Sigma has announced a new telephoto lens in the shape of the 170-500mm F5-6.3 APO DG. The lens features multi-layer coating, aspherical lenses, SLD glass and rear focus system. It is compatible with a number of digital SLRs with AF mounts, including Sigma, Canon, Nikon, Pentax and Konica Minolta. It will retail for £629.99 and includes a lens hood and removable tripod collar.
Press Release:
Sigma 170-500mm F5-6.3 DG lens
An ultra-telephoto zoom up to 500mm producing high performance with digital or film SLR cameras.
  • The new multi-layer lens coating and lens design reduces flare and ghosting.
  • Aspherical lenses and SLD glass provide correction for all types of aberration throughout the entire zoom range.
  • Rear focus system ensures fast auto focus.
The Sigma Corporation is pleased to announce the launch of the new 170-500mm F5-6.3 DG lens. This compact ultra telephoto zoom lens covers a useful range up to 500mm.
The new multi-layer lens coating and lens design reduces flare and ghosting, and creates an optimum color balance resulting in better picture quality through the entire zoom range on both film and digital SLRs.
This lens uses one aspherical lens and three SLD(Special Low Dispersion) glass elements for excellent correction of chromatic aberration, making high-quality images a reality throughout the entire zoom range.
Since the front of the lens does not rotate during focusing, a circular polarizing filter can easily be attached and used. A lens hood and removable tripod collar are included as standard components.
SPECIFICATIONS:
Focal Length: 170-500mm F5-6.3DG
Minimum Aperture: F32
Lens Construction: 13 Elements in 11 Groups
Angle of View: 14.5°- 5°
Number of Diaphragm Blades: 9pcs
Minimum Focusing Distance: 300-320cm (118.1-125.9”)
Maximum Magnification: 1:6.6
Filter Size: 86mm
Lens Hood: Bayonet Type Hood
Dimensions: Diameter 92.5mm (3.6”) x Length 232mm (9.1”)
Weight: 1345gr/47.4oz
SRP: £629.99
Available fittings: Sigma AF Canon AF Nikon AF Pentax AF Konica Minolta AF
* The appearance and specifications are subject to change without notice.
