Fujifilm has announced forthcoming firmware updates for its X-Pro1, X-E2 and X-E1 mirrorless interchangeable lens cameras, and for the X100S fixed-lens large sensor compact. Features promised include customizable Auto ISO, exposure preview in manual exposure mode, improved workflow for in-camera Raw conversion, and the ability to edit filenames in-camera. The X-Pro1 and X100S will also gain more accurate viewfinder framelines. The update for the X-Pro1 will be available on 5th December; those for the X-E1, X-E2 and X100S on 19th December.
We're hugely impressed by Fujifilm's continual updates and improvements to its cameras - it's fair to say that the X-Pro1 has been transformed since its launch into one of the most capable mirrorless models on the market. In this round of updates, the X-Pro1, X-E1 and X100S inherit many of the small tweaks first seen in the X-E2; users are likely to appreciate the addition of customizable Auto ISO in particular.
Quick summary of key changes:
  • Ability to edit the file name of shots taken in-camera
  • Improvements made to the in-camera RAW file converter process
  • More precise display of the exposure setting in live-view and histogram*
  • Improved playback view and file numbering for continuous shooting*
  • Ability to change aperture and shutter speed in AE lock*
  • Setting of the max and default ISO and minimum shutter speed in ISO AUTO*
  • Improve the cover range and accuracy of the bright frame in the OVF**
* Already implemented on X-E2
** X-Pro1 and X100S only
Jump to:
Press Release - X-Pro1:
Further firmware upgrade available soon for FUJIFILM’s flagship X-Pro1 camera
FUJIFILM Corporation (President: Shigehiro Nakajima) will be releasing another new firmware upgrade for its flagship Fujifilm X-Pro1 compact system camera on November 28th which will offer users enhancements to operability and functionality.
This latest firmware upgrade is being released in response to customer demand and will offer X-Pro1 users the chance to update their model to incorporate functionality available on the most recent X series cameras launched in October 2013.
The X-Pro1 is set to continue as the company’s flagship X series model, and Fujifilm is striving to keep the level of technology offered on this product as up to date as possible so that purchasers of the X-Pro1 will have greater longevity of use.
Release date of the new firmware
5th December 2013 (Thu.) GMT 05:00/JST 14:00
Firmware version
FUJIFILM X-Pro1: Ver. 3.10
Main contents of the firmware update
1.  Improve the cover range and accuracy of the bright frame in the OVF
The cover range of the bright frame displaying the shooting area in the optical viewfinder has been improved so that a field of view closer to the actual image can be checked. By maintaining the position of the bright frame with parallax compensation during AF lock, the shooting area can be checked even when letting go of the shutter release.
2. See the exposure setting in live-view and histogram
The images and histogram will reflect current exposure levels (with the shutter speed and aperture set during manual exposure also displayed on the image). In scenarios where the live view and the final shot will appear differently, eg: when using flash, this setting can be turned off.
3. Aperture and shutter speed can be changed once AE lock is selected
The aperture or shutter speed can be changed while maintaining exposure (EV value) with the AE lock button. The photographer has the ability to tweak settings down to the very last moment before shooting.
4. The default and maximum sensitivity and minimum shutter speed can be set when ISO AUTO is selected
When selecting “AUTO” in the ISO setting, users can also set standard ISO, Maximum ISO and a low-speed shutter limit. The Low-speed shutter limit has been extended to 1/500 seconds.
5. New fuctionality allowing you to edit image filenames
An image filename (DSCF***) is automatically allocated to each picture when shooting, this can now be changed to your filename of choice.*1 This added functionality is useful when organising the images after shooting, and sorting the images into groups.
*1 It can be changed to a 4-letter filename when selecting “sRGB” and a 3-letter filename when selecting “Adobe RGB” for the color space.
6. Change of numbering for images shot using continuous shooting
When shooting using continuous shooting, only the first image is currently displayed in full screen and subsequent frames are displayed in small on the bottom right, and the file number was set as “S+7-digit number”. With the new firmware, all frames in continuous shooting are displayed as full screen shots in playback. The file number has also been altered to follow numerically as per standard single shots, thereby allowing uniform management of images after shooting.
7. Improvement of RAW file conversion function
When developing RAF images in-camera using the built-in RAW file converter, the firmware upgrade improves the flow by taking you back to the original RAF image once the conversion has been done, whereas before it left you with the converted JPG file on screen and the user had to go back to the next RAF file manually.
Details on improvements 2, 3, 4 and 5 are available in the operation manual on the support page below.
Please visit the following URL for details on other changes.
Firmware download
http://www.fujifilm.com/support/digital_cameras/software/#firmware
* This firmware is exclusive to the FUJIFILM X-Pro1.
Press Release - X-E1, X-E2 and X100S:
Firmware updates available soon for the FUJIFILM X-E1, FUJIFILM X100S, FUIFILM X-E2
FUJIFILM Corporation (President: Shigehiro Nakajima) will be releasing firmware upgrades for its premium X-E1, X100S and X-E2 models to enhance operability and functionality.
This latest firmware upgrade is being released in response to customer demand and will offer users the chance to update their models to incorporate functionality available on the most recent X series cameras launched in October 2013.
Fujifilm is striving to keep the level of technology offered on these products as up to date as possible so that purchasers of the X series models will have greater longevity of use.
19th December 2013 (Thu.) GMT 05:00/JST 14:00
Firmware version
FUJIFILM X-E1 :   Ver. 2.10
FUJIFILM X100S :  Ver. 1.10
FUJIFILM X-E2 :  Ver. 1.10
Contents of the firmware update
For an overview of improvements to each model please refer to the list below.
● Updates now available for the X-E1, X100S and X-E2
1. New functionality allowing you to edit image filenames
2. Improvement of RAW file conversion function
● Updates available for the X-E1 and X100S
3. See the exposure setting in live-view and histogram
4. Change of numbering for images shot using continuous shooting
5. Aperture and shutter speed can be changed once AE lock is selected
6. The default and maximum sensitivity and minimum shutter speed can be set when ISO AUTO is selected
● Updates available for the X100S
7. Improve the cover range and accuracy of the bright frame in the OVF
Details by model
Update X-E1 X100S X-E2
1. Ability to edit the file name of shots taken in-camera  Yes    Yes  Yes
2. Improvements made to the in-camera RAW file converter process  Yes  Yes  Yes
3. More precise display of the exposure setting in live-view and histogram  Yes  Yes done
4. Improved playback view and file numbering for continuous shooting  Yes  Yes done
5. Ability to change aperture and shutter speed in AE lock  Yes  Yes  done
6. Setting of the max and default ISO and minimum shutter speed in ISO AUTO  Yes  done done
7. Maintain live view of framed area with the parallax compensation during AF  * Yes  *
* These models do not have an optical view finder
Details on improvements 1, 4, 5 and 6 are available in the operation manual on the support page below.
Firmware download
** This firmware is exclusive to the FUJIFILM X-E1, X100S and X-E2 models. Firmware is software that controls the camera body.
