Fujifilm has announced the X100S - a significantly enhanced replacement for its X100 large sensor, fixed-lens compact camera. The X100S retains its predecessor's classic styling but has been extensively re-worked inside, with a 16MP X-Trans sensor that includes on-chip phase-detection elements (a technology first utilized by Fujifilm), and a higher-resolution LCD in its Hybrid optical/electronic viewfinder. A faster 'EXR II' processor, along with the on-chip AF information help Fujifilm offer what it says is the world's fastest AF. The X100S backs-up its rangefinder-esque looks with a digital split-image manual focus system, allowing fast manual focusing. A great many fine details of the camera have also been enhanced - we look in greater detail in our hands-on preview article.
Jump to:
Press Release:
The FUJIFILM X100S: FUJIFILM launches a high-speed successor to the X100 with the world’s fastest AF of 0.08 seconds (*1)
Two years ago, FUJIFILM launched the prestigious X100 with a FUJINON 23mm f/2 fixed prime lens and superb image quality, in a beautifully designed compact camera body.  Its unique style and international acclaim has carved out a niche for a new genre of Premium Compact Camera, designed in pursuit of optimum operability. Today, FUJIFILM is proud to announce the launch of the FUJIFILM X100S, the successor to the FUJIFILM X100, inheriting its elegant design and high-performance lens, whilst evolving further to meet customers’ demands with the introduction of a higher-definition Hybrid Viewfinder and a new sensor and processor.
The X100S has the ability to capture high resolution images, comparable to those taken on full-frame sensors. This is down to a combination of its newly-developed 16.3 megapixel APS-C X-Trans CMOS II sensor and EXR Processor II, which together increase resolution by approx. 25% (*2) and reduce noise by more than 30% (*3). Clear images with minimal graininess, even at high ISO settings, can also be produced, thanks to the removal of the optical low pass filter and the introduction of a more powerful processor.
The newly-developed X-Trans CMOS II sensor has built-in Phase Detection pixels which provide the X100S with the world’s fastest AF in as little as 0.08 seconds (*1). Additionally, the EXR Processor II offers very speedy response times with a start-up time of approx. 0.5 seconds (*4), and a shooting interval of 0.5 seconds. Plus with its shutter time lag of only 0.01 seconds, it allows you to react quickly and capture each precise moment you want to with no missed photo opportunities.
Also new to the FUJIFILM X100S is the world’s first (*5) “Digital Split Image” feature, which displays dual images on the left and right to be lined up for manual focusing. This enables accurate focusing especially when working with an open aperture or macro shooting. What’s more there is a handy Focus Peak Highlight function, which shows you precisely which area of your composition is in focus.
Depending on the subject and scene, users can switch between two viewfinder options: optical or electronic. The Optical Viewfinder (OVF) is useful when users want to see their subject in the same bright clarity that they see with the naked eye, or when time lag is an issue. The high resolution 2.36 million dot electronic viewfinder (EVF) is useful when you want to be able to visually check focus, exposure, white balance and depth of field whilst composing the shot.
Main Features
(1) Sensor performance comparable to full-frame output
The X100S features FUJIFILM’s newly-developed 16.3 megapixel APS-C X-Trans CMOS II sensor with a unique, highly randomised, colour filter arrangement. The benefit of the new array is the elimination of the need for an optical low-pass filter; these are used in conventional sensors to reduce false colour and moiré effects but they also reduce image resolution. The removal of the optical low-pass filter allows the X-Trans CMOS II sensor to maximise the light it receives directly, enabling users to capture much finer detail and optimise resolution levels.
The X100S uses a Lens Modulation Optimiser to reduce optical effects such as lens diffraction, which occurs when light passes through a lens. Even when stopped down to f/16, the X100S retains sharpness and texture in the smallest details, demonstrating the extent of the sensor and lens combination’s capabilities, perfectly.
The excellent sensitivity of the X-Trans CMOS II sensor is coupled with the new EXR Processor II’s advanced signal processing capacity, which can reduce noise by more than  30% (*2) compared to its predecessor.  Even when shooting in low-light, at a high ISO setting, the FUJIFILM X100S will produce crisp images with minimal grain.
(2) The World’s fastest Auto Focus and High-speed EXR Processing
With built-in Phase Detection, the X100S offers the world’s fastest AF speed of just 0.08 seconds(*1).  The Intelligent Hybrid AF can switch to Contrast AF, dependent on the demands of the subject or scene, to ensure that the camera always auto-focuses quickly and with precision.
The EXR Processor II delivers processing speeds twice that of FUJIFILM’s previous generation processor (*6).  The fast responses result in an impressive start-up time of approx. 0.5 seconds (*4), and a shooting interval of 0.5 seconds. In addition the X100S delivers a burst shooting rate of up to 6 frames per second (max. 29 frames) at the full resolution of 16.3 megapixels and the shutter time lag is a mere 0.01 seconds.
(3) Enhanced manual focus performance with the world’s first (*5) ‘Digital Split Image’ display
Making use of the built-in phase detection pixels for AF action, the X100S is the world’s first (*5) camera to offer a “Digital Split Image” feature, which displays dual images on the left and right to be lined up for manual focusing.  This enables accurate focusing especially when working with an open aperture or macro shooting.
In addition, the X100S offers a handy Focus Peak Highlight function, which highlights high contrast areas of your subject.  It provides the photographer with a guide, even in situations where it is difficult to calculate focusing accuracy, allowing users to enjoy manual focusing comfortably, however challenging the conditions.
(4) Premium Hybrid Viewfinder for easy image composition
Offering users freedom when composing photos and adaptability for a range of shooting conditions, the X100S’s Hybrid Viewfinder combines both an Optical and an Electronic Viewfinder.
The electronic viewfinder uses a 100% coverage, extra high resolution, 2,360K-dot High Definition LCD panel.  It shows depth-of-field during macro shooting, as well as white balance settings, allowing users to accurately compose their shot while continuously looking through the viewfinder.
The premium quality optical viewfinder offers an easy-to-see magnification of 0.5 at a 23mm focal length and a horizontal apparent field of view of 26 degrees.  The all-glass construction uses high-refractive index glass to minimise chromatic aberrations and distortion.
While in the optical viewfinder mode, users can make adjustments to shutter speed, aperture, ISO and other settings without having to take their eye off the viewfinder.  The shooting frame (Bright Frame) and text brightness automatically adjust according to the ambient light available, to ensure that the information on the display is easy to see at all times.
The system features an OVF Power Save mode, which activates the power-saving function in the optical viewfinder mode to double the maximum number of images per full charge from 300 (*7) in normal operation.
With FUJINON’s proprietary coating, the viewfinder cleverly resists fingerprints and can easily be wiped clean, so that users can enjoy the optical viewfinder’s clear display without compromise.
(5) FUJINON 23mm f/2 lens offering premium image quality in a compact body
Specifically designed for this model, the FUJINON 23mm f/2 Single Focal Length Lens has a fixed angle of incidence of light into the lens, which facilitates optimum optical design. Taking full advantage of this, the X100S demonstrates advanced levels of image clarity, not only in the centre of the image, but also through to the edges of the photo. The versatile focal length of 35mm (*8) delivers an angle of view ideal for a diverse range of subjects and scenes.
The lens consists of 8 elements in 6 groups, and includes a high-performance double-sided aspherical element and highly-refractive converging glass elements, which deliver a high level of detailed performance with minimal aberration, excellent sharpness and beautiful colour reproduction.  Moreover, FUJINON's proprietary HT-EBC coating is applied to effectively control image flares and ghosting.
Other benefits of this lens are the beautiful, soft, round-shaped Bokeh that is produced from the 9 blade lens diaphragm. In addition the lens allows you to get as close as 10cm from your subject in macro mode for stunning close-up shots. And its built-in 3-stop ND filter enables blurring of the background in portraits, or applies a gorgeous creamy look to flowing water even in a bright setting.
(6) Elegant design and sophisticated functionality
The front of the X100S proudly bares the letter “S” as confirmation of its extensive evolution from the FUJIFILM X100. Down to the tiniest detail, the premium build and feel of the X100 is continued in the X100S. FUJIFILM’s top quality Japanese engineering is evident from the high precision components used and the perfectly optimised body.
The X100S’s top and base parts are made of magnesium alloy to achieve a lightweight, resilient, yet delicate design. A specially-formulated coating is applied to give its surface a steel look for an added premium feel.  All the dials and rings have been milled from solid metal, with attention paid to the finer details such as finger grips and enhanced operability. The exterior is finished with synthetic leather, which is durable and resilient to the environment yet reproduces the texture of real leather, while still offering the practical benefits of additional grip and comfort.
The layout of the dials and rings allow users to operate the aperture ring on the lens with their left hand, and the shutter speed dial and exposure compensation dial on the top panel with their right hand, meaning all the settings can be adjusted comfortably without having to take your eye off the viewfinder. And to make you feel even more at home, you can even customise your shutter sound by choosing between the four different sounds available:  Lens Shutter, Focal Plane Shutter, Mirror Up and Silent Shutter.
The menu system has been also updated to incorporate a Q “Quick” button which allows you to quickly call up frequently-used menu items such as ISO setting and Film Simulation modes. In addition, the Fn (Function) button allows users to assign functions frequently used while shooting, for convenient use at the touch of a button.
(7) Artistic photography
The X100S features FUJIFILM's proprietary 'Film Simulation Modes'. Users can choose from ten simulation options which replicate the results achieved by FUJIFILM colour reversal films (Velvia / PROVIA / ASTIA), professional colour negative films (PRO Neg. Std / PRO Neg. Hi), monochrome filters (MONOCHROME, Ye filter, R filter and G filter) and SEPIA.
Also available on the X100S is the Advanced Filter function; users can choose from 8 different artistic effects which can be previewed on the LCD screen:
Pop Colour - great for boosting contrast and colour saturation
Toy Camera - create shaded borders as if you were taking a photo on a toy camera
Miniature - adds top and bottom blur for a diorama or miniature effect
Dynamic Tone - create a fantasy effect by dynamically-modulated tonal reproduction
Partial Colour – highlights one colour and leaves the rest of the image in black and white (choose from red, orange, yellow, green, blue or purple)
High Key - enhances brightness and reduces contrast to lighten tonal reproduction
Low Key – create uniformly dark tones with few areas of emphasised highlights.
Soft Focus – blurs the focus of the image edges to create a softer effect
In addition a Multiple Exposure function enables users to combine two separate images together for special creative effects. And for greater artistic freedom, the aspect ratio can be selected from 3:2, 16:9, and 1:1 (square) to accommodate a wide range of photographic styles.
(8) Full HD Video Shooting
The X100S can shoot at 60fps during Full HD video recording (1920 x 1080) for very smooth video capture. Plus shooting at the high bit-rate of 36Mbps will result in reduced noise and enhanced image quality that reveals every detail, from individual leaves in the trees, to subtle changes in facial expression. During video recording, users have access to many of the additional modes available in still image capture. Film Simulation modes can be used, White Balance settings can be adjusted, you can even make the most of the fast lens to produce beautiful bokeh and also operate the Intelligent Hybrid AF for high-speed and high-precision focusing.
(9) FUJIFILM X100S Key features list:
  • 16.3 megapixel APS-C X-Trans CMOS II sensor
  • EXR Processor II
  • High Definition Hybrid Viewfinder (OVF / EVF)
  • FUJINON 23mm f/2 lens
  • Intelligent Hybrid AF (with the world’s fastest AF speed of 0.08 secs (*1))
  • Start-up time of 0.5 secs (*4)
  • Shutter time lag of 0.01 secs
  • Shooting interval of 0.5 secs
  • High-contrast and wide viewing-angle 2.8-inch Premium Clear LCD (460K dots)
  • Super Intelligent Flash
  • Burst shooting rate of up to 6 frames per second at full resolution (max. 29 frames)
  • Focus Peak Highlight function
  • Digital Split Image display
  • Artistic filters
  • Full HD movie recording (60fps / 30fps)
(10) Premium Accessories available for the FUJIFILM X100S
  • Wide conversion lens WCL-X100 - designed specifically for X100 and X100S, shortens the lens’ focal length from 35mm (*8) to 28mm (*8).  It offers a broader field of view while maintaining the powerful performance equivalent to that of the main body’s lens
  • Premium Leather case LC-X100S - Users can remove / insert a memory card and battery without having to take this case off.  This is a practical ‘Quick Shot’ case, made of premium genuine leather
  • Shoe Mount Flash - Three types of Fujifilm external flashes are available, capable of the proprietary high-precision TTL auto flash control:  EF-20 and EF-X20 with the guide number 20, and EF-42 with the guide number 42
External stereo microphone MIC-ST1 - For recording real sound with impact to go with premium-quality images and full-HD movie
*1 Fujifilm research as of November 2012. Compared with other compact digital cameras equipped with an APS-C sensor and a non-interchangeable lens based on CIPA standards and conducted in High Performance mode.
*2 Fujifilm research. Compared with X100 and conducted in f/16.
*3 Compared with FUJIFILM X100
*4 High Performance mode
*5 Fujifilm research as of November 2012
*6 Compared with the EXR Processor Pro.
*7 Maximum shots from a fully charged NP-95 lithium battery pack, based on the CIPA test standard.
*8 35mm format equivalent
Fujifilm X100S specifications
Body type
Body typeLarge sensor compact
Sensor
Max resolution4896 x 3264
Other resolutions4896x2760,264 × 3264, 3456x2304, 3456x1944, 2304 × 230, 2496x1664, 2496x1408 , 1664 × 1664
Image ratio w:h1:1, 3:2, 16:9
Effective pixels16 megapixels
Sensor sizeAPS-C (23.6 x 15.8 mm)
Sensor typeCMOS
ProcessorEXR II
ISOAuto (ISO 200 - 6400), ISO 100, 12800 and 25600 with boost
Boosted ISO (maximum)25600
White balance presets7
Custom white balanceYes
Image stabilizationNo
Uncompressed formatRAW
JPEG quality levelsFine, Normal
File format
  • JPEG (Exif 2.3),
  • RAW (RAF format)
  • RAW+JPEG
Optics & Focus
Focal length (equiv.)35 mm
Optical zoom1×
Maximum apertureF2
Autofocus
  • Multi-area
  • Single
  • Continuous
  • Live View
Digital zoomNo
Manual focusYes
Normal focus range21 cm (8.27)
Macro focus range10 cm (3.94)
Number of focus points49
Screen / viewfinder
Articulated LCDFixed
Screen size2.8
Screen dots460,000
Touch screenNo
Screen typeTFT color LCD monitor
Live viewYes
Viewfinder typeElectronic and Optical (tunnel)
Viewfinder coverage90%
Viewfinder magnification0.5×
Viewfinder resolution2,350,000
Photography features
Minimum shutter speed30 sec
Maximum shutter speed1/4000 sec
Exposure modes
  • Program AE
  • Shutter priority
  • Aperture priority
  • Manual exposure
Built-in flashYes
Flash range9.00 m
External flashYes (hot-shoe)
Flash modesAuto, On, Off, Red-Eye, Slow Sync
Continuous drive6.0 fps
Self-timerYes (2 or 10 sec)
Metering modes
  • Multi
  • Average
  • Spot
Exposure compensation±2 (at 1/3 EV steps)
AE Bracketing (at 1/3 EV, 2/3 EV, 1 EV steps)
WB BracketingNo
Videography features
Resolutions1920 x 1080 (60, 30fps)
FormatH.264
MicrophoneStereo
SpeakerMono
Storage
Storage typesSD/SDHC/SDXC
Connectivity
USB USB 2.0 (480 Mbit/sec)
HDMIYes (Mini connector)
WirelessEye-Fi Connected
Remote controlYes
Physical
Environmentally sealedNo
BatteryBattery Pack
Battery descriptionLithium-Ion NP-95 rechargeable battery & charger
Battery Life (CIPA)330
Weight (inc. batteries)445 g (0.98 lb / 15.70 oz)
Dimensions127 x 74 x 54 mm (5 x 2.91 x 2.13)
Other features
Orientation sensorYes
Timelapse recordingNo
GPSNone
Additional images
