Fujifilm has officially announced the Fujinon XF 55-200mm F3.5-F4.8 R LM OIS telephoto zoom for its X system of mirrorless cameras. Headline features include optical image stabilisation with a claimed 4.5 stops benefit, dual linear stepper motors for focusing, all-metal barrel construction, and premium optics. The lens also features an aperture ring like that on the company's XF 18-55mm zoom. Fujifilm has also updated its roadmap of upcoming lenses to include the XF 56mm F1.2 R, which is half a stop faster than previously projected, and scheduled for release in January 2014. Finally the company is promising firmware updates to improve the autofocus speed of both the X-Pro1 and X-E1, which will be available to download in July.
Jump to:
Press Release:
Fujifilm announces the latest addition to the highly acclaimed series of XF lenses – the XF55-200mm telephoto lens and updated XF lens roadmap
New updated firmware for Fujifilm X-Pro1 and X-E1 will increase auto focus performance
Valhalla, N.Y., April 17, 2013 – FUJIFILM North America Corporation today announced the launch of the FUJINON XF55-200mm (83-300mm*1) F3.5-F4.8 R LM OIS, the first XF telephoto zoom lens for the X-Series Interchangeable Lens Digital Camera System that includes the award-winning FUJIFILM X-Pro1 and FUJIFILM X-E1. The all new XF55mm-200mm (83-300mm) F3.5-F4.8 gives photographers a fast aperture across the entire zoom range and outstanding image stabilization for sharp, high resolution images.
“We know that adding this newly designed, advanced telephoto zoom lens to our XF lens line-up will allow photographers who are using our premium X-Pro1 and X-E1 cameras to gain even more shooting flexibility, and also have cutting edge optical technology at their fingertips that enhances the way they capture images,” said Go Miyazaki, president and chief operating officer, FUJIFILM North America Corporation.
The all new FUJINON XF55-200mm lens gives users a fast F3.5-4.8 lens that produces
sharp images across its entire zoom range, from edge-to-edge.  Its image stabilization function enables the use of shutter speeds up to 4.5 stops slower, preventing camera shake even when shooting hand-held in low-light situations, or when shooting at a stopped down aperture.
The XF55-200mm lens includes two linear motors for high-speed AF of 0.28 seconds*2 to quickly focus on your subject. Together with its high quality metal design, the XF55-200mm lens  delivers an easy-to-transport lens with a large maximum aperture for outstanding mobility and performance.
The FUJINON XF55-200mm (83-300mm*1) F3.5-F4.8 R LM OIS lens features:
  • An advanced optical design to cover the mid-telephoto (83mm) to telephoto (300mm)
  • Image stabilization for shutter speeds up to 4.5 stops slower
  • Two linear motors for high-speed AF and quiet operation
  • Two ED lens elements and one Super ED lens element for increased performance and effective control against chromatic aberrations
  • FUJINON's proprietary HT-EBC coating on the entire lens surface to effectively prevent reflections, and control flare and ghosting
  • Minimum focal distance of 1.1m across the entire zoom range to enable telephoto close-ups
  • A 1/3EV step aperture ring for users to easily adjust the aperture while holding the camera up to their eye
  • High quality, metal construction focus ring and aperture ring
New Firmware for FUJIFILM X-Pro1 and FUJIFILM X-E1
New firmware will also be released to improve auto focus performance for the FUJIFILM X-Pro1 and FUJIFILM X-E1*3. The new firmware maximizes the benefit of the XF lenses and enables the cameras to search the contrast AF quickly throughout the full range of focal length. The focus speed will be as fast as 0.7 seconds even if it searches from infinity to MOD at the telephoto end.
The new firmware*3 will be available in July 2013 for download at Fujifilm.com.
Updated FUJINON XF Lens Roadmap
Fujifilm is committed to the entire X-Series line of advanced digital cameras and FUJINON XF lens, and is issuing an updated XF lens roadmap following the initial XF lens roadmap released in June 2012.
With 10 FUJINON XF lenses and the new three X-Mount lenses that Carl Zeiss announced in September 2012, there will soon be 13 high-performance lenses available for the X-Mount system to meet the needs of every photographer and support a wide range of photography from  ultra-wide-angle at 10-24mm(15-36mm*1) to super-telephoto of 55-200mm (83-300mm*1.)
End 2013
In late 2013, Fujifilm will deliver the pancake XF27mm (41mm*1) F2.8 high performance single focal length lens. Fujifilm will then launch the super wide zoom XF10mm-24mm (15-36mm*1) F4 lens with optical image stabilization and the single focal length XF23mm (35mm*1) F1.4 lens.
Early 2014
In early 2014, FUJINON will launch its premier prime portrait lens, the XF56mm (84mm*1) F1.2R.
For information about the Carl Zeiss X-mount lenses, please visit http://lenses.zeiss.com.
*1 35mm format equivalent
*2 based on CIPA standards
*3 It will be necessary to update the firmware on all XF lenses except the XF55-200mmF3.5-4.8 R LM OIS. The lens firmware will be available from July 2013.
*4 Images are not of the final product.
*5 Road map is as of April 17, 2013. Specifications are subject to change.
Fujifilm XF 55-200mm F3.5-4.8 R LM OIS specifications
Principal specifications
Lens typeZoom lens
Max Format sizeAPS-C / DX
Focal length55–200 mm
Image stabilisationYes (4.5 stops claimed)
Lens mountFujifilm X
Aperture
Maximum apertureF3.5 - F4.8
Minimum apertureF22.0
Aperture ringYes
Number of diaphragm blades7
Aperture notesrounded diaphragm
Optics
Elements14
Groups10
Special elements / coatingsTwo ED glass elements, one Super ED glass element
Focus
Minimum focus1.10 m (43.31)
Maximum magnification0.18×
AutofocusYes
Motor typeStepper motor
Full time manualYes
Focus methodInternal
Distance scaleNo
DoF scaleNo
Physical
Weight580 g (1.28 lb)
Diameter75 mm (2.95)
Length118 mm (4.65)
MaterialsMetal barrel, metal mount
Zoom methodRotary (extending)
Power zoomNo
Zoom lockNo
Filter thread62.0 mm
Filter notesDoes not rotate on focusing
Hood suppliedYes
