Sony has confirmed it will be making a full-frame replacement for its flagship A900 DSLR. No further details were given during a round-table discussion at the CP+ show in Japan, but we find it hard to believe the result will step away from the SLT technology the company has invested so heavily in. The company has also finally announced the A-mount 500mm F4 lens that it has been showing in various states of preparedness since PMA 2007 will be available from late March.
No details of price are given but the premium 'G' branding and the fact it's a 500mm F4 are likely to make as substantial a dent in your wallet as the lens would make if you dropped it onto a particularly malleable surface.
Press Release:
Closer encounters with new 500mm super-telephoto:
Rugged, pro-focused SAL500F40G lens from Sony for A-mount SLT and DSLR cameras
  • Longest-ever focal length G Lens from Sony
  • Bright F4.0 aperture for superior light gathering
  • Nano AR Coating on optical surfaces for flawless still images and HD video
  • Compatible with SteadyShot INSIDE featured in all α cameras
  • New SSM drive circuit for quick, accurate autofocus
  • Rugged dust- and moisture-resistant design: ideal partner for SLT-A77
  • Enhanced handling and operability
Serious photographers can pull distant subjects closer with a powerful new 500mm (equivalent to 750mm with APS-C camera) super-telephoto lens from Sony.
The SAL500F40G is ideal for sports, wildlife and demanding imaging applications that require extreme magnification with uncompromised optical performance.
The SAL500F40G is the longest fixed focal length G Lens from Sony to date. Whether you’re shooting detail-packed stills or Full HD video, you’ll enjoy frame-filling close-ups with flawless resolution. With a bright F4.0 maximum aperture, its excellent light gathering power allows the use of faster shutter speeds to broaden shooting opportunities.
The ruggedly-engineered SAL500F40G copes effortlessly with tough photo assignments. Focusing ring and front/rear joints are protected by interlocking seals that shrug off dust and moisture, even when you’re shooting outdoors in driving rain or arid desert conditions. This weather-resistant design makes the SAL500F40G a perfect partner for the SLT-A77 (α77) Translucent Mirror camera that offers serious photographers similarly ruggedized performance.
Like all other A-mount lenses, the SAL500F40G is compatible with the SteadyShot INSIDE image stabilisation system that’s featured in every α Translucent Mirror and DSLR camera from Sony. Depending on shooting conditions, camera model and settings, you’ll enjoy camera-shake blur compensation that’s equivalent to approximately 4.5 stops (max.) in shutter speed.
Inside, the advanced optical design of the SAL500F40G includes 11 elements in 10 groups, including three ED (Extra-low Dispersion) glass elements. It’s also the first G Lens from Sony to feature advanced new coating process that ensures crisper, clearer images. Exclusive to Sony, the ground-breaking Nano AR Coating process cuts internal reflections drastically. Resulting images are brilliantly crisp and clear, with dramatically reduced lens flare and ghosting. Flare is reduced still further by the carbon fibre lens hood that’s lined with black velvet fibres to absorb incident light.
Razor-sharp autofocus performance makes the SAL500F40G ideal for capturing an athlete’s explosive movements or the unpredictable flutter of wild birds. The high-torque SSM (Super Sonic wave Motor) features a new drive circuit, ensures rapid, responsive AF with significantly faster object tracking than conventional Sony lenses.
Serious enthusiasts will also welcome a strong emphasis on enhanced handling and ergonomics. Four focus hold buttons are spaced around the lens barrel for easy operation in any position. They’re complemented by a two-way DMF (Direct Manual Focus) mode button and focus range switch for positive, fumble-free operation when you’re shooting under pressure.
Built to order, the SAL500F40G super-telephoto lens from Sony is available from late March 2012.
Technical specifications
500mm F4 G SSM
Min. aperture F32
No. of aperture blades 9 (Circular aperture)
Max. magnification ratio 0.135
Min. focus 4.0 m
Filter diameter 42 mm (Exclusive)
(Diam. X L)
140 x 367.5 mm
Weight (approx.) 3460 g
Teleconverter compatibility Yes (1.4x: AF and MF Mode, 2x: MF mode)
Dust and moisture resistance Yes
