Fujifilm has introduced the XF 27mm F2.8, a compact 'pancake' lens for its X-system cameras. It's just 23mm thick and weighs only 78g, making it by far the smallest X-mount lens. This means there's no space for an aperture ring, so X-Pro1 and X-E1 owners will need to update their firmware to allow aperture setting from the camera's rear control dial. It'll be available in either black or silver, at an MSRP of $449.95.
Jump to:
Press Release:
FUJIFILM expands the lineup of X Mount interchangeable lenses
FUJINON XF 27mm F2.8
A highly portable high-performance single focal length lens for casual shooting with quality results
FUJIFILM Corporation (President: Shigehiro Nakajima) is proud to announce the launch of the new "FUJINON XF27mmF2.8" lens for the FUJIFILM X-Pro1 and X-E1 compact system cameras.
FUJINON XF lenses are the pinnacle of Fujifilm's optical design technology, with top quality all-glass construction including aspherical lens elements. Their fast f-stop broadens users' scope of photographic expression for low-light photography and scenes with a beautiful bokeh effect. In addition, FUJINON's "HT-EBC Coating" reduces reflection at a wider range of wavelengths, thereby controlling ghosting. The lenses feature advanced lens engineering, capable of drawing the maximum performance out of the highly-descriptive "X-Trans CMOS Sensor" in the FUJIFILM X-Pro1 and X-E1 cameras.
The FUJINON XF27mmF2.8 is a compact and lightweight lens for excellent portability. It is a well-balanced, high-performance, single focal length lens, delivering great picture quality in a wide range of scenes including landscapes, snapshots and portraits.
High-performance lens that offers a field of view similar to that of the human eye, covering a wide range of scene types
The lens has a fixed focal length of 27mm (41mm in 35mm format equivalent), offering a field of view similar to that of the human eye, capturing each scene as precisely and naturally as you see it.  It includes a glass moulded aspheric element which reduces image distortion as much as possible.  You can explore different ideas dependent on the scene you’re shooting, e.g. using your own footwork to adjust the distance between yourself and your subject, or by changing the shooting angle, enabling you to enjoy a broad range of photography.
Lightweight and compact
Weighing 78g and measuring 23mm in length, this is one of the smallest and lightest single focal length lenses available for APS-sensor mirrorless cameras.  Its thin form factor keeps the camera compact when mounted, encouraging you to take your camera wherever you go.
Outstanding resolving power for sharp and clear images
The advanced optical design is coupled with FUJINON’s proprietory HT-EBC Coating that brings a large amount of light onto the camera sensor to draw the maximum performance out of the X-Trans sensor, thus achieving outstanding resolving power for sharp and clear images.
High-speed autofocus
The lens incorporates an autofocus design that uses a high-torque coreless DC motor to shift all of the front lens elements (5 elements in 4 groups) to achieve a fast AF speed.  The quick AF response is one of the fastest amongst single focal length lenses on APS-sensor mirrorless cameras.
Premium-quality focus ring
The high precision focus ring is made of metal, and requires delicate operation during manual focusing.  The materials and the design ensure a comfortable feel and exactly the right amount of torque when rotating the ring.
Bokeh effect for isolating a subject
The use of a seven-blade round diaphragm means your subject is isolated with beautiful bokeh in portraiture with a shallow depth of field, or for close-up photography of stunning dishes or small accessories.
Available in two colours
The 27mm lens will be available two different colours - both silver and black - to allow users to accessorise their X series cameras to their own taste.
[For FUJIFILM X-Pro1 and X-E1 customers]
The FUJINON XF27mmF2.8 lens does not feature an aperture ring in order to keep it compact and lightweight.  When using this lens, please update your camera body’s firmware to enable aperture adjustment via the camera’s command dial.
Fujifilm Global website: http://www.fujifilm.com/support/digital_cameras/
Fujifilm XF 27mm F2.8 specifications
Principal specifications
Lens typePrime lens
Max Format sizeAPS-C / DX
Focal length27 mm
Image stabilisationNo
Lens mountFujifilm X
Aperture
Maximum apertureF2.8
Minimum apertureF16
Aperture ringNo
Number of diaphragm blades7
Aperture notesRounded diaphragm
Optics
Elements7
Groups5
Special elements / coatings1 aspherical element
Focus
Minimum focus0.34 m (13.39)
Maximum magnification0.1×
AutofocusYes
Motor typeMicromotor
Full time manualYes
Distance scaleNo
DoF scaleNo
Physical
Weight78 g (0.17 lb)
Diameter61 mm (2.41)
Length23 mm (0.91)
MaterialsMetal barrel, metal mount
ColourBlack, Silver
Filter thread39.0 mm
Additional images
