Nokia 808 Review: Damian Dinning of Nokia Responds
By Barney Britton | Published Aug 1, 2012 |
Damian Dinning is Lead Program Manager of 'Imaging Experience' at Nokia.
We were in touch with several Nokia representatives throughout the process of producing our recent review of the Nokia 808 PureView. Following its publication, Damian Dinning - Lead Program Manager of Imaging Experience at Nokia wrote to us responding to some of the issues that we raised and explaining why those decisions were made in the phone's development.
August 1st, 2012
Dear dpreview.com
Great to see the 808 PureView receiving your Gold Award – thank you. Our team are both delighted and extremely proud of their collective achievement.
I thought I’d just take some time out to share some insights/background behind some of the decisions/trade-offs we made given some of the excellent points you noted in the review.
Whilst we wanted to provide a rich set of controls which cover key elements such as focus, exposure, brightness/colour and composition especially for those who take a more involved role in the capture phase, we also wanted to keep as clean and as uncluttered viewfinder as possible. As you might imagine however, it’s very hard to get this balance just right. Personally speaking I find most of not all digital camera viewfinder/info screens are either all or nothing. We continue to seek the best balance in this regard, but equally, recognise we can never get this right for everyone.
This principle led us to a number of decisions we felt all things considered where the right ones:
Specifically…
Histogram:
We believe not everyone uses it or knows how to use it and even fewer need/use it all the time. Our solution was therefore to provide one click access from the EV adjustment button. You can either just check it or check and adjust, it’s up to you. But then you can easily hide it too. As aid we wanted to retain as much viewfinder real estate as possible.
Slide zoom:
We felt the conventional method of 'assisted' zoom is too slow and lacks sufficient control and precision. What I mean by assisted zoom is basically anything other than manual zoom as on most SLRs. Whilst manual zoom is fast and precise it’s almost impossible to zoom smoothly, important for video of course. The slide zoom capability we're introducing for the first time with the 808 PureView provides a level of precision and speed pinch to zoom and motorised zooms are unable to provide.
Often with these methods you end up under/over shooting and/or moving the device during the operation. Furthermore, in the case of motorised controls, you’re often having to wait for the zoom to travel from one point to another. With slide zoom it allows you to frame the shot similarly to cropping in photo editing applications and then when happy with the framing, simply releasing your ginger from the display it either quickly zooms to that setting in the case of stills or in video smoothly and more slowly to the pre-set framing.
We use an acceleration/deceleration curve at the start/stop phases of zoom too, impossible with other methods and then aim to handle all those pixels as smoothly as possible. Ideally I would have liked it to be even smoother. Zooming out is more conventional. We did prototype the same method of zooming for zoom out but in trials we found it to be counter intuitive. Again based on trials we found once people had used it for a while it becomes very intuitive, fast and easy. As I think you pointed to in your own conclusion. Our own user testing showed that after this period everyone preferred it to conventional zoom methods.
ISO setting:
We found the optimal number of touch controls along the side of the viewfinder in a screen of this size to be 5. This dictated the size of the touch targets. No doubt people will chime in and comment on this point but this was the recommendation from our usability experts to achieve good usability in the camera. This in turn dictated the area for text, which in some languages the characters used require more space than the often used English versions. However, as with all the icons we prioritised at least indicating that a function was set to a setting different to the default. Increasing the size of the buttons would have impacted more on the viewfinder which we were keen to avoid.
Exposure:
The 808 PureView uses a system which is more heavily influenced (unless faces are detected) by objects in the centre. Half press of the physical shutter release button (assuming touch to focus has not been set) locks both focus and exposure which for most situations should provide the desired results. However, this is an area I think with some small amount of innovation can improve the experience for the future.
Viewfinder:
Given there is no optical viewfinder of course we do prioritise the brightness of the viewfinder in very bright and very dark conditions to increase usability. In bright conditions we increase the brightness of the display accordingly to make it as visible as possible and in very low light conditions we increase the read time (reduce the viewfinder refresh rate) to increase the effective brightness of an otherwise dark scene. Unfortunately this results in a trade-off in such situations in the accuracy of the image as a preview which may explain some of the challenges you experienced with exposure compensation.
Thanks again, and best regards
Damian Dinning, Lead Program Manager, Imaging Experience. Nokia
9
Flag as inappropriate
Share:
Print view
Comments
Total comments: 214
12
LasVegasPhotographer
By LasVegasPhotographer (8 months ago)
Groundbreaking technology in a Phone, thanks Damian for bringing this to the masses! I only like dragging around my Canon 5D mk ii when I'm doing a paid shoot, but my 808 Pureview is always in my pocket for an amazing shot!!
1 upvote
Petrogel
By Petrogel (9 months ago)
An expensive camera phone with no reason of existence, Too expensive for a camera, too incapable for a phone !!!!!
0 upvotes
vetsmelter
By vetsmelter (9 months ago)
What exactly are the features you find missing in the phone part that makes it too incapable?
1 upvote
Menneisyys
By Menneisyys (9 months ago)
"What exactly are the features you find missing in the phone part that makes it too incapable?"
He's just trolling... many of his posts have recently been moderated out because of his blind trolling.
3 upvotes
Petrogel
say good bye
0 upvotes
Petrogel
@ Vestmelter
"....... the phone is remarkably unimpressive because it is based on Nokia’s ancient Symbian operating system. That means web-browsing that’s so slow you might as well not bother even comparing it to Apple or Android. And it means an interface that is in places as clunky in its design as the bulbous Pureview" doe newspapers
http://www.telegraph.co.uk/technology/nokia/9378495/Nokia-Pureview-808-review.html
For me the incapability goes to the O.S in relation with the price of the phone
Comment edited 3 minutes after posting
0 upvotes
vetsmelter
Understand so you are not comparing phone or communcation functionality (signal reception in low coverage area's, talk time, built in SIP clients, Skype GTalk etc..) but rather judging web surfing as main criteria.
I agree the 808 is not the surfing device of choice. I have an N900 for that. It is pocketable and complements the 808 very well. The 808 can serve as mobile access point.
N900 provides Tor, Firefox with noscript and adblock and full ip-tables Linux firewall control to block all greedy advertisement and data mining companies.
For sure Android has recently done a good catching work and has now also full Firefox features still missing on the iOS.
But to use your words: most platforms are still too incapable as a phone in my own judgement :)
Only the camera in the 808 can make me compromise into using the 808 as main phone.
To increase the 808's surfing speed: turn of the Flash and auto-reload feature and there you go, web browsing is already a lot quicker.
1 upvote
By Image3572 (9 months ago)
Great phone but with the os should be android !
0 upvotes
vetsmelter
Nikon is planning something, don't know if it includes a phone but at least its got Android (what a relief)
http://nikonrumors.com/2012/08/08/the-coolpix-s800-will-be-the-first-android-based-camera-from-nikon.aspx/#more-43120
0 upvotes
Menneisyys
Too bad Nikon's P&S cameras have always been bad compared to those of the top-tier P&S manufacturers (Pana, Canon, Fuji). Their only attraction have been their price (P300/P310, for example).
0 upvotes
technofan
By technofan (9 months ago)
A weak dynamic range with blown highlights can get tedious very quickly...add that to a Symbian system and I'm left with the feeling that this is nearly ready but it is not there yet. I had an XZ1 and the highlight clipping became an issue for me. Nokia has gone with Windows and that could be a mistake too. Android is the developers dream .... For the future I would love to see a much greater dynamic range. However, this phone for the early adopter is bound to do ok. Nokia has brought this out to make lots of early adopter sales. They probably have the next 3 generation phones sat in the factory waiting to go..... :-)
Kudos to Nokia for bringing this tech to the market....it is definitely a huge step forward in camera phones! :-)
0 upvotes
peevee1
By peevee1 (9 months ago)
"Android is the developers dream "
You must be kidding. Have you ever tried to do something houseful for Android, which necessitates going to NDK? Sheesh.
Sure, Symbian used to be worse, but with posix compatibility and QT added in the recent years it is much more bearable.
0 upvotes
rick1000
By rick1000 (9 months ago)
MR. Damian Dinning, I appreciate your candor & staright forward comnents and rational for the design trade tradeoffs made when executing the Nokia 808 build. There are many Fortune 500 comapnies that should learn a lesson from your perspective. Consumers understand tradeoffs, we don't like being lied to. I will consider a Nokia product in the future.
4 upvotes
WilliamJ
By WilliamJ (9 months ago)
I won't ever for my part. I don't like to give my hard-earned money to a company that is unable to manage itself well enough to avoid firing 10000 (!!!) employees when it reorganises its business (cf: http://www.wired.com/business/2012/06/nokia-fires-10000-looks-to-undercut-cheap-android-phones/ ).
Don't feed the monster otherwise don't be surprised it will become more and more voracious... and a model for every other companies, even the one that hired you or each member of your family.
1 upvote
Infms
By Infms (9 months ago)
@WilliamJ And the alternative? The company going bust and having to fire ALL of its employees? Think for a second... :)
3 upvotes
WilliamJ
I did, and you did you ? Really ? Is saying nor doing nothing to protest against that sort of scandalous management a good politic to you ? I don't care for Nokia, there will always be enough people who just think to their own pleasure to buy their products. But if some of us boycott Nokia, maybe this will become more difficult for them to make ends meet, and ultimely, they will try to avoid such a politic that can irritate their customers and make them lose some big bucks.
Never ever forget the old proverb: silence means consent. I, for my part, won't be silent. I thank you by the way to give me another opportunity to point it out.
1 upvote
MistyFog
By MistyFog (9 months ago)
WilliamJ, seriously I think you don't have a clue on what is going on, or perhaps like Infms said you just haven't thought things through. The layoffs were necessary to conserve cash as Nokia is going through a rough patch at the moment - you have been reading the papers, or have you not? In any case, Nokia was outspending even Apple so it makes sense to realign their expense ratio. Boycotting the product will only aggravate the situation and likely result in even more jobs lost. Despite your posturing I don't think you actually have Nokia employees' well being at heart. Or you don't happen to work at Cupertino, do you?
In any case, this is a photographic review and your vendetta against the company has no place here. Go picket, take to the streets if you must, but please take your grouses elsewhere.
2 upvotes
WilliamJ
To MistyFog: it's so easy to spot a dishonest person, that's the one who shows to have a two standards rolling in his veins. You demand me to "leave my vendetta" outside.
1) who do you think you are to demand anything to anybody here ? Only Dpreview webmasters are qualified to scold a member if they find it necessary. Are you one of these webmasters ? If not, your authority is nil.
2) why didn't you demand rick1000 to shut up too, as he's largely praised the Nokia way of managing in the first place, which has nothing to do with photography. Really, other Forbes 500 big companies should take model on the Nokia way to fire 10000 to stay an even keel ? Very good model, indeed !
To sum up, let me tell you if you want to be credible, behave with equity and don't overestimate your importance on a site where you're nothing more than another citizen. Understood ?
1 upvote
MistyFog
I think you are too blinded by hatred to actually read what rick1000 is trying to say. This is a thread about Damian Dinning sharing his views and some of the thoughts that went into the product, and if I read rick1000 correctly he is basically thanking Mr Dinning for sharing these info and wishing that other companies will have the same level of communication and candor with their customers. You may agree or disagree with Mr Dinning but I sure do appreciate the time he takes to explain things to the customers. I agree with rick1000 on this. Meanwhile, YOU had to hijack this thread to push your own agenda against Nokia.
1 upvote
WilliamJ
Hatred ? Me ? You're wrong, in this like in other things. But how to talk with somebody who is so full of prejudices ?
How to talk with someone who thinks a company who fired a total of 40000 employees in just two years (cf: http://www.ibtimes.com/articles/352117/20120614/nokia-elop-job-cuts.htm ) is a good enough company ?
How to talk with someone who thinks product of this company deserves to be bought just because it got good reviews and is affordable, disregarded its competitive price and it's strong advertisement is the result of super-harsh company choices ?
Is it possible to talk with someone who polarizes himself on the efficiency of a product without considering any ethic background ?
And be sure I didn't hijack this thread. Rick1000 said he would consider buying a Nokia product because he' been pleased by its communication ability. To that, I answered I didn't consider to buy any Nokia product for the reasons I gave. Is it allowed to have a different opinion, yes or no ?
1 upvote
MistyFog
WilliamJ, rick1000 made a simple statement that it's commendable for companies to engage their customers. And I did enjoy reading the information shared by Damian, and felt that I have in fact learnt something on UI design. There is nothing wrong to thank someone for sharing information, to express the wish that more companies do the same.
This is a very simple situation where a reader enjoyed reading a particular item posted at the site, and expressed appreciation for the person providing that information. Very simple and should have ended at that! There is no need to bring in unrelated topics with the obvious purpose to undermine someone. If you have issues with a particular business decision by a company please bring that up in the appropriate forum, for goodness sake not a site dedicated to photography! I can easily imagine you trolling EVERY forum where Nokia is mentioned (especially if in positive light) to make your smear/attack. Looks like a troll, sounds like a troll.
1 upvote
WilliamJ
And you forgot "tastes like a troll" to be complete... or to be completely off mark. I don't have any relation with Nokia, have no need to take revenge of it (I've not been fired by this company, for instance) and have never been angry against one of its product as I've never bought a Nokia. I just intended to say personally, I won't ever buy a product of a company who fired so many good workers in order to stay in a race that ruins families just to sell not-too-expensive-camphone on an already over-saturated market.
Pyrrhic victories are not my taste.
Well, I've said what I had to, no less no more. For the rest, Petrogel has said it all.
1 upvote
Menneisyys
EOSHD has posted a VERY good review to http://www.eoshd.com/content/8674/nokia-pureview-808-review-and-vs-iphone-4s , certainly worth a read.
They state the following:
1, the DR of the camera is much better than that of the iPhone 4S (and, consequently, the S3). I REALLY recommend checking out the direct comparison of the two phones in the two shots right under the sentence "Highlight roll off, although not as nice as a DSLR of course is better than most small chip pocket cameras and certainly an improvement over the iPhone 4S.".
2, highlight clipping can easily be fought by artificially decreasing the contrast. (Of course, by dialing-in a -0.x exposure correction also works. The article states the shadows aren't very noisy.)
3, now, for the bad: as was easy to see based on GSMArena's ISO 12233 and other, comparative test shots, the 1080p effective video resolution is certainly worse than that of the 4S (and a lot other cameras / phones). Damian, do you plan to fix this?
3 upvotes
AnHund
By AnHund (9 months ago)
The DR of the 808 is possibly better than the 4s, but it is still "only" 10EV at lowest ISO (which is quite incredible for a phone camera) compared to 11,6EV for a P&S like the Canon S100.
If you make exposure compensation to prevent highlights from being clipped you'll loose detail in the shadows due to under exposure.
Btw. if you want to see some great iPhone photos take a look here:
http://blog.mingthein.com/2012/06/10/the-iphone-as-a-camera/
1 upvote
WilliamJ
I don't know whether I'm the only one in this forum to feel there is like a marketing flood in action: so many people who had never posted before suddenly appeared to tell us how fantastic the Nokia is and how it can do as well as a good camera, by the way it's so good it could easily replace any P&S camera and so on. A real gospel !
Too many people telling the same thing and intending to prove - what for ? - that if you buy yourself this item you won't need a camera any longer... very suspect. Where this urging to convince us of such a strange idea comes from ?
2 upvotes
AnHund
I think it is because people really want it to be exceptionel and fantastic.
Of course it is possible to take great shots with this camera in perfect light and with the right person behind the lens, but that can be done with an iPhone, Android or Lumia.
I guess a lot of people are going to be a bit disappointed, because this phone is not going to take great photos by itself and especially not in difficult lighting conditions.
I have seen really good pictures taken with this phone, but then again (and no offence) looking at the samples here at Dpreview the output is not very convincing if compared to for instance an S100 which I would choose any day to this camera phone if I could have only one camera.
Comment edited 32 seconds after posting
3 upvotes
Rage Joe
By Rage Joe (9 months ago)
Or maybe it just simply IS fantastic. Hehehe,
3 upvotes
MistyFog
Has it ever occurred to you that maybe, just maybe, there are those who bought an 808 and are happy with their purchase? I'm wondering how we can verify that, perhaps Amazon might have some customer reviews available?
You don't like the 808, fine, DON'T BUY IT. Please stop making all sorts of insinuations here (fake accounts etc) without basis. There are enough genuine 808 owners who just love their phones and the pictures coming out from it, and not to mention the positive reviews from various websites. I find your insinuations very offensive and I hope you will have the maturity to refrain from making them.
1 upvote
WilliamJ
It seems it's a new trend to demand defiantly others to shut up when their opinions are disturbing. Yet it's easy, if our doubts about so many people suddenly feeling in their guts the urging need to promote the camphone they bought so expensively are unfounded, what's the matter ? If the product is really good enough, it will sell like hot cakes. What are you affraid of ? That we might be right, perhaps ?
1 upvote
regulareinstein
By regulareinstein (9 months ago)
"...simply releasing your ginger from the display it either quickly zooms..."
That typo made for an interesting imagination exercise.
4 upvotes
Peanut88
By Peanut88 (9 months ago)
This could be a good niche of a camera smartphone in the future.
But it sorely needs these changes :
1) More camera modes and options.
2) Underwater camera phone container
3) New OS. Best to be Android. Not Windows 8.
Waiting for the next model soon.
You indeed wasted precious time and resources on the Symbian OS phone. It is dead on the water.
2 upvotes
vlad0
By vlad0 (9 months ago)
Android ? Why ruin the phone like that..
7 upvotes
lecoupdejarnac
By lecoupdejarnac (9 months ago)
I own the 808 and I love it. I really liked my Olympus XZ-1 but I sold it after I got the 808, because I wasn't carrying it as often as I thought I would.
I've used iPhones before and I have to say, I've been impressed with Symbian. It is very responsive and I don't find it to be much worse than iOS unless you don't like using a browser (I use Opera) and are dependent on apps. Granted I would probably prefer Android.
What I would like to see most is a built-in HDR mode, because manually generating HDR images on a PC would somewhat defeat the convenience of a camera phone. Plus it would help with the highlight clipping.
A underwater container? Heh I don't think that would make most peoples' priority lists :p The phone will fit in most waterproof plastic bags though...
6 upvotes
Ben O Connor
By Ben O Connor (9 months ago)
As another XZ-1 user; I cant decide any other thing to replace my baby white XZ-1 ;) But i promise next camera that i will purchase (maybe 4 years later) would be a Hardcore DSLR or even a full frame one.
I even starting to think that Olympus is very late to show its XZ-1´s rival... first Samsung make its cam´s wi-fi... then canon bring outbiggest sensor to G series... and then sony made it pocketable.. BUT THIS LAST ONE... Nokia really hit the target no wonder.
By the way soon i will also pruchase XZ-1´s housing, i also dreaming some underwater case for Nokia... but then... imagine, you are about to take some fish foto, suddenly your phone rings! and the fishes swam away coz of the noise :)))
0 upvotes
Ben O Connor
THIS IS THE KILLER DEVICE FOR 1,7" & SMALLER SENSOR SIZE P&S CAMERAS. NO ARGUE AT ALL !
Congratulations to Nokia. hmm and lets think about future some..
New Nokia 809:
Made screen fliping up and down (as in NEX-5n or E-PL3) and add all the photographical control buttons on keyboard , which locates beneath the screen. ;)
4 upvotes
HowaboutRAW
By HowaboutRAW (9 months ago)
Hard to believe that it will kill the sales of P&S cameras that shoot raw and can shoot PASM.
As for jpeg only, all auto, P&S cameras there's a huge price advantage for those cameras.
3 upvotes
Ben O Connor
Seriously, from this on thos P&S cameras should do MORE ! The ones´who brings JPEG´s only, your 3-5 optical zoom does not help anymore ! keep your up to 24 mpix´s for yourselves !
Now we got a "camera" here, that you can call grandma, and send sms to your mother :D have you ever seen a canon that you can even dial 3 numbers, 911 for example :D NOOOWAY !
0 upvotes
AnHund
Keep dreaming :-)
2 upvotes
WilliamJ
I'd like to say more, AnHund and me let you all alone with your illusions.
1 upvote
Camediadude
By Camediadude (9 months ago)
THIS is what I wanted! Thank you DPREVIEW, Thank you Mr. Damian, this is what makes us come here (me at least!) to devour scrumptious morsels ... such tantalising titbits from the leaders of the camera industries that we admire and adore ... I am eager to see where these exciting developments and beautiful engineering takes us! To the everlasting images!
3 upvotes
AbrasiveReducer
By AbrasiveReducer (9 months ago)
Oy vey.
0 upvotes
Camediadude
Oh dear, I sincerely hope that I did not offend you! Just got a might excited is all (blushing ..) and perhaps a tad inebriated as I typed! It happens, lol. Can't deny though that these are some pretty flipping sweet developments, and signs of good things to come for photography gear nuts like us!
1 upvote
JeaPS
By JeaPS (9 months ago)
Wipe yourself down.
0 upvotes
Camediadude
Lol...I like your "taste"
in cameras!
0 upvotes
massimogori
By massimogori (9 months ago)
Very interesting indeed: thanks DPREVIEW folks for focusing on this important development.
As soon as Mr Franiec releases a dedicated grip and Gariz makes a leather half case for this phone, I will trash my x-pro1.
Comment edited 50 seconds after posting
1 upvote
magneto shot
By magneto shot (9 months ago)
>< but u cant compare the 808 to the x-pro1....the x-pro1 can change lens and a much bigger sensor....
0 upvotes
ageha
By ageha (9 months ago)
The x-pro1 also focuses much slower. >.<
1 upvote
ViTAR
By ViTAR (9 months ago)
Why seek balance, when it could be made via basic and advanced options? Just make it selective by user, defaulting to basic.
2 upvotes
Japla
By Japla (9 months ago)
I have used 808 for a while, and I am pretty pleased with the IQ. For me the most important camera is the one which I always with me, not DSLR's at home.
There is one pretty annoying feature, which I decided to point out:
I would wish, that I could save the creative mode settings, for example in similar way as in Canon C1, C2, C3 modes. Right now, if I choose setting L1 and need to take a macro shoot, I change focus to macro. Unfortunately this also comes as new setting L1, so next time when I use camera, I need to change focus again.
I would prefer that the L1, L2 and L3 would be settings which are separately saved, so that when ever I choose any of them, they would always start with the my own, saved settings, and not with the ones which I modified last time.
1 upvote
closin99
By closin99 (9 months ago)
It should not be impossible for Pana to turn my LX5 or the upcoming LX8 into a phone.
0 upvotes
vetsmelter
Talking about Panasonic: I have yet to hear any raving reviews about their 101P.
It probably is no match for the LX5?
Still best camera phone in the world because of the Android OS many hear seem to find more viable (sometimes without hands on exp with Symbian) for hosting Pureview tech? ;)
http://www.intomobile.com/2011/10/01/panasonic-lumix-phone-101p-arguably-best-camera-smartphone-world-japan-only/
http://www.ubergizmo.com/2011/09/panasonic-lumix-101p-arrives-in-japan/
0 upvotes
Davidgilmour
By Davidgilmour (9 months ago)
How long before the copy cats from Cupertino will "patent" this invention?
4 upvotes
JadedGamer
By JadedGamer (9 months ago)
Apple hate - how quaint.
2 upvotes
EDWARD ARTISTE
By EDWARD ARTISTE (9 months ago)
Pathetic dude. Just pathetic.
0 upvotes
epdm2be
By epdm2be (9 months ago)
They can buy that panasonic sensor just as anyone can. Why hasn't any o/t other player do that.
The same with Sony. They make sensors themselves (tech obtained from Minolta ages ago). Instead of marketing Xmor-RE sensor why nor stick a REAL XMor-sensor in these xperias and use a proper GLASS lens (perhaps a Carl Zeis one).
I'm sure carl zeiss would sell to anyone who puts a bag of money on the table (the same for Panasonic).
So instead of talking down on Nokia, PUSH the others into doing the same. Come on HTC, Sony, LG, Samsung (ditch that lousy 8Mpixel Sony-sensor and stick at least a 12Mpixel XMor but preferably this 41-panasonic into the future Galaxy S IV)
0 upvotes
macyourday
By macyourday (7 months ago)
Ahhhh. The aroma of ignorance and bile. Scrtch 'n sniff even on the internet.
0 upvotes
Pixel Judge
By Pixel Judge (9 months ago)
Never a big fan of camera phone.... until NOW! These images are simply impressive by a smart phone.
I would vote Damian as the CEO of Nokia for his genuine, logical and yet humble feedback. He would have turned around Nokia's product & stock....hmm.
(Camera companies now please take notes!)
12 upvotes
vlad0
He gets my vote.
Too bad corporation don't operate in a very democratic manner...
0 upvotes
epdm2be
... and mine too.
I'm completely convinced that ALL whom had the pleasure to actually meet Mr. Dinning will agree as well. They ought to sack that ex-MCSFT CEO and put someone in charge whom actually ACCOMPLISHED something for the company!!!
Comment edited 6 minutes after posting
0 upvotes
Gadgety
By Gadgety (9 months ago)
The RX100 mentioned elsewhere in the comments certainly looks impressive. Still the Pureview impact is likely to be several magnitudes greater. Besides the obvious benefits of Pureview, the compactness enables future innovations.
For example, when processor power/speed is even more impressive in the phone/tablet world, I imagine that all sets could have TWO cameras for 3D/stereo HIGH QUALITY photography with incredible compactness. These things seem to impress the kids of today as they watch 3D movies and TV, so it'll come to the mobile world.
Furthermore how about if Nokia creates a Nokia mount, and adapts the Ricoh GXR concept, meaning you could buy various types of lenses (extra wide angle/telelenses/macros) with integrated sensors and a software pack that goes with each lense.
0 upvotes
Gadgety
The possibilities are endless. Whereas the coupling of phone and lense brings advantages. This decoupling, but at a higher level allowing both coupling and decoupling, creates an entirely new photography market.
Imagine if the Pureview camera was detatchable and useable on a WP8 phone I'm sure a lot more buyers would, me included, would fork out the money, knowing I get the use the camera module in future iterations/OS:s.
This would also turn Nokia even more inte a photography/media/video company: The "NOKIA NANO 4/3."
0 upvotes
vlad0
That would require some amazing software patches..a lot in the PureView technology is based on algorithms written for Symbian, and the specific drivers for the dedicated GPU/DSP .. very complicated, and that would make it really hard to just swap the sensor between two very different platforms.
In fact, I don't know if we are going to see the PureView PRO technology in a Windows NT based phone anytime soon. The platform (wp) supporst SoCs that can handle up to 20Mpix sensors, not 40+, which is needed if you want the full effect. So.. either PureView "light" or Microsoft would have to write specific software for that camera module, which needs that extra processing power.. I believe that was one of the main issues during the 808 development, they just couldn't get a hold of enough computing power to process all the pixels in real time, especially during video recording.
Otherwise, great idea :)
Comment edited 1 minute after posting
0 upvotes
Gadgety
If Nokia spent 5 years of budget on developing Pureview and the business case is there, I'm sure both Nokia and Microsoft will make the porting of the FULL Pureview to WP, although it may not happen in WP8. We'll see. As for the rest of my idea, I'm sure there are massive obstacles. I was just toying with the possibilites that Nokia's breakthrough tech creates.
0 upvotes
terantek
By terantek (9 months ago)
It should be achievable in WP8, I think there were similar limitations in WP7 with regard to the 16MP titan II, which they overcame with a dedicated ISP. Hopefully the same sort of thing can be done, I really want this camera, but not on a small low res screen. I'm sure MS will do what it can to get this tech on their OS as well, it would give them a huge boost to have their phone winning all the camera reviews.
0 upvotes
FYUHJ
By FYUHJ (9 months ago)
In 1966, the original has [url=http://www.nikeshoessaleusa.com/nike-sb-dunk-high-heel-blackorange-p-1420.html]nikes shox tl3[/url] been trying a variety of different methods of production of lighter shoes, Bowerman, send Onitsuka company a pair of shoes of their own design, which the upper is a soft nylon, rather than the traditional leather. This pair of shoes called Cortez, although the beginning was the representative of Adidas ridiculed and laughed at, but at the track all the rage to [url=http://www.nikeshoessaleusa.com/nike-sb-dunk-high-heel-blackbluesilver-p-1419.html]nikes shox conundrum[/url] become Tiger's best-selling shoes. In 1969, BRS has sold more than one million U.S. dollars of shoes.
0 upvotes
Gadgety
I replied to these answers in the comments section where DD had made his original remarks. Appropriate that you lift the as a separate heading. Thanks.
0 upvotes
Joe Ogiba
By Joe Ogiba (9 months ago)
One huge advantage cameras have over the Nokia 808 is you don't need a 2 year contract with monthly data fees like here in the US with Verizon and others. Put the 808 camera in a Verizon feature phone like my Verizon Kin Twom with 8mp /720p camera and I would get it.
Comment edited 2 minutes after posting
2 upvotes
Anonymous Gerbil
By Anonymous Gerbil (9 months ago)
You can buy the phone without a contract, and as far as I know, you can use it as a camera without any contract.
1 upvote
HowaboutRAW
Anonymous Gerbil:
Why then when $650 would get one a much better camera?
0 upvotes
Sasparilla
By Sasparilla (9 months ago)
Thinking of doing the 808 with a month to month Straight Talk $45/mo unlimited talk/text and 2.5GB data plan (bring your own phone uses AT&T's network) - compared to many of Verizon / AT&T two year subscriptions you can come out ahead money wise with the 808 and Straight Talk.
As to the question of why get this when you can have a better camera - if you just want a camera don't look at a phone. I want a phone with a great camera and basic internet functionality and this covers those bases.
0 upvotes
AbrasiveReducer
With phones reaching this level of image quality I guess it boils down to what you want. If you want to take the best photos possible you're still better off with a small camera like the RX100. If you want a camera that can locate sushi restaurants and costs money each month to operate, then this looks a like a great solution. You have to hand it to Steve Jobs. He realized you only buy a Mac every few years but phones provide an endless stream of cash.
0 upvotes
Anonymous Gerbil
HowaboutRAW: Its not clear to me that $650 does buy me a "much better" camera. I already have a 7D and a 1000D, so I'm thinking pocket sized. Maybe RX100. Is it "much better"? I have no use for zoom (just another thing to fail), 20MP is stupid, but raw is nice. The 808 is almost certainly more pocketable, especially when I don't have to carry two devices.
AbrasiveReducer: The 808 doesn't cost money per month if you use it instead of another phone. (Or don't use it as a phone.)
0 upvotes
epdm2be
Not to mention you can transfer your pics to any other Bluetooth device (or NFC+BT for even easier transfer) and/or wifi. You can even use it as an USB disk with 3G/wifi/USB-tethering when out in the field playing with your photoshop and the pics taken. It has Facebook and twitter access (if needed).
And as a phone... it's the only one that has full 2-way call recording without hacking/rooting/jailbreaking/whatever(Nokia really ought to advertise this as a major selling point), loud ringtones, great speakerphone and has free worldwide offline point-to-point Navigation with a compass-guided pedestrian mode (which is interlinked with both the address-book and calender).
Plus this is the first decent P&S camera with DLNA :-)
Oooh, and you can also record astonishing full HD video with with great audio that you can couple with BT/wifi/DLNA...
I think a Phone like this opens a lot of opportunities for an avid amateur P&S photographer.
Comment edited 2 times, last edit 12 minutes after posting
0 upvotes
HowaboutRAW
Anonymous Gerbil:
$500 bucks will do for a much better camera. $400 will buy you a camera with real manual and raw--better.
0 upvotes
epdm2be
If Nokia wasn't such an egghead with the repair of my Lumia 800 I would have bought one 2 months ago. Now the summer is halfway gone and I'll probably pass on this. Just being a stubborn egghead myself this time (No I can't let this situation go and don't forgive Nokia for being such an a$$hole)!
A pitty since I was really looking forward to have one. Now I'll probably settle for a either an Xperia (12Mpixels supposedly Xmor-sensor) or an SGS III (Sony sensor similar to iPhone 4S). However I've got no idea about the "glass" on these phones. To they even have proper glass lenses?
1 upvote
Octane
By Octane (9 months ago)
I sure hope you will give every manufacturer the same chance and a top spot in your news section when they are responding to your reviews.
1 upvote
Scott Everett
By Scott Everett (9 months ago)
We do.
15 upvotes
epdm2be
Octane: actually I would have liked to see more manufacturers to be more open. In fact some punters have asked Mr. Dinning 'normal' questions and remarks which was he was kind enough to answer in all honesty with arrogance.
While others have gone to great lengths to avoid customers questions and thus denied responsability of certain subpar products (Yes, Apple and Samsung I am pointing at you).
0 upvotes
Valentinian
By Valentinian (9 months ago)
to my understanding, Nokia's great idea was to put a 40 MP camera together with a phone, and to use digital zoom (with consequent lower, but still enough MP).
Ok... but... ehi... Sony RX100 has 20 MP, optical zoom AND also digital zoom !... wonder what is the RX100's IQ when zooming down to 5 MP versus Nokia IQ ...
Comment edited 4 minutes after posting
0 upvotes
civichief
By civichief (9 months ago)
Hi,
please do not forget that the Noki 808 PureView is a mobile phone with a camera. It was not build to compete with dedicated digital cameras.
But under certain circumstances it can compete with some digital cameras and outperforms any other mobile phone.
5 upvotes
Jim
By Jim (9 months ago)
Exactly right, civichief. This is really an interesting device. It's easy to see the end of the trail coming for low end cameras as the in-phone cameras become better and better.
Jim
0 upvotes
Valentinian
I agree... to a point. yes, it is a phone, but one trying to be also a PORTABLE decent quality p&s. What struck me, was that also the RX1 can use the digital zoom trick, and it is more than competitive for price, portability and IQ.
Sure,it doesn't have a phone. so, if the phone part is more important for you, and carrying a camera AND a phone is unconfortable to you, then yes, get the Nokia. But this page is for digital camera review, so it is correct to compare the Nokia to a digital camera.
Comment edited 2 times, last edit 3 minutes after posting
1 upvote
3DSimmon
By 3DSimmon (9 months ago)
well if you're going to think like that...if you took the phone away, the camera would be about 1/8th the size of the RX100, how would the RX100 perform being 1/8th it's physical size
2 upvotes
Valentinian
Either my math or yours need to be reviewed... the RX1 is 1.4" thick. for the Nokia 808 to be 1/8th of the RX1, then the Nokia should be 3/16" thick.... wow
0 upvotes
vlad0
the rx100 is over $600 .. can't check your e-mail on it, can't read the news.. its just a camera. You get much more for that price with the 808, and you don't have to carry two devices anymore.
2 upvotes
Geir Ove
By Geir Ove (9 months ago)
Hello,
Do not forget the PureView technology: If it was this obvious and easy to pull off, why haven't the Big Ones (HTC, Apple ...) done this before?
Nokia has shown it's power to Invent, and they have great people like Mr. Damian Dinning!
Comment edited 36 seconds after posting
1 upvote
epdm2be
Funny the RX100 also uses Carl Zeiss optics :-)
0 upvotes
magneto shot
Here is a model album done completely using Nokia 808 :
http://www.facebook.com/media/set/?set=a.407827615931483.86458.171375309576716&type=1
0 upvotes
vlad0
"made for making" : ) Great clicks.. I've been shooting with the N8 for a while, and now the 808.. results are quite good from both, but the 808 is a step forward for sure. Here is my album:
http://www.esato.com/phonephotos/index.php?uid=206975
4 upvotes
Tilted Plane
By Tilted Plane (9 months ago)
Offhand, his remarks show both smarts and savvy. A good sign for Nokia. And what he says makes enough sense that nitpicking beyond all this is beyond me. Let's hear from people who buy and use the thing.
1 upvote
vlad0
I've had it for 3 weeks now.. great smartphone overall.
0 upvotes
mrdancer
By mrdancer (9 months ago)
Just a quick note to all the folks dismissing Symbian:
About a year ago, iOS received a lot of media attention because they were tracking users' habits, etc. Shortly thereafter, it was reported that AndroidOS may be even more aggressive at collecting user data. We can only assume that MS will follow suit. It seems the OS mfrs are more interested in tracking your habits and preferences than they are about providing a quality product. The future belongs to who has the most user data, and these companies would love to know everything possible about you.
Maybe Symbian isn't so bad after all...
4 upvotes
vlad0
Its not bad at all.. in fact, in some cases, its still better than ios and android.
4 upvotes
Ryan_Valiente
By Ryan_Valiente (9 months ago)
It's not like Google and Apple will use their collected data against you.
People are getting paranoid about these things.
Same goes to Facebook. After reading some comments in facebook news here in DPR, people here are freaking nuts.
0 upvotes
mrdancer
I agree that they won't use your data against you. However, there are no guarantees that that data is safe. How many times have we heard about data breaches in the last few years? Google and Apple are not immune from data breaches! I'm not really paranoid - I just don't like lots of holes and loose ends left hanging out there that could directly affect me.
Don't even get me started on Facebook - that is the stalker's best friend and most useful tool...
0 upvotes
Per Inge Oestmoen
By Per Inge Oestmoen (9 months ago)
Do these new Nokia phones have a notification light? With my Nokia E6, I can set the phone on Silent and be notified that someone has tried to call or sent a SMS, MMS or other message. With the notification light, I can spot this from a distance - and I do not have to pick up the phone and turn it on in order to be notified that someone has tried to contact me. My other phone, the Sony Xperia S, also has a notification light in the form of a small dedicated LED lamp. So, do the newer Nokias have such a notification light function?
0 upvotes
WilliamJ
Excuse-me Per Inge Oestmoen, it's not against you, but it's how a photo-dedicated site becomes a phone-oriented site. I can see the next question to be how to implement the SkyPe apps, and after if we can access a multi-lingual talking GPS function, and then if this phone is ogg or flv files compatible and so on...
Not my cup of tea !
1 upvote
Menneisyys
"Excuse-me Per Inge Oestmoen, it's not against you, but it's how a photo-dedicated site becomes a phone-oriented site. I can see the next question to be how to implement the SkyPe apps, and after if we can access a multi-lingual talking GPS function, and then if this phone is ogg or flv files compatible and so on..."
Time moves on - today, even some phones are capable of taking excellent pictures. The discussion of these phones do belong here, to DPReview.
Comment edited 23 seconds after posting
1 upvote
WilliamJ
Oh please, Menneisyys, don't be brain-washed ! A question about the notification light of a phone, be it photo-abled, is a discussion about phones and not about cameras. Don't act like a bull charging on a red cape !
0 upvotes
vlad0
This is a smartphone 1st, camera 2nd. People have it mixed up..
1 upvote
falconeyes
By falconeyes (9 months ago)
Yes. Configurable messaging light, after missed calls or SMS. Would be cool to enable it if phone is set to remote camera mode over Wifi, using an iPhone as its viewfinder. Not yet a feature, but who knows ...
0 upvotes
Sasparilla
Something not touched on, but is nice, is that the display when the camera is asleep shows the time of day and whether you have missed a call or have notifications waiting for you - no need to press a button to wake it up to see it, its just always there. Part of the display technology it uses (downside is that the resolution is low).
0 upvotes
snakez
By snakez (9 months ago)
Damian always seems pretty cool, but the thing is, even though Nokia is redefining the compact camera and pushing us in the direction compact photography should go in and eliminating the MP war, he's not too interested in putting the 808 in the hands of actual photographers and taking more input from us, not to mention, real world testing with imagination as a photographer would put it through, not pure "testing" with lab scenes.
1 upvote
GeorgeZ
By GeorgeZ (9 months ago)
Someone angry he didn't get a free phone?
8 upvotes
chlamchowder
By chlamchowder (9 months ago)
What makes you think that he's not interested in appealing to photographers, and isn't listening to photographers? The 808 offers far more photography oriented features than any other smartphone, in addition to excellent image quality.
It certainly seems to me that he has paid far more attention to photographers than any other smartphone maker.
4 upvotes
civichief
you may have missed it.
The FHM Magazine in Germany made a cover shoot with the 808 PureView with photographer Joss Gerhard (maybe???).
http://www.promicabana.de/wp-content/uploads/2012/06/Rebecca-Mir-FHM-Cover-2012.jpg
It's a bit dark, but acceptable.
0 upvotes
Mike Griffin
By Mike Griffin (9 months ago)
It isn't dark on my screen. Looks just like any other magazine cover shot with a high end SLR or MFC
0 upvotes
falconeyes
@Damian, thanks for the response and some of the motivations behind.
I do own the 808 and published two articles about it, one about how to successfully use the 808 in the studio (http://falklumo.blogspot.de/2012/07/the-icamera-nokia-808-pureview-part-ii.html ).
There are a number of points where the 808 needs improvement, simply because it now competes with more serious cameras. One is manual control over shutter speed ( fireworks, slave flashes, studio, sports etc. ). People know that they then need to control or configure ISO. Another sad ommission is a 3:2 aspect ratio mode.
I can understand that not everything feasible must go into a UI. To keep it clean. Fair enough.
But how about an updated API then? Such that Apps like CameraPro or others or a second app from Nokia ("CameraExpert" or so) can fill the gaps. And gaps there are.
Otherwise, I found the 808 a very capable and pleasing camera. Kudos to Nokia and the team.
3 upvotes
Menneisyys
"But how about an updated API then? Such that Apps like CameraPro or others or a second app from Nokia ("CameraExpert" or so) can fill the gaps. And gaps there are."
Exactly! At least a way to access the pure sensor data, BEFORE WB correction or any kind of NR. We need RAW support - as I've also explained in a mail I've sent to Mr. Alakarhu back in March.
0 upvotes
AnHund
Which serious camera does it compete with? - just curious.
0 upvotes
leopardskin
By leopardskin (9 months ago)
nokia! i have your tires on my bicycle, rubber boots and your 3310 - they are very fine, now for the first time in 10 past years i start to feel like buying a phone. (luckily i don't have money) i respect a good design and i guess this is it.
1 upvote
AmaturFotografer
By AmaturFotografer (9 months ago)
3310.. that's classic.
0 upvotes
Camediadude
WOW... I had no idea that Nokia has tire making ancestry, I just looked it up here too to see it with my own eyes ... Huh! We learn something new everyday!!
0 upvotes
Jostian
By Jostian (9 months ago)
Thanks Damian for taking the time to reply, I was VERY keen on the 808 till I saw the low res screen and plasticky build...WHY would you have such a low res screen on a phone with such an amazing camera?????? Screen res is lower than 3 yr old N8, makes no sense!!!
2 upvotes
GeorgeZ
They have the same resolution and it's because Symbian can't handle more.
As for the plastic- have you ever held one in your hand? It was the first thing that struck me, it's perfect. High grade "plastic" that feels good to the touch. Much better than my old Nexus S (THAT was cheap plastic) or the Sony Xperia P.
4 upvotes
Der Steppenwolf
By Der Steppenwolf (9 months ago)
GeorgeZ: Now I don't know about Nexus S but Xperia P is made out of metal. And if you held one and still think it's plastic then you really, really need help.
1 upvote
GeorgeZ
@Steppenwolf: I'm holding one in hynds right now. Didn't say it was plastic but the material of the 808 is, IMHO, nicer than that of the Xperia P. It seems plastic can feel better than metal. Thanks for your advice though.
3 upvotes
familyogre
By familyogre (9 months ago)
the screen is excellent, yes it's not the highest res but it's one of the brightest out there and is easily viewable in very bright light which is pretty important for taking photos.
As for the build, go hold one, it's fantastic.
2 upvotes
civichief
it is not lower that the resolution of the N(.
The pixel density is lower.
0 upvotes
Geir Ove
Hello,
From a Nokia 808 owner: The screen is just GREAT, and poses NO problem, and by the way it has the BEST Contrast Ratio of any Phone on the market:
http://www.gsmarena.com/nokia_808_pureview-review-776p2.php
0 upvotes
Schwermetall
By Schwermetall (9 months ago)
I knowing that we are here speaking mainly about photography but the video section is also an important part of this camera.
The 808 have an great performance in video too but it still lacks of an white balance lock and this distroys the stability of colour during panning.
I'm not 100% shure but even the white balance presets are not real fixed they are more a kind of working point and so they are also changing during panning.
1 upvote
ChrisPee
By ChrisPee (9 months ago)
Nokia 808 with Android: I'll buy. With symbian, no way.
6 upvotes
vlad0
You are missing out..
3 upvotes
civichief
because Nokia got no experience with Android and Nokia developed Pure View when there was no powerful Android available.
1 upvote
cermevez
By cermevez (9 months ago)
Hi... WOULDNT IT BE THE BEST TO HAVE MANUAL FOCUS ON THIS EXCELENT PHONE??? that could be added via software update PLEASE DAMIAN, PLEASE NOKIA!.
Pd: This phone is the best ever made for multimedia people like me! best photo, best gadget for music (fm transmitter), roughest, etc etc etc! the best!
0 upvotes
familyogre
It does have manual focus
1 upvote
cermevez
r iu sure??? manually I can adjust the distance tu be focused? maybe you are confused, I have a digi cam where you can set the distance to be focused, not only set "macro" or "infinite"... set the exact distance where you want to focus, like 15cm... 25cm... and scroll the distance that way...
0 upvotes
jon404
By jon404 (9 months ago)
So is he saying that the blown highlights are because the user didn't view the preview screen right? Something like that?
0 upvotes
GeorgeZ
I've been a visitor to this site for 10 years and funnily enough Nokia seems to be the only company that actually responds and gives insights- kudos!
Also I have followed Damian's postings here and on the Nokia blog and am happy to read that there are good reasons for their decisions. Very interesting.
I am very happy with the808. What I'd like to know is why it would chose 1/25 and ISO 250 and no flash in a indoor protrait with subject baout 1,5m away, that's strange. Maybe Damian could explain, is 1/25 considered fast enough to avoid camera shake? This is my image:
http://img214.imagevenue.com/img.php?image=885214696_2012_07_23_0528_122_924lo.jpg
3 upvotes
panoviews
By panoviews (9 months ago)
The 808 PureView with an Android OS would be fine, but right now I prefer my 90 Euro Samsung with Android and a small camera. Jumping back on the old Symbian? Noooooo..........
1 upvote
civichief
Nokia Belle Feature Pack 1 is brand new and in some aspects superior to Android or iOS (Multitasking, no unwanted data exchange, ofline navigation from the start, needs less resources for same performance).
0 upvotes
epdm2be
Don't compare S60 with Nokia Belle FP1. For god's sake. Nokia was even smart enough to call it Nokia Belle and still people think this is a bloody N97.
Do you hypocrites act the same when HTC brings out a new phone and start yelling "Oooh No not Donut again!"
Besides Android isn't very good at media itself. It took 4.0.1 (october 2011) before zooming in video-recording became possible OS-wise. This has been available far longer in even some older Symbian OS-versions (the N86 comes to mind, S60v3.2, OS9.3 2009).
Nonetheless. The 808 is another fine step in getting good camera's in cellphones. It just cannot replace my 'olde' Nikon D40 which has SPAM-modes which any 'serious' photographer require. Which is probably not the target audience for this phone, anyway.
Comment edited 14 minutes after posting
0 upvotes
PaulRivers
By PaulRivers (9 months ago)
Still just disappointed that there's no shutter priority mode.
That's the biggest thing that keeps this from possibly replacing my Canon s100 - I don't care about aperture priority, but in indoor lighting shutter priority is my most used mode - people moving at 1/15 just doesn't work, at all.
1 upvote
Anonymous Gerbil
A decent shutter speed is also important since the 808 does not have image stabilization. I don't recall that the review said anything about the shutter speeds that the 808 would choose.
1 upvote
Damian D
By Damian D (9 months ago)
We agonised a lot over this area during development. The main limitation is the lack of variable aperture control (a size constraint). If you set a specific shutter speed you're either going to get over/under expsoure or the system needs to play with the gain (ISO) which may leave you with results you were not expecting. This time round we've provided user control over the ND filter so you can force faster or slower shutter speeds, dropped the longest shutter speed to 2.7 seconds (when using manual ISO) and a greater degree of exposure compensation and ISO settings. Whilst we recognise this is not ideal, this should provide sufficent control over every available variable (given the limitation of no variable aperture ) to force shutter speeds that would still result in correct expsoure.
For the future, we continue to seek ways of providing more direct control over settings applicable to such usage.
Thanks for your feedback.
Damian
10 upvotes
Anonymous Gerbil
Damian: I'm less interested in a precise shutter speed than I am interested in a reasonably fast shutter speed. For example, a minimum shutter speed. Or... a minimum shutter speed per ISO level, thereby allowing interested users to specify the rate at which ISO is boosted as the scene darkens.
1 upvote
Damian D
Got it.
3 upvotes
PaulRivers
Hi, wow, thanks for responding. :-)
However, I'm not sure I can quite follow the reasoning - physical apertures have limits on how wide or narrow they can go as well, you have the same issues on a compact camera as well - my s100 won't go smaller than f8.0 either.
I have a friend who bought a Nikon superzoom which does a lot of 1/15 in indoor lighting, it's - the most frustrating experience I've ever seen. If he just takes pics, the camera chooses 1/15 and anyone who's not sitting down posing, or asleep, turns out as nothing but a blurry mess. If he wants to adjust the shutter speed, he has to screw around with the iso to "indirectly" set the shutter speed, and he's sitting over the for several minutes trying to get things right - while everyone is going "just take the !@#! picture already!".
It's like watching a Rube Goldberg machine...
Like the other poster said, having a *minimum* shutter speed would be a huge improvement, that's what I need.
0 upvotes
Rich
By Rich (9 months ago)
Damian
Love the phone, I'm too hard on my phones so I settled for a used N8 and have been thrilled with its quality. The only thing that disappoints is dynamic range. Have you ever thought of using the Pureview technology to enhance dynamic range?
0 upvotes
epdm2be
Mr. Rivers, what if you'd use the "sport"-mode? Wouldn't this prioritise shutterspeed over aperture? Because that's what I use (when available) when I require a higher shutter speed. You need enough light though. I asume that the 808 has at least the following scene-modes:
Sport: usually prioritize shutter speed
portrait: usually prioritize aperture
and various variations of these like nightshot (low shutterspeed, large aperture) etc...
0 upvotes
vlad0
A lot of work went into the 808.. as soon as you use the phone, you just know. I enjoy using it, its a great device.. it manages to "wow" me quite often, which is not easy in today's tech world.
One big thanks to the Nokia team for bringing this to the market..! Great work, keep it up.
2 upvotes
gl2k
By gl2k (9 months ago)
Nokia ... RIP. Too little too late.
It took Nokia years to understand how the smartphone market works. It's all about apps.
0 upvotes
vlad0
..or that is what apple/google want you to believe, since.. they make quite a bit of money out of the whole thing.
3 upvotes
sir_bazz
By sir_bazz (9 months ago)
If it really is all about the apps then isn't there a very strong chance that WP8 will be the game changer in the smartphone market?
From what I understand, any program coded for Win8 can be easily recompiled with WM8 as the new target and potentially giving Windows phones access to any app available to a Windows 8 desktop machine.
I dunno if it will really be all that easy once released but it sure sounds like a very big risk to the iPhone/Android app market.
0 upvotes
BrunoH
By BrunoH (9 months ago)
You do know that Apple (or more precisely Steve Jobs) said during the first iPhone release in 2007 that Apps were not necessary and that web pages would be enough :-)
No one knew how big deal apps would make for mobile phones. Nokia was late but so was everybody else to.
Now the current status of the Microsoft Marketplace is 110.000 apps and steady rising. All major apps is available for Windows Phone devices. So I don't think its to late for Nokia, not at all. especially as Windows Phone 8 will be able to run all windows 8 apps if the developers choose to compile for both platforms.
4 upvotes
Anonymous Gerbil
gl2k: Why do you bother coming here and telling people that you are not interested? Obviously other people are. Your input is simply not useful.
4 upvotes
smena8m
By smena8m (9 months ago)
Most of my friends, at work, feel strong need for laugh, when our american colleges starting to show their new apps on iPhone.
Most of normal people manage with apps which are coming with phone and Nokia have them all - even in Belle not only win based phones...
1 upvote
darthvader89
By darthvader89 (9 months ago)
Yes.. App store.. So many apps,
But so many stupid ones! I always liked the way nokia did mobiles, and i liked symbian.. But today it is just obsolete. With windows 8 or android, i would sell the iphone i use now and would get this pureview 808 immediately!
0 upvotes
epdm2be
@ sir_bazz: First it's WP8 not WM8. Secondly it's NOT that easy. Microsoft has made it VERY clear that you need to do quite a lot more than just recompile stuff between Win 8-intel and Win8-ARM (AKA Win8 RT) to get apps working. And that's not even taking Windows Phone 8 into account. Don't expect an Adobe Photoshop or Adobe Lightroom on your phone anytime soon.
However apps for WP7 will run (supposedly without modification) on WP8. But not vice versa (which is bad news for current WP7 users). Whom coincidentally has a 16Mpixel HTC Titan. Isn't that the highest Mpixel count on a phone prior to the 808? Has anyone ever compared that one? And what about Xperia's with Sony Exmor-sensors? Don't their compact cams use these too? What about them?
I guess DPreview must soon open a smartphone section. It wouldn't be bad I think. It would definitely draw more attention to the site and since Dpreview has a highly rated credibility.... I'm for it!
0 upvotes
ptox
By ptox (9 months ago)
@epdm2be: That depends. If you're using just the WinRT features, then porting between phone and tablet is mostly about layout and UX redesign.
Of course there are some WinRT features in Windows not available in WP, but these are unlikely to be relevant for most consumer applications.
As for tablets, can you point out where MS has said you need to do "a lot more" than just compile for the two architectures--again assuming that you're using WinRT?
Because that's not my understanding. Consider: if you build your tablet app in .NET or HTML5 using WinRT, it will run on both architectures.
How is building it in native code any different, besides the need to recompile?
(I feel the need to clarify the difference between WinRT, which is the new Windows runtime and analogous to Win32 -- and Windows RT, which is the name of the ARM-based Windows 8 OS that only runs WinRT, and not also Win32 like Intel-based Windows 8. Whoever came up with this nomenclature should be put in stocks...)
0 upvotes
mark moe
By mark moe (9 months ago)
Who makes the sensor? Nokia or another company??
1 upvote
vlad0
as far as i know, the sensor is co-developed by Nokia and Toshiba. Toshiba does the manufacturing. Identical situation to the Nokia N8.
0 upvotes
InTheMist
By InTheMist (9 months ago)
This is the reason that I'm leery about the future of compacts. I think that innovators like Nokia (who have lead the smartphone camera IQ for a while) and Apple will eventually put cameras in market segments like the Nikon 1 and below out to pasture.
If mirrorless wants to stay relevant, the focusing speed is going to have to be improved.
Nowever. If you're going to add a histogram, you'll eventually have to offer some sort of RAW support to put the final nail in the coffin of enthusiast-level compacts.
0 upvotes
vlad0
I think this has been a long time coming.. the N8 was a warning shot.. 808 and beyond would finish the job. Apple is a big one, like I said earlier, P&S makers are really lucky that Apple are not behind the wheel of this technology, otherwise they will destroy them, and rather quickly.
3 upvotes
peevee1
"If mirrorless wants to stay relevant, the focusing speed is going to have to be improved."
In m43 world, focusing speed is excellent for a year already.
0 upvotes
Ryan_Valiente
I bet you haven't used some of the latest mirrorless cameras have you ?
0 upvotes
alexzn
By alexzn (9 months ago)
Thank you Nokia for making the whole market segment of compact point and shoots obsolete, and for showing us what a cameraphone could do.
4 upvotes
Koulang
By Koulang (9 months ago)
No RAW file!
It would be perfect if RAW file has been included and OS have been Windows or Android!
2 upvotes
chlamchowder
I suspect speed is why there's no raw file functionality.
41 MP sensor, with 12 bits/pixel and 8 bits/byte = 61.5 MB
The fastest micro SD cards (smartphones usually take these) I could find were class 10 cards (about 10 MB/s sequential write). Waiting 6 seconds to write a raw file = not fun.
1 upvote
zodiacfml
By zodiacfml (9 months ago)
Congrats to him and his team for taking things to the next level. Compacts can get better but the companies are just unwilling (small exception to Sony).
1 upvote
Alphoid
By Alphoid (9 months ago)
Thank you for the thoughtful response. Personally, I'd buy one as soon as it has a real OS (not Symbian). I assume you're working on this.
1 upvote
sir_bazz
What shortcomings have you found with Nokia Belle FP1 ?
1 upvote
vlad0
Symbian 10.1 is actually quite good. You can.. call, text, email, tweet, facesmash, foursquare... navigate (GPS), googe maps, skype (voip), browse the internet, read the news.. whatever your heart desires. Its a full featured smartphone OS, in some ways, smarter than the more.. modern ones.
Try all of that on a Nikon 1
2 upvotes
JWest
By JWest (9 months ago)
Two words: no apps.
0 upvotes
sir_bazz
@JWest
Over 100K apps at the Nokia store as of Dec last year.
Sure there's a lot of gaps compared to Android but at least your pics will look better from the Nokia....and as were all photography enthusiasts here it's easy to tell which is more important.
3 upvotes
herula
By herula (9 months ago)
Most of all I need the fm radio app. Can't find that on iOS. So the whole apple thing is useless to me. Including billions of apps.
2 upvotes
JadedGamer
A FM radio app on iOS would need some external FM antenna hookup, since it does not have one built in. Then again, neither does the Nokia 808...
0 upvotes
sir_bazz
Hard to imagine being stuck with a mobile phone without an FM radio.
To me, little inclusions like that are more important than the screen res or the OS.
0 upvotes
exp1orer
By exp1orer (9 months ago)
not surprising at all... Nokia's slogan:- 'Connecting People' :)
2 upvotes
Val030456
By Val030456 (9 months ago)
Thank you! Very clear and useful comments.
1 upvote
alexpaynter
By alexpaynter (9 months ago)
Manufacturers often respond to criticisms but usually in a political way. This is however a well informed technical response from a design team that has considered a lot of variables. Kudos to Nokia.
23 upvotes
Paul B Jones
By Paul B Jones (9 months ago)
Just repeatin' what a few others have said but wow it is nice to see that kind of communication from a company.
14 upvotes
CameraLabTester
By CameraLabTester (9 months ago)
Damian Dinning should work for the big 2 camera makers.
He has more humane brilliance than the old wood out there...
15 upvotes
Anonymous Gerbil
Hah, the last thing the established players want is an employee that tells the simple truth!
7 upvotes
Total comments: 214
12
