Olympus has finally announced the long-rumored E-M5, the first of its OM-D range of Micro Four Thirds cameras. The E-M5 is built around a 16MP sensor and features the company's latest 5-axis image stabilization system that works for both stills and movies. It can shoot 1080i60 movies in MOV format (h.264 compression) and includes a 1.44M dot EVF in its weather-sealed magnesium alloy body.
It will cost around $1299.99 / £1149.99 / €1299.99 with the weather-sealed 12-50mm F3.5-6.3 power zoom lens and will be available from April 2012.
Jump to:
Press Release:
Olympus OM-D (E-M5)
The Olympus E-M5 Unites an Intuitive Built-In Electronic Viewfinder with the World’s First*1 5-Axis Image Stabilization and World’s Fastest*2 Autofocusing System inside a Powerfully Portable and Rugged Dustproof and Splashproof Body
CENTER VALLEY, Pa., February 7, 2012, 9:00pm – Today Olympus builds upon the 40-year legacy of the OM SLR film camera series and marks the beginning of the new digital imaging era with the launch of the Olympus E-M5, the first of the new Olympus OM-D (OM Digital) Series of Micro Four Thirds™ products. Designed to meet the needs of advanced photographers, the Olympus E-M5 is packed with a built-in electronic viewfinder, superior image technology, blazing fast speed and total creative control in a classic, rugged body ready for sand, sun, sleet or snow.
Evoking the classic design of the original OM Series introduced 40 years ago, and transforming it for the modern age, the Olympus OM-D Series is a new and entirely unique Micro Four Thirds camera system. It combines outstanding features found in the Olympus E-System DSLR line with those of the compact Olympus PEN® Series to meet the requirements of discerning photographers who demand more performance and portability from their interchangeable-lens cameras. The compact and ready-for-action Olympus E-M5 boasts breakthrough innovations inside, including:
  • A built-in 120-fps (frames-per-second) refresh rate, high-resolution electronic viewfinder (EVF) with outstanding image quality, eye detect and intuitive functionality that enables real-time viewing of shooting conditions
  • A 16.1-megapixel Live MOS Sensor and TruePic™ VI image-processing engine for superior image quality and high sensitivity
  • The world’s first*1 5-axis image stabilizer to compensate for multi-directional camera shake during both still photography and HD moviemaking
  • The world’s fastest*2 autofocusing system (FAST AF) plus new 3D AF tracking for improved performance following moving subjects at up to 9 frames-per-second sequential shooting
  • A lightweight magnesium alloy body that is enhanced with the same dustproof and splashproof durability of the Olympus E-5 DSLR
  • A tilting 3.0-inch touch screen OLED and new Movie Effects: One Shot Echo, for a semi-transparent frame at your whim and Multi Echo, for a multi-motion trail effect.
 Intuitively Designed Electronic Viewfinder
The OLYMPUS E-M5 is the first Olympus interchangeable-lens camera to incorporate a 120-fps refresh rate, High-Definition electronic viewfinder with an eye sensor to seamlessly switch the display between the tilting, 3.0-inch touch screen OLED and the electronic viewfinder for ease-of-use, features a 100-percent field of view, maximum 1.15x magnification and an eye point of 18mm for fatigue-free viewing. Camera setting information, such as shutter speed, is displayed at the bottom of the viewfinder so photographers can concentrate on framing shots and take full advantage of an EVF’s ability to display the effects of various exposure adjustments and Art Filter effects – all without having to take the eye away from the viewfinder.
Superior Image Quality
The Olympus E-M5 uses a new 16.1 megapixel High-Speed Live MOS Sensor offering improved performance and exceptional clarity and speed in all aspects of image capture. Olympus’ TruePic VI image-processing engine dramatically improves image quality in low-light environments. The camera’s sensor allows for a maximum ISO of 25,600, and the dynamic range has been expanded for more faithful color reproduction.
Unprecedented 5-axis image stabilization
The Olympus E-M5 is distinguished by the world’s first 5-axis image-stabilization mechanism capable of reducing the effects of camera motion and image blur from five directions on stills and video, even including motion blur caused by the photographer walking or running. Previous IS mechanisms compensated for camera shake by addressing only two kinds of movement along the vertical and horizontal axis. However, camera shake can actually be caused by five different kinds of movement: horizontal shift, vertical shift, rotary motion, as well as the yaw and pitch. While some technology has attempted to correct for camera blur by building the Image Stabilization mechanism into the lens, the Olympus E-M5 IS mechanism is incorporated into the camera body itself so that all lenses mounted on the body can take advantage of this sophisticated technology, whether shooting stills or HD video.
Blazing Speed
Focus and shoot faster with record-breaking autofocus speed and imaging processing. The Olympus E-M5 employs the FAST (Frequency Acceleration Sensor Technology) AF system, introduced in the PEN E-P3, but with even greater speed. The 16MP Live MOS chip drives image data off the sensor at a blazing 240 frames-per-second, a 2X speed increase in Continuous Autofocus, with reduced image blackout enabling photographers to track fast action, Maximum frame rates in sequential shooting have also increased more than 2X with a max frame rate of 9-fps in Single AF. A new 3D tracking AF system can follow the subject through the X-, Y- and Z-axes to dramatically improve focus on moving subjects. Paired with the M.ZUIKO DIGITAL ED 12-50-mm f3.5-6.3 electronic zoom lens for optimum focusing speed, fast camera start-up times and operational speeds enable the photographer to keep up with the most challenging shooting situations, while dual control dials and dedicated function buttons help them adjust settings on-the-fly.
Creative Freedom
The Olympus E-M5 features a 3.0-inch tilting OLED touch-screen to enable photographers to get up high or down low for any shot. The touch screen interface offers intuitive focus and release of the shutter and review and enlargement of images in playback with the touch of a finger. The new Live Bulb feature updates the Live View image on the OLED screen at pre-set intervals during long exposures and enables the user to preview continually unfolding action such as fireworks or waterfalls and adjust the exposure time accordingly while capturing the image at the desired moment. An innovative new interface, EVF Creative Control, produces a tone curve overlay on the viewfinder screen to enable separate adjustment of highlight and shadow brightness, white balance, magnification and aspect ratio can also be manipulated via the EVF
A new “Key Line” Art Filter joins ten other available filters on the Olympus E-M5 and enhances the edge lines of the image to make it look more like an illustration. New “Cross Process II” and “Dramatic Tone II” Art Filters provide variations on the popular existing filters, and the two new Echo effect for movies leaves a momentary residual image of a subject’s movements when activated during movie recording. Users who like to perform their movie post-editing on a PC will particularly appreciate the Full HD 1080i movie recording function, which adopts the MOV format (MPEG-4 AVC/H.264).
Powerful Portability and Rugged Durability
The striking, iconic design of the Olympus E-M5 is more than just looks; its magnesium alloy body is rugged enough to stand up to severe environmental conditions like heavy rain and blowing sand. The Olympus E-M5 employs internal seals extensively and, when the new M.ZUIKO DIGITAL ED 12-50 mm f3.5-6.3 EZ lens is attached, this combination delivers an integrated dustproof and splashproof camera system. The electronic viewfinder section of the body is also made of magnesium alloy to ensure durability, and the FL-LM2 Electronic Flash that ships with the camera features the same dustproof and splashproof construction.
New Lenses and Accessories for Every Shooting Challenge
The HLD-6 Power Battery Grip, in the same dust- and splashproof construction as the Olympus E-M5 body, is an adaptable, two-part grip that can be used either as a landscape grip for easier handling or as a portrait grip with an additional shutter release. The portrait grip accommodates an extra lithium-ion battery to supplement the one in the E-M5, thus extending battery life. The FL-600R electronic flash (GN 50 at ISO 200 or GN 36 at ISO 100) offers improved recharge time and enhanced flexibility and operability for movie recording, and with a wireless control option. Equipped with a built-in LED, the FL-600R can be used to light movies and as a brighter AF auxiliary light. The MMF-3 Four Thirds mount adapter is designed for mounting a Four Thirds Standard-compliant lens on a Micro Four Thirds Standard-compliant camera body. The MMF-3, which also features dust- and splashproof construction, is ideally suited for use with Olympus’ similarly constructed High Grade and Super High Grade lenses.
The Olympus E-M5 is compatible with all Micro Four Thirds-compliant lenses, including two new lenses that Olympus will introduce later this year: the M.ZUIKO DIGITAL ED 75mm f1.8 and the M.ZUIKO DIGITAL ED 60mm f2.8 macro. The 75mm lens is a high-quality metal design with fast aperture settings for portraits and indoor sports shooting, while the dustproof and splashproof 60mm lens features 1:1 macro and a closest shooting distance of just 7.5 inches.
*1 As of February 2012. Among interchangeable-lens cameras.
*2 As of November 2011. Among interchangeable-lens digital cameras on the market, and using Olympus’ in-house test conditions. In C-AF Tracking mode, maximum frame rate is 4.2fps.
U.S. Pricing and Availability
The Olympus E-M5 will be available in April and ships in the following configurations:
Estimated Street Price:
$999.99 (Body only, available in Black and Silver)
$1,299.99 (Black or Silver body with black M.ZUIKO Digital ED 12-50 mm f3.5-6.3 EZ lens)
$1,099.99 (Black body with black M.ZUIKO DIGITAL 14-42 mm f3.5-5.6 II R lens)
For a complete list of specifications, visit the Olympus website: http://olympusamerica.com/cpg_section/product.asp?product=1583
To find out more about the OM-D E-M5, visit the OM-D site at: www.olympusomd.com
Olympus OM-D E-M5 specifications
MSRPEU: € 1099 (Body only) UK: £1149.99 EU: € 1299 (with M.Zuiko Digital ED 12-50mm 1:3.5-6.3)
Body type
Body typeSLR-style mirrorless
Body materialMagnesium alloy
Max resolution4608 x 3456
Other resolutions4608 x 3072, 4608 x 2592, 3456 x 3456, 2592 x 3456, 3200 x 2400, 3200 x 1800, 3216 x 2144, 2400 x 2400, 1824 x 2432, 2560 x1920, 2560 x 1440, 2544 x 1696, 1920 x 1920, 1440 x 1920, 1920 x 1440, 1920 x 1080, 1920 x 1280, 1440 x 1440, 1104 x 1472, 1600 x 1200, 1536 x 864, 1584 x 1056, 1216 x 1216, 864 x 1152, 1280 x 960, 1280 x 720, 1296 x 864, 960 x 960, 720 x 960, 1024 x 768, 1024 x 576, 1008 x 672, 768 x 768, 576 x 768, 640 x 480, 640 x 360, 624 x 416, 480 x 480, 384 x 512
Image ratio w:h1:1, 4:3, 3:2, 16:9
Effective pixels16 megapixels
Sensor photo detectors17 megapixels
Sensor sizeFour Thirds (17.3 x 13 mm)
Sensor typeCMOS
ProcessorTruePic VI
Color spacesRGB, Adobe RGB
Color filter arrayPrimary color filter
ISOAuto (200 - 25600), 200, 400, 800, 1600, 3200, 6400, 12800, 25600
White balance presets12
Custom white balanceYes (1)
Image stabilizationSensor-shift
Uncompressed formatRAW
File format
  • JPEG
  • DCF
  • DPOF compatible
  • MPO compatible
Optics & Focus
  • Contrast Detect (sensor)
  • Multi-area
  • Selective single-point
  • Tracking
  • Single
  • Continuous
  • Face Detection
  • Live View
Autofocus assist lampYes
Digital zoomNo
Manual focusYes (Live view image is magnified when the focus ring is rotated. (at S-AF+MF or MF mode))
Number of focus points35
Lens mountMicro Four Thirds
Focal length multiplier2×
Screen / viewfinder
Articulated LCDTilting
Screen size3
Screen dots610,000
Touch screenYes
Screen typeTouch control in electrostatic capacitance type OLED monitor
Live viewYes
Viewfinder typeElectronic
Viewfinder coverage100%
Viewfinder magnification1.15×
Viewfinder resolution1,440,000
Photography features
Minimum shutter speed60 sec
Maximum shutter speed1/4000 sec
Exposure modes
  • i Auto
  • Program AE
  • Aperture priority AE
  • Shutter priority AE
  • Manual
  • Bulb
  • Time
  • Scene select
  • Art Filter
Scene modes
  • Portrait
  • e-Portrait
  • Landscape
  • Landscape + Portrait
  • Sport
  • Night
  • Night + Portrait
  • Children
  • High Key
  • Low Key
  • DIS mode
  • Macro
  • Nature Macro
  • Candle
  • Sunset
  • Documents
  • Panorama
  • Fireworks
  • Beach & Snow
  • Fisheye Conv
  • Wide Conv
  • Macro Conv
  • 3D
Built-in flashNo
External flashYes (via Hot-shoe (FL-50/FL-50R, FL-36/FL-36R, FL-20, FL-14, FL-300R, FL-600R))
Flash modesAuto, On, Off, Red-Eye, Fill-in, Slow Sync (2), Manual (3 levels)
Flash X sync speed1/250 sec
Drive modes
  • Single
  • Continuous
  • Self-timer
Continuous drive9.0 fps
Self-timerYes (2 or 12 sec)
Metering modes
  • Multi
  • Center-weighted
  • Spot
Exposure compensation±3 (at 1/3 EV, 1/2 EV, 1 EV steps)
AE Bracketing (2, 3, 5, 7 frames at 1/3 EV, 1/2 EV, 2/3 EV, 1 EV steps)
WB BracketingYes (3 frames in 2, 4, 6 steps selectable in either blue/amber or magenta/green axis)
Videography features
Resolutions1920 x 1080 (60 fps), 1280 x 720 (60, 30 fps), 640 x 480 (30 fps)
FormatH.264, Motion JPEG
Storage typesSD/SDHC/SDXC
USB USB 2.0 (480 Mbit/sec)
HDMIYes (Mini HDMI type-D)
WirelessEye-Fi Connected
Remote controlYes (Optional (RM-UC1))
Environmentally sealedYes
BatteryBattery Pack
Battery descriptionLithium-Ion BLN-1 rechargeable battery & charger
Weight (inc. batteries)425 g (0.94 lb / 14.99 oz)
Dimensions122 x 89 x 43 mm (4.8 x 3.5 x 1.69)
Other features
Timelapse recordingNo
Additional images
Top view with additional grip attached. Accessories
Weather sealing
 Splash proof  Optional hand strap
Left and right sides of the OM-D Optional 4/3 lens adapter
