Sony FE 35mm F1.4 ZA teardown
1 2 3 4 5 6
We've already looked at Roger Cicala's teardown of the Canon EF 35mm F1.4L II, where he showed it to be a heavy duty design with extensive adjustability to bring it back to spec after a period of abuse. LensRental's look inside the Sony FE 35mm F1.4 turned up a lens designed with a radically different approach. It's easy to over-interpret the differences and start trying to picture the different use-cases they've been designed for, but even if you don't want to extrapolate so far, it's fascinating to see how unconventional Sony's approach is.
