Sony has announced the NEX-3N, its entry-level NEX camera, replacing the NEX-F3. The 3N is, as before, aimed at users stepping up from compact cameras and gains a compact-style zoom lever around its shutter button. It features a smaller body than the F3, and Sony says it is the smallest, lightest mirrorless camera to feature an APS-C sensor, despite featuring a built-in flash. The camera will be bundled with the e-mount 16-50mm F3.5-5.6 power zoom lens, to make the most of the camera's zoom control.
Jump to:
Press Release:
Super-compact interchangeable lens APS-C camera weighs just 210g
  • No-fuss self-portraits with 180° tiltable LCD screen and zoom lever
  • Large Exmor APS HD CMOS sensor with 16.1 effective megapixels and high sensitivity, for detail-packed, low noise photos and Full HD video
  • Beautiful compositions made easy with new Auto Object Framing
  • Light, compact body with pop-up flash
Moving up from your fixed lens camera? Travel light with the compact, easy to use NEX-3N E-mount camera with built-in flash – an exciting introduction to the world of interchangeable lens photography by Sony.
Self-portraits have never been simpler with the NEX-3N, thanks to the camera’s easy-to-hold textured grip that fits reassuringly in the hand. The crisp, bright 7.5cm (3.0-type) LCD screen instantly flips through 180 degrees for fuss-free arm’s-length compositions. What’s more, a newly-added zoom lever on the camera body allows smooth, fingertip control of focal length with compatible lenses like the slim, light SELP1650 power zoom. Great for one-handed portrait framing, the zoom lever also adjusts digital zoom if you’re not using a powered lens.
All serious photographers know that great photos start with a great composition. Brand new Auto Object Framing helps you get better-looking, more professional results without effort. The camera judges what’s in the scene – one person, two people or even macro and moving objects – automatically cropping the shot to create more powerful, professionally-framed compositions.
Weighing approximately 210g, the NEX-3N is the world’s smallest, lightest interchangeable-lens camera with a large APS-C sized sensor*. Grabbing more light than the sensor in ordinary compact cameras, it’s the big sensor that’s key to exquisitely detailed photos and sparkling Full HD movies that stand out from the crowd. What’s more, it’s easy to create pro-style background blur effects with your collection of interchangeable E-mount lenses… just like you’d achieve with a bigger, bulkier DSLR camera.
The camera’s large sensor also boosts maximum sensitivity to ISO 16000. It’s complemented by an evolved BIONZ processor that uses the same area-specific noise reduction techniques featured on the acclaimed full-frame α99. Levels of noise reduction and sharpness are individually adjusted for different image areas. Even if you’re shooting in dim light, you’ll enjoy crisp, ultra-low noise handheld shots without needing flash.
The NEX-3N is also the first NEX interchangeable lens camera from Sony that offers support for new “TRILUMINOS Colour”. You’ll experience a dramatically expanded palette of vivid, ultra-realistic colours when videos and still images are played back on any BRAVIA TV with support for “TRILUMINOS Display”.
There’s now a range of thirteen high-quality E-mount lenses to realise the immense creative potential of the NEX-3N. Choose from telephoto, zoom, wide angle, macro lenses by Sony and Carl Zeiss to suit any shooting situation. Every model blends superb optical performance with elegant looks to complement your E-mount camera. There’s also a full range of coordinating accessories by Sony, from style-matching carry cases and straps to spare batteries.
The light, compact new NEX-3N interchangeable lens camera from Sony is available in Europe from March 2013.
* Among interchangeable-lens cameras with an APS-C sensor and pop-up flash, as of Feb 2013.
Sony Alpha NEX-3N specifications
Body type
Body typeRangefinder-style mirrorless
Max resolution4912 x 3264
Other resolutions4912 x 2760, 3568 x 2368, 3568 x 2000, 2448 x 1624, 2448 x 1376
Image ratio w:h3:2, 16:9
Effective pixels16 megapixels
Sensor photo detectors17 megapixels
Sensor sizeAPS-C (23.5 x 15.6 mm)
Sensor typeCMOS
Color spacesRGB, AdobeRGB
ISOAuto, 200, 400, 800, 1600, 3200, 6400, 12800, 16000
White balance presets6
Custom white balanceYes (2500-9900k )
Image stabilizationUnknown
Uncompressed formatRAW
JPEG quality levelsFine, Standard
File format
  • JPEG
  • RAW (ARW 2.2 Format)
Optics & Focus
  • Contrast Detect (sensor)
  • Multi-area
  • Selective single-point
  • Single
  • Continuous
  • Live View
Digital zoomNo
Number of focus points25
Lens mountSony E (NEX)
Focal length multiplier1.5×
Screen / viewfinder
Articulated LCDTilting
Screen size3
Screen dots460,000
Touch screenNo
Live viewYes
Viewfinder typeNone
Photography features
Built-in flashYes (Pop-up)
External flashNo (Accessory Port)
Continuous drive4.0 fps
WB BracketingNo
Videography features
Resolutions1920 x 1080
Storage typesSD/ SDHC/SDXC, Memory Stick Pro Duo/ Pro-HG Duo
USB USB 2.0 (480 Mbit/sec)
HDMIYes (Type D)
Environmentally sealedNo
BatteryBattery Pack
Battery descriptionLithium-Ion NP-FW50 rechargeable battery & USB charger
Battery Life (CIPA)480
Weight (inc. batteries)269 g (0.59 lb / 9.49 oz)
Dimensions110 x 62 x 35 mm (4.33 x 2.44 x 1.38)
Other features
Orientation sensorYes
Additional Images
