Panasonic has announced the Lumix DMC-GX7 - the follow-up to the DMC-GX1 - which is its first mirrorless interchangeable lens camera to include in-body image stabilization. This 16MP, rangefinder-style camera also includes a high-resolution, widescreen EVF that can be tilted upwards 90 degrees. Panasonic claims that their newly designed Live MOS sensor improves both detail and color saturation by 10%. Other features of note include a tilting LCD, a 'silent shooting' mode, focus peaking, 1080/60p videos, and Wi-Fi with NFC capability.
We've had a chance to handle the camera and have prepared some first impressions of what appears to be Panasonic's most serious attempt at an enthusiast's mirrorless camera yet:
Jump to:
Press Release:
Change your Perspective with the New LUMIX DMC-GX7 DSLM (Digital Single Lens Mirrorless)
A Premium Flat Body Camera with a Host of Creative Functions for Photo Enthusiasts and Artisans
NEWARK, NJ (August 1, 2013) - Panasonic is pleased to announce a new addition of LUMIX G Digital Single Lens Mirrorless (DSLM) Camera, the DMC-GX7, featuring high photographic performance and a sleek design which incorporates a tiltable LVF (Live View Finder).
Dressed in magnesium alloy full diecast frame in black and silver the new LUMIX GX7 allows photographers to change their viewing perspective with a newly integrated 90-degree tiltable LVF. The new LVF features 2764K-dot high resolution and 100% color reproduction based on a Field Sequential Color Accuracy method**. This 16:9 Wide Screen LVF boasts approx.1.39x / 0.7x (35mm camera equiv.) magnification and 100% field of view. The tiltable LVF offers extraordinary angle of view with unique shooting style – looking down into the viewfinder to level the camera straight on the subject. It comes with an Eye Sensor that automatically turns ON/OFF according to the photographer’s action. The Eye Sensor AF (Auto Focus) automatically begins to focus when a user looks into the LVF, so no shooting opportunity is missed. An Eye Cup, DMW-EC1GU, made of elastic material is sold separately to enhance comfort in viewing either with the naked eye or glasses.
The LUMIX GX7 is a new breed of digital camera suitable for the Hybrid Photographer. It’s capable of recording full HD 1920 x 1080, 60p (60 Hz) / 50p (50 Hz) smooth, high quality video recording in AVCHD Progressive and MP4 with stereo sound. The practical full-time AF and tracking AF is also available in video recording mode. The cinema-like 24p video with the bit rate of max. 24Mbps or P/A/S/M mode provides richly expressive afterimage with exquisite image quality.  The Digital Live MOS Sensor greatly improves motion picture quality.
The LUMIX GX7 incorporates Creative Panorama, Time Lapse Shot, Stop Motion Animation or Clear Retouch in addition to the popular Creative Control mode with a total of 22 fascinating filter effects
A new in-body Image Stabilizer is nearly as effective as the MEGA O.I.S. found in Panasonic’s conventional DSLM lenses, which makes it easier to take clear photos with mounted non-stabilized and classic lenses. The LUMIX GX7 is also compatible with Focus Peaking for more precise control of focusing. In Silent Mode, the camera switches the shutter from mechanical to electronic and turns all sound (AF operation) off while suppressing emission of AF assist lamp and flash with just a single setting for special shooting occasions. Furthermore, the LUMIX GX7 allows photographers to use a max. 1/8000 shutter speed for more impressive expression with high speed lens options.
Panasonic developed a new 16.00-megapixel Digital Live MOS Sensor for LUMIX GX7 that achieves both high resolution and high sensitivity image recording with minimum noise by utilizing cutting-edge Semiconductor Fine Technology to improve color saturation by approx. 10% and a redesigned on-chip lens that enhances light condensation to achieve approx. 10% higher sensitivity. Noise generation is minimized in both pixel circuit and digital signal readout circuit for better S/N ratio by approx. 25% and detail reproduction by approx.10% compared to the LUMIX DMC-GX1, making it possible to capture clear images even in low lit situations.  The image processor Venus Engine features advanced noise reduction systems, including Multi-process NR (Noise Reduction) and Detail Reproduction Filter Process, which enhances the limit resolution. The combination of the digital Live MOS Sensor and the Venus Engine achieves max. ISO 25,600.
The Contrast AF System of the LUMIX GX7 excels in both speed and accuracy by exchanging digital signals between the camera and the lens at max. 240 fps. A variety of extensive AF functions including Low Light AF (-4EV), Pin-point AF and One-shot AF enhances usability to comply with a wide-range of shooting situations. In Pinpoint AF, picture-in-picture display is available and the magnification ratio of in-frame picture is selectable from 3x to 6x. The One Shot AF function can be allocated to the AF/AE Lock Button (AF/MF Switch Lever) for more flexible control over focusing.
The LUMIX GX7 incorporates high speed response desired for the digital single lens mirrorless camera, taking only approx. 0.5 sec* to get ready to shoot after startup. The LUMIX GX7 also realizes the high speed burst shooting at 5 fps and max. 40 fps using an electronic shutter. Also, AF Tracking enables consecutive shooting to capture moving subject in sharp focus at 4.3 fps.
At the same time, Panasonic designed ease of operation into the LUMIX GX7. Two separate dials on front and back offer direct control over aperture, shutter speed or exposure, which achieves smooth manual shooting. The Live View function is also digitally advanced, making it possible to adjust highlight / shadow separately with the front/rear dial. Three patterns of settings can be customized in addition to three patterns of presets. In addition, the Fn (Function) tab is newly integrated into the menu, which means a total of nine functions can be assigned (five in tab and four with the button).
The LUMIX GX7 integrates Wi-Fi® connectivity (IEEE 802.11 b/g/n) with NFC (Near Field Communication) technology to offer a more flexible shooting experience and seamless instant image sharing. All of these flexible shooting, browsing, and sharing styles are made possible with the LUMIX GX7 and Panasonic's dedicated application software and the Panasonic Image App for iOS / Android smartphones/tablets.
DMC-GX7KS (with lens) = http://shop.panasonic.com/shop/model/DMC-GX7KS
DMC-GX7SBODY (no lens) = http://shop.panasonic.com/shop/model/DMC-GX7SBODY
* With H-FS1442A, based on the CIPA standard.
**Based on Adobe RGB color space, Panasonic in-house comparison based on the CIE 1931 x, y color space.
Panasonic Lumix DMC-GX7 specifications
Price
MSRP$999 (body only), $1099 (with 14-42 lens)
Body type
Body typeRangefinder-style mirrorless
Body materialMagnesium Alloy
Sensor
Max resolution4592 x 3448
Other resolutions4592 x 3064, 4592 x 3064, 4592 x 2584, 3424 x 3424, 3232 x 2424, 3232 x 2160, 3232 x 1824, 2416 x 2416, 2272 x 1704, 2272 x 1520, 1920 x 1080, 1712 x 1712
Image ratio w:h1:1, 4:3, 3:2, 16:9
Effective pixels16 megapixels
Sensor photo detectors17 megapixels
Sensor sizeFour Thirds (17.3 x 13 mm)
Sensor typeCMOS
ProcessorVenus Engine
Color spacesRGB, Adobe RGB
Color filter arrayPrimary color filter
ISOAuto, 125, 200, 400, 800, 1600, 3200, 6400, 12800, 25600
Boosted ISO (minimum)125
White balance presets6
Custom white balanceYes (2)
Image stabilizationSensor-shift
Uncompressed formatRAW
JPEG quality levelsFine, Standard
File format
  • JPEG (DCF, EXIF 2.3), RAW, MPO
Optics & Focus
Autofocus
  • Contrast Detect (sensor)
  • Multi-area
  • Center
  • Selective single-point
  • Tracking
  • Single
  • Continuous
  • Touch
  • Face Detection
  • Live View
Autofocus assist lampYes
Digital zoomYes (2X, 4X)
Manual focusYes
Number of focus points23
Lens mountMicro Four Thirds
Focal length multiplier2×
Screen / viewfinder
Articulated LCDTilting
Screen size3
Screen dots1,040,000
Touch screenYes
Screen typeLCD
Live viewYes
Viewfinder typeElectronic
Viewfinder coverage100%
Viewfinder magnification1.39×
Viewfinder resolution2,764,800
Photography features
Minimum shutter speed60 sec
Maximum shutter speed1/8000 sec
Exposure modes
  • Program, Aperture Priority, Shutter Priority, Manual
Scene modes
  • Clear Portrait, Silky Skin, Backlit Softness, Clear in Backlight, Relaxing Tone, Sweet Child's Face, Distinct Scenery, Bright Blue Sky, Romantic Sunset Glow, Vivid Sunset Glow, Glistening Water, Clear Nightscape, Cool Night Sky, Warm Glowing Nightscape, Artistic Nightscape, Glittering Illuminations, Clear Night Portrait, Soft Image of a Flower, Appetizing Food, Cute Dessert, Freeze Animal Motion, Clear Sports Shot, Monochrome, Panorama
Built-in flashYes (Pop-up)
Flash range7.00 m (at ISO 200)
External flashYes (via hot-shoe)
Flash modesAuto, Auto & Red-eye reduction, Fill-in flash, Slow sync, Slow sync w/red-eye reduction, off
Flash X sync speed1/320 sec
Drive modes
  • Single
  • Burst
  • Auto Bracket
  • Self-timer
Continuous drive5.0 fps
Self-timerYes (2 or 10 secs, 10 secs w/ 3 shots)
Metering modes
  • Multi
  • Center-weighted
  • Spot
Exposure compensation±5 (at 1/3 EV steps)
AE Bracketing±3 (3, 5, 7 frames at 1/3 EV, 2/3 EV, 1 EV steps)
WB BracketingYes (3 exposures in blue/amber or magneta/green axis)
Videography features
Resolutions1920 x 1080 (60p, 60i, 50p, 50i, 30p, 24p), 1280 x 720 (60p, 30p), 640 x 480 (30p)
FormatMPEG-4, AVCHD
MicrophoneStereo
SpeakerMono
Storage
Storage typesSD/SDHC/SDXC card
Connectivity
USB USB 2.0 (480 Mbit/sec)
HDMIYes (miniHDMI)
WirelessBuilt-In
Wireless notes802.11b/g/n with NFC
Remote controlYes
Physical
Environmentally sealedNo
BatteryBattery Pack
Battery descriptionLithium-ion rechargeable
Battery Life (CIPA)350
Weight (inc. batteries)402 g (0.89 lb / 14.18 oz)
Dimensions123 x 71 x 55 mm (4.83 x 2.78 x 2.15)
Other features
Orientation sensorYes
GPSNone
Additional images
