Sigma has today announced two tele-converter lenses the APO tele converter 1.4x EX DG and APO tele converter 2x EX DG. The tele converters are mounted between the camera body and the lens to increase the focal length by 1.4x or 2x. Both have a multi-layer lens coating to reduce flare and ghosting, won't compromise the quality of the other lens in use and high speed auto focus is retained when the converters are used.
Press Release:
APO TELE CONVERTER 1.4x EX DG
APO TELE CONVERTER 2x EX DG
Digitally optimized tele-converters, exclusive to Sigma’s telephoto and telephoto zoom lenses.
  • New multi layer lens coating and lens design reduce flare and ghosting.
  • The high image quality of the master lens will not be compromised thanks to this new design concept.
  • High-speed Auto Focus is retained even when these tele-converters are utilized.
The Sigma Corporation is pleased to announce the launch of the new APO TELE CONVERTER 1.4x EX DG and APO TELE CONVERTER 2x EX DG
These dedicated APO tele-converters are mounted between specific lenses and the camera body to increase the focal length by the power of 1.4 or 2.
These digitally optimized tele-converters employ the latest lens coating technology to reduce both flare and ghosting. A combination of these dedicated tele-converters and specific DG lenses ensure the best possible performance. The new special design maintains the master lens’ high-level of performance while extending its focal length.
Compact and lightweight, these tele-converters are a convenient way of converting lenses into longer focal-length lenses, therefore ensuring that those unexpected opportunities are not missed.
The specifications (Based on Sigma Mount)
Lens Construction: 3 Groups - 5 Elements
Focal Length: 1.4 times of master lens
Aperture Range: F2.8-32
Magnification: 1.4 times of master lens
Dimensions: φ 68.5mm×19.5mm
Weight: 160g
Lens Construction: 5 Groups - 6 Elements
Focal Length: 2 times of master lens
Magnification: 2 times of master lens
Dimensions: φ 68.5mm×52mm
Weight: 235g
