the entire creative process out! Adding some new technology to a camera is good, even innovative. Sometimes less is more!
1 upvote
DanCart
By DanCart (Oct 23, 2011 at 17:45:25 GMT)
BW18 from what you said maybe you should consider Sigma SLRs !
0 upvotes
Roberto Coin
By Roberto Coin (Oct 31, 2011 at 22:20:55 GMT)
Hasselblads will never go that low in price. Keep dreaming.
0 upvotes
Sofus Comer scomer
By Sofus Comer scomer (Oct 19, 2011 at 19:22:05 GMT)
Having had Nikon for 4 years (Nikon D3) and eagerly waiting for what Nikon comes with soon, I find that this is the most clever move Canon could make. What a perfect camera. I would switch today, if I had the $. No need for more than 18mp yet a ton of super powerful wellthought of featuers... If you want more pixels, then go middle format, to properly gain the missing details your wanting. Well done Canon... What will Nikon do, and when?
4 upvotes
Tape5
By Tape5 (Oct 19, 2011 at 17:50:35 GMT)
C'mon Canon ! we want pix we want pix we want pixel pixel pixel !
I know most high megapixel cameras produce rubbish photos !! just look at Phaseone IQ 180 !Journalists and wedding photographers will not be able to sustain your business you know. People are not getting married that often any more anyway. You need us Pixelnuts, rich kids, compulsive buyers, poseurs and artists to survive and we all want more res res res !!
MF peole are going to walk in big time, sure, but that is no reason to panic like this ! Nikon is not going out without a fight. D3x has been freaking us out since Dec 08.
Or put a sign out telling us to go away and this is the direction you are going in the coming decade. Soon someone will make a camera that shoots 100 frames a second from factory for ten years, nonstop. Then all you have to do is to point it. Where is photography going after that?
0 upvotes
Leo LS
By Leo LS (Oct 19, 2011 at 17:38:30 GMT)
I think this camera will have a life cycle of at least 5 years and will mark the end of DSLR era like EOS 1V marked the end of SLR. EVF and mirrorless will certainly take over.
0 upvotes
whp
By whp (Oct 19, 2011 at 20:17:13 GMT)
If the AF sucks, like it does with the Mk4 then it's going to have the life cycle of 100 years because everyone will switch. Three times the charm when it comes to Canon releasing problematic flagship bodies. Like another poster said, why is Canon offer so many AF modes? It should just work. Which is a sign that the AF issues are still there.
0 upvotes
Rob Jelsma
By Rob Jelsma (Oct 20, 2011 at 08:50:02 GMT)
AF sucks ..... on the MK4 ..... If you're not able to shot tack sharp with the MK4 ... I think moving to another profession is the resolution to your out of focus problem !
6 upvotes
Carbon Fibre
By Carbon Fibre (Oct 20, 2011 at 18:58:39 GMT)
I beg to differ that the AF on the 1D MkIV sucks. In 2010, when I was not familiar with the various AF modes, keeper's rate was only about 5-10% for my F1 GP shots. As I understood the AF modes much better, I set it under the customized menu for quick access, to switch between modes. This year's F1, my keeper's rate was about 30%. There were simply too many pics that were tack sharp I had such tough time selecting the best. From what I gathered from your comments, you probably have not optimized the usefulness of the AF modes. 1D MkIV's focusing system is impressive and I am really excited to test the new 1DX AF system!
0 upvotes
Teila Day
By Teila Day (Oct 20, 2011 at 21:48:01 GMT)
I think the point is that people feel that they should not have to program a camera to take sharp images with a competent focus system. Professionals want to be able to aim and shoot (within reason) and a camera costing $5k or more should deliver most of the time regardless what option I have selected in the focus system menu.
I think Canon will hit a home run with this body! Although I would like to see a very high res body- this camera makes the most business sense for Canon since most shooters don't need/want gobs of extra pixels they don't need in the course of business... and w/Med Format prices w/in only $5k or so of this flagship Canon, it's clear that Canon has their head screwed on straight. I find the camera (at least on paper) very compelling and I'm very interested for reviews to pour in months from now. I'm interested most in the high iso capability in the "realistic range". I hoping for around a 1.5-2 stop advantage over the 5d2 at 6400 iso.
Comment edited 7 minutes after posting
0 upvotes
TTMartin
By TTMartin (Nov 27, 2011 at 21:06:28 GMT)
Professionals want a aim (point) and shoot camera, really?
0 upvotes
Wallace Photography
By Wallace Photography (Oct 19, 2011 at 15:01:29 GMT)
FYI, yes Eyefi cards are SD, but there are CF adapters.
But this camera should absolutely have wireless built in.
1 upvote
whp
By whp (Oct 19, 2011 at 20:35:58 GMT)
I read a few blogs where Nikon users are complaining about how eye-fi does not work properly using a CF adaptor. The Eye-fi website also confirms issues with using adaptors too.
0 upvotes
JMD-70
By JMD-70 (Nov 28, 2011 at 00:00:56 GMT)
I have D3 and D3s,...and have success with Eye-Fi and Extreme SD-to-CF adapter. I also have WT-4,...which of course works, but you can't beat what the Eye-Fi does at its price point. Lastly, I tested my Eye-Fi card (8gb Pro X2) in a D7K and it was a perfect marriage,...the camera loves the card loves the camera! JMD
0 upvotes
Joas Souza
By Joas Souza (Oct 19, 2011 at 13:40:07 GMT)
I CAN'T BELIEVE THAT IS HAS ONLY 18MP. EVERYBODY WAS EXPECTING 32MP. WELL, NIKON STILL AHEAD, UNFORTUNATELY.
2 upvotes
Henry M. Hertz
By Henry M. Hertz (Oct 19, 2011 at 14:45:55 GMT)
correct is: every noob was expecting 32 MP.
pros expect more then the "noob measurement" for image quality... aka "megapixels".
comparing the 3DX to a 12 FPS beast shows that you have no clue what you are talking about.
13 upvotes
The Gozitan
By The Gozitan (Oct 19, 2011 at 14:53:35 GMT)
WE DON'T NEED MORE MP. WE NEED LESS NOISE AND HIGHER IQ. SEEMS LIKE A STEP IN THE RIGHT DIRECTION TO ME.
19 upvotes
yabokkie
By yabokkie (Oct 19, 2011 at 15:40:38 GMT)
32MP is a conservative number. I would like 50% more pixels than 32MP for now, well over 100MP (I consider 100MP as standard) in the future.
the truth is that there is very little, almost negligible tradeoff when we have times of more pixels. anyone can simply verify that by comparing D3X against D3, twice the number of pixels, nearly no negative impact on image quality, especially when you resize D3X to 12MP and postprocess it with Dfine (the same algorithm used by D3 to produce "half-cooked-raw" file).
1 upvote
khaledsa1
By khaledsa1 (Oct 19, 2011 at 16:10:15 GMT)
It's the quality and size of the pixel not the quantity. I have the 1Ds MK II, 16.7 MP. Since march of 2005, I may have used each image to it's full size, 1% of the time. To this day, when processed properly from RAW, I can beat any new 18 and 20 MP image, especially at 1600 and 3200 ASA. If you are doing landscape photography, there are cameras for that. Also, these sensors are exceeding the limits of the optics. That's why I am waiting for Larger sensor with less pixels for the G13.
1 upvote
Applehead
By Applehead (Jan 11, 2012 at 07:16:49 GMT)
I like having extra MP for the cropping options and quality of large prints. This camera is the right one for its target market. Hopefully the 5D3 will have 26 to 32 MP and great image quality, at a slower FPS. That will provide a camera for each market.
0 upvotes
THSolutions
By THSolutions (Oct 19, 2011 at 13:14:16 GMT)
I cannot wait, 4 months after this baby hits the market, there are going to be plenty of USED 1d and 1ds's available!!! Oh the Joy!! LOL YES!
Comment edited 16 seconds after posting
5 upvotes
sieger
By sieger (Oct 19, 2011 at 09:31:02 GMT)
The 1 DX looks like a nice tool for pros who know what they need, but not a one for all camera. Photojournalists, wedding photogs, and sports shooters come to my mind as possible users.
Someone mentioned BIF: If one comes from an APS-H form factor, this may not be the right tool. It requires bigger, heavier and more expense lenses.
The FF will also be a challenge to many who have bought into crop sensor lenses, or who enjoy the sharpest center part of their FF lenses on a crop sensor.
About high ISO performance vs. megapixel count: The credit should go to Nikon with their D3 (and D3s).
Nothing has been said about live view. How does it focus using live view? Is it easy to use?
I would assume that 1DX has a good battery life, but how good? After all, there is a lot of processing going on in the camera.
I am one of those who wish there was a built-in GPS. WiFi would also be nice.
To sum it up: seems like a good tool for many applications, but pictures tell more than a 1000 words.
Comment edited 45 seconds after posting
0 upvotes
Taikonaut
By Taikonaut (Oct 19, 2011 at 09:20:21 GMT)
I guess the 5DMk3 will be the high MP studio camera with emphasis on video, swivel screen and fill the void of the 1D price point of £3k. 7DMk2 will be the new APS-H camera and priced around £2k.
1 upvote
Taikonaut
By Taikonaut (Oct 19, 2011 at 09:11:51 GMT)
Yes but the hacked GH2 has high bitrate over 100mbps if needed and the GH3 will get 1080p 60fps at higher bitrate but fraction of the cost.
0 upvotes
john
By john (Oct 19, 2011 at 08:49:22 GMT)
at first canon introduce AF adjustment setting to get away their poor AF, now they have AF mode presets, does that mean they still get poor AF, and need the user to decide which mode is good?
I just know one thing, if the camera have great AF system, like the D3,D700 and D300 you really don't need to touch any setting, I don't need to use AF adjustment, and I stil have great spot on results from racing cars, latin dance, kids running to me.
from all my photo friends and my own experience, the best AF canon SLR are still eos 1, eos 1n and 1dm1
1 upvote
whp
By whp (Oct 19, 2011 at 07:16:24 GMT)
I have the 1dmk2n and the 1dmk4. I found the Mk2n reliable but the Mk4 has big problems with focus using zoom lenses. Zoom-in,focus is fine, but zoom-out and it front focuses.This happens on all my zoom lenses and two Mk4 bodies. I sent bodies and lenses at the same time to Canon Irvine for repair and it's still the same. I worry that the 1d-X could be the same way if they are holding the Megapixels at 18, then it won't be too obvious. Low light will also cause front focusing too. AF micro adjustments don’t solve this problem.
Second issue is you can’t use Eye-Fi cards with the removal of the SD card slot. Canon's expensive wireless transmitter device (around $750) is horrible and techs are not helpful at 800-OK-Canon. I got an Eye-Fi SD card and was up and running in 5 minutes. It cost about $150 for the most expensive card. I set up the Eye-Fi i to wirelessly send small jpeg preview images to the iPad and iPhone. Eye-Fi does not make a CF version and SD-CF adapters don't work.
Comment edited 3 times, last edit 4 minutes after posting
0 upvotes
Poss
By Poss (Oct 18, 2011 at 23:12:33 GMT)
A major manufacturer finally makes an appropriate "lower" MP sized full frame sensor camera with improvements where it counts the most (DR, ISO, AF)
You know... the kind of camera the silent majority of working pros will buy and the vocal minority of people, who'll never actually get one, will endlessly cry about.
Bravo Canon!
It only took what... 5-6 years since Canon's last great FF pro body?
8 upvotes
Chez Wimpy
By Chez Wimpy (Oct 18, 2011 at 23:59:08 GMT)
I guess Nikon - for the last four years - didn't count?
5 upvotes
Superka
By Superka (Oct 19, 2011 at 03:07:49 GMT)
Nikon - Yes!
Comment edited 2 times, last edit 2 minutes after posting
1 upvote
Maddrew
By Maddrew (Oct 19, 2011 at 06:34:37 GMT)
I'd take lower resolution sensor with better low light performance over high resolution sensor witih mediocre low light performance any day (although Nikon gives us both options in the D3S and D3X). I wonder what would Nikon come up with to top this?
0 upvotes
Poss
By Poss (Oct 20, 2011 at 01:44:45 GMT)
Nikon sort-of counts... 16-18 MP is the ideal size for most uses and the D3 had 12 which was slightly underwhelming. Now, don't get me wrong, I shoot a 12MP D700 and my complaints about it have nothing to do with his resolution but the D3 flagship could have been a 16MP maybe at a time where the 1DsMK2 was already there for a few years... hence the "slightly underwhelming" feeling
0 upvotes
OneShotOneClick
By OneShotOneClick (Oct 18, 2011 at 20:51:43 GMT)
Hello Everybody!
I'm a HIG ISO ADDICTED because I love low light situations.
I've read that Canon has developed "PIXEL FUSION" tecnology.
It merge a 3x3 sensor's pixel to work like one to improve ISO quality. It will be equipped on small sensors and mirrorless camera.
Does someone know if it will be available on 1D-X??
I don't care if it could reduce the amount of MP if it make me bring home pictures and videos when I should not without that tecnology or without a 1600$ lens.
I have to add that i love low light portrait using hard macro.
So the question remain..
Will 1D-X be equipped with PIXEL FUSION?!?
0 upvotes
michaelrz
By michaelrz (Oct 19, 2011 at 10:34:13 GMT)
Isn't ISO 204,800 enough?
Boy, are we hungry! :)
0 upvotes
OneShotOneClick
By OneShotOneClick (Oct 19, 2011 at 11:50:13 GMT)
@ michaelrz
204,800 is too much!!
I WANT IQ at high ISO.
If YOu take Nikon D3s at high Iso Its unique but GRAINY when You use it in mid dark situations at 12500 or more.
It would be fantastic using PIXEL FUSION on a native sensor 100-52000 ISO having great IQ
So we could have a ultra clear 25000 ISO without noise at 6 or 8MP
0 upvotes
michaelrz
By michaelrz (Oct 19, 2011 at 16:23:07 GMT)
@OneShotOneClick
OK I get your point.
I Believe the 1Dx would surpass the D3s. I won't be surprised at all if this sensor could produce clean images at 12500 or even 25000.
Anyway, basically I'm on your side, but It's just that we sometimes expect too much and forget to enjoy and get excited by the marvels we already have. We hold in our hands technologies that just a decade ago would have seemed astonishing or even unobtainable.
Just a thought... :)
1 upvote
Andre Oliveira
By Andre Oliveira (Oct 18, 2011 at 20:31:58 GMT)
No price info yet?
I feel that many people will miss the 1.3 crop sensor. They could well have made it dual, full frame and an option for cropped operation with the touch of a button, then it would really be the successor of both EOS 1Ds and EOS 1D line.
2 upvotes
R Butler
By R Butler (Oct 18, 2011 at 22:29:52 GMT)
MSRP of $6800 - it's at the bottom of the news story.
0 upvotes
yabokkie
By yabokkie (Oct 18, 2011 at 19:18:19 GMT)
this is not a new 1D4 + 1Ds3. it's effectively 1D5 to compete with future D4. maybe 5D3 will replace 5D2 + 1Ds3, with over 40MPs to power play 645D. there should be no problem we go 100 or hundreds of MPs.
there is almost no (little) compromise of image quality when we go more pixels. the most affected is speed ... or image quality at the same speed. that's why Canon chose 18MP, for sports.
image quality is not the same thing as pixel quality. though things are complicated, you can think image_quality = pixel_quality * number_of_pixels.
Comment edited 2 times, last edit 3 minutes after posting
0 upvotes
frenchmonkeys
By frenchmonkeys (Oct 18, 2011 at 19:05:38 GMT)
I know it's always been in vogue to say 'you don't need higher resolution', and complain about the megapixel war, but resolution has always mattered in photography.
When I shot film/trannies, I would occasionally use Scotchchrome 1000 for it's golfball grain, or push the hell out of Tri-X for the same reason. I would sometimes choose Velvia because it was smooth, detailed, with extremely fine grain.
With digital I can't just choose a different sensor - I'm forever stuck with the one that comes in the camera. More pixels gives me more choices. I can reduce quality, add noise, but I can't do the reverse in any meaningful way.
It's not all that long ago that people were saying that 5 MP was enough for anyone, then 8, then 10, and so on. I loved the images on my 1D, but I wouldn't trade my 1D4 for it - I enjoy the extra 12 MP.
Of course noise has to be managed too, and high ISO is welcome, but I'd trade some of the high ISO capability for a spec. that includes an extra 20-30 MP.
5 upvotes
Poss
By Poss (Oct 18, 2011 at 23:05:34 GMT)
Why not get a medium format camera then? No diffraction issues, gobs of resolution, ability to do multiple exposures... you know... all the goodies...
0 upvotes
Henry M. Hertz
By Henry M. Hertz (Oct 18, 2011 at 23:24:17 GMT)
you are one of the guys who think going from 10MP to 20MP doubles the RESOLUTION?
well let me tell you not even close!
and 18 vs 21 megapixel make next to no difference.
especially not when the 18 MP file is much cleaner and is (maybe) made with an sensor that has a weaker AA filter.
spatial resolution is decreased by an AA filter.
so a 21 MP sensor can have less spatial resolution then a 18 MP sensor.
but to whom im talking.. you MP junkies are so clever..... lol
1 upvote
j2ker
By j2ker (Oct 19, 2011 at 03:44:48 GMT)
What do you shoot and at what resolution do you print that you need so many MP to slow down your workflow? I make very few hard copies, and the ones I make up to 20"x30" look acceptable with my 4.1 MP D2hs. I can't imagine needing more than ~ 12 MP, unless your output is huge. IMHO, lower pixel density = better high ISO = better photos.
0 upvotes
Applehead
By Applehead (Jan 11, 2012 at 07:32:21 GMT)
Medium format is not a good answer to wanting more megapixels (MP). It requires much higher f/stop, and therefore, light, to get the same depth of field, making it inappropriate for many uses. Switching formats also requires a significant investment in camera and lenses. Megapixels are useful if the IQ is there, and a few cameras have proven that one can have high MP in the 35mm format DSLRs and still have good IQ at the expense of FPS, diffraction at f/8 and above, and a little high-end ISO, primarily.
0 upvotes
jmmgarza
By jmmgarza (Oct 18, 2011 at 18:40:04 GMT)
Too bad Canon glass is not up to Nikon specs... sweet body though.
0 upvotes
frenchmonkeys
By frenchmonkeys (Oct 18, 2011 at 19:35:28 GMT)
How so?
In my opinion, Nikon and Canon's pro glass offerings are much the same as each other: a great balance of IQ, speed, build quality and price. For me, Canon just has the edge - the lenses that make sense for my kit are, on average, marginally better from the Canon range, and it's what I use most. For others, it may be a different story. Glass isn't the reason to choose between Canon or Nikon though.
TBH, I don't think the leapfrogging of body features is a reason to choose either - first one, then the other has the edge.
Nikon has better flash capabilities for certain. Personally, I consider using flash a last resort (I don't refer to studio flash here), so for me, that also isn't a reason to choose.
I use Canon most because it feels more comfortable for me to use; fits my hand better. It 'disappears' more readily for me, so I can just concentrate on taking photos.
I'd love some additional features and I've already whined about them, but the glass is good.
3 upvotes
yabokkie
By yabokkie (Oct 18, 2011 at 20:10:32 GMT)
Nikon 24-70/2.8 is certainly better than the Canon one, especially at the tele-end. but Canon 70-200/2.8LIS2 provides better image quality than VR2 (I personally would rather prefer a lens that can go wider at close range, especially if I have zoom micro in my bag). so it really depends.
0 upvotes
Henry M. Hertz
By Henry M. Hertz (Oct 18, 2011 at 23:27:20 GMT)
don´t feed the nikon trolls.
8 upvotes
jmmgarza
By jmmgarza (Oct 20, 2011 at 23:23:08 GMT)
You haven't been reading the countless DPReview articles on Canon and Nikon lenses. Yes, Canon is "almost" as good a Nikon. Veritas vincit.
0 upvotes
Nigel Bolton
By Nigel Bolton (Oct 22, 2011 at 08:34:34 GMT)
Well you haven't been physically trying a Canon EF 300MM f/2.8 II on a 1DMk4 and 5DMk2 Vs Nikon 300mm F/2.8G VR on a D3X. Don't get me wrong the latter produces fantastic images. BUT you have to put at least a x1.4 converter or possibly even a x2 on the Canon combo to bring the image quality DOWN to the Nikon. For a bit of (resolution only) support on this try the comparison below.
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=739&Camera=453&Sample=0&FLI=2&API=0&LensComp=650&CameraComp=614&SampleComp=0&FLIComp=0&APIComp=0
0 upvotes
uberfoto
By uberfoto (Oct 26, 2011 at 06:09:07 GMT)
Nigel, you're comparing a 2nd gen Canon 300 with the first gen Nikon 300. At least compare 2nd gen lenses from both manufacturers...
Canon and Nikon both have some great glass. Some Nikons are better than Canon and visa versa.
0 upvotes
Alberto Tanikawa
By Alberto Tanikawa (Oct 18, 2011 at 18:13:34 GMT)
Chuck Westfall did not go into too much technical detail on the sensor. 18mpx may not seem enough for some, but what if, a big IF, Canon pulls something like a layered sensor - a la Foveon? Not very likely, but 18mpx like that, great ISO performance, and speed in one package, the 1Dx would be hard to beat!
0 upvotes
azlee
By azlee (Oct 21, 2011 at 13:46:40 GMT)
Foveon's are noisey at anything over 400 iso.
0 upvotes
DanCart
By DanCart (Oct 23, 2011 at 18:33:29 GMT)
and Foveons are the absolute best at ISO100
0 upvotes
Tape5
By Tape5 (Oct 18, 2011 at 17:38:21 GMT)
I totally understand people who are excited with the added speed and higher ISO, and I agree that the higher pixel count is not everything, but there must also be room to criticise the higher frame rate. Do we all need that? The real pros are ruled by their needs anyway, but this type of 50,000 frames a second camera is likely to turn its owners into shoot now and ask later type of photographers carrying a pretty ugly device. Pixel numbers do matter in my view. They allow a more detailed recording of the image not a faster one. We are not all journalists and many of us have minutes if not hours or days to consider what we are shooting. So I hope canon has a big one coming. 50,000 megapixels and one frame a day for me thanks.
7 upvotes
lioneyes90
By lioneyes90 (Oct 20, 2011 at 20:31:07 GMT)
0.000012fps would not be that practical though, and you would need a supercomputer to handle a 50 gigapixel image :/ But it was a funny post :)
Comment edited 50 seconds after posting
0 upvotes
jamesfrmphilly
By jamesfrmphilly (Oct 18, 2011 at 17:37:40 GMT)
i was going to go nikon for the multi exposure.
this keeps me at canon.
0 upvotes
KiboOst
By KiboOst (Oct 18, 2011 at 17:27:29 GMT)
Nice camera, good to see Canon rethinking it overal (metering, AF etc), but wow, replacing 1Ds line with a 18mp sensor ? Big fail here, I'm waiting at least 30mp and amazing IQ at low iso, don't care about speed. Sure won't replace my 1DsII with 1DX. I do slow shot, tripod, low iso, large fine art print, no need for low res machine gun. If a 1DsX around 30mp don't come soon, I think it will be time to go to the other side, D800 seems appealing even if I largely prefer a big monobloc body like 1D for vertical shooting and general feeling in hand. 5D body size don't really appeal me, maybe D4x then ? 1DX make me starting to look ar Nikon lenses, even if it's a damn good camera for sport/bif shooters.
5 upvotes
stephoto
By stephoto (Oct 18, 2011 at 17:10:01 GMT)
no mention of AA filter? may it be weaker than the previuous one on 1dsmarkIII?
0 upvotes
Jeff Greenberg
By Jeff Greenberg (Oct 18, 2011 at 17:04:13 GMT)
"people are going to feel much more comfortable up-rezing"
Especially if Canon advises as to the best up-size workflow...
Am eager to see in-camera multiple exposure function added to 7D line!
0 upvotes
Alxy
By Alxy (Oct 19, 2011 at 02:46:55 GMT)
May be they meant that people will be up-rezing more with 18mp then with 32mp camera, which everyone was waiting for?
1 upvote
Steve oliphant
By Steve oliphant (Oct 18, 2011 at 16:34:29 GMT)
Wow finally ,they get it, I would love to see anyone post real faxes on the resolving ability on any 35mm lens .I think the very best Canon or Nikon lens will resolve 119 line per mm ,so about 10 mp ,if you want to interpolate use photoshop, it will do a great job.Im a Canon user and I was about to go to Nikon because they make better cents at 12mp, good on ya Nikon ...
0 upvotes
frenchmonkeys
By frenchmonkeys (Oct 18, 2011 at 19:56:35 GMT)
Sigh. So you think that the results from a 1D4 (16MP) and 1D3 (10MP) are pretty much the same then? I've shot with both. The 1D3 can't hold a candle to the 1D4.
Photoshop interpolation is NOT a replacement for higher resolution sensors. Suggest you try it. You can even do it off the same camera - take a small JPEG, and a full size one with the next frame. Increase the size of the small one in PS. Now compare the two. See? No? Make it simple then. Try with a 10 by 10 pixel image interpolated to 16 by 16, compared to a 16 by 16 original. The results are more obvious here, and the same thing happens with higher resolution.
I agree resolution isn't the only factor, but it is a factor, and a fairly important one. So long as the pixel quality is high, I'll take more megapixels please.
5D2 is a case in point here though. Higher resolution than the 1D4 by some margin, but lower IQ. I want my cake and eat it too. Lots of pixels, high quality, and lose the shutter speed.
2 upvotes
yabokkie
By yabokkie (Oct 18, 2011 at 20:45:04 GMT)
single-pixel-camera is the ultimate answer to those who prefer pixel quality over image quality.
2 upvotes
noisejammer
By noisejammer (Oct 18, 2011 at 21:14:11 GMT)
I have tested this number. I checked a 70-200 IS Mk 2 using a 7D. Pointing it at the stars, the lens resolved to single pixels in red and green. There was some chromatic aberration present in the blue channel, but it was still very good. Since the 7D pixels are (iirc) 4.3 microns, it could be argued that the lens was operating at around 115 lp/mm. My experiments with a 135L yielded very similar results.
There is however quite a lot of space at the top - a truly diffraction limited f/2.8 lens should be able to reach 585 lp/mm in green light.... assuming you could live with the absurdly thin DoF.
Comment edited 41 seconds after posting
1 upvote
Chez Wimpy
By Chez Wimpy (Oct 19, 2011 at 00:06:13 GMT)
I hope I am reading this wrong. The 24TSEII (to pick an example) resolves over 45MP worth over the FF image circle. How do I know? Stitching with my 18MP APS-C camera lets me see some of the FF potential, and this is still sharp at the pixel level. Telephoto lenses are better still...
2 upvotes
Esbutt
By Esbutt (Oct 18, 2011 at 16:34:24 GMT)
Isn't it worrying that Canon is still using the same basic sensor technology and data readout that it was using 10 years ago?!?
0 upvotes
frenchmonkeys
By frenchmonkeys (Oct 18, 2011 at 19:59:06 GMT)
No. Look at the images produced.
1 upvote
Henry M. Hertz
By Henry M. Hertz (Oct 18, 2011 at 23:32:32 GMT)
isn´t it worrying that 98% of all cars still use a otto motor and that you still need electricity for a lightbulb after more then 100 years?
7 upvotes
Total comments: 289
12
