Photokina 2008: Sigma has today announced a new HSM version of its popular 24-70mm F2.8 EX DG lens. This large aperture standard zoom is considerably more compact than its predecessor, thanks to a brand new optical design which features 14 elements in 12 groups, including three aspherical, one ELD and two SLD elements. The HSM focusing motor promises fast and silent focusing coupled with full-time manual focus, and the minimum focus distance is 38cm allowing a maximum magnification of 1:5.3. The lens will be available in Sigma, Canon, Nikon, Pentax and Sony mounts.
Jump to:
Press Release:
24-70mm F2.8 EX DG HSM
The compact large aperture standard zoom lens equipped with HSM
The Sigma Corporation is pleased to announce the new 24-70mm F2.8 EX DG HSM. This large aperture standard zoom lens covers focal lengths from 24mm and is housed in compact construction.
The latest optical design provides an overall length of 94.7cm /3.7inch. It is ideal for general photography such as snapshots, portraiture and landscapes. The Super Multi Layer Coating reduces flare and ghosting. ELD (Extraordinary Low Dispersion) glass, two SLD (Special Low Dispersion) glass elements and three aspherical lenses provide excellent correction of all types of aberrations.
 Superior optical performance is ensured throughout the entire zoom range. This lens incorporates HSM (Hyper Sonic Motor), ensuring a quiet and high speed AF as well as full time manual focusing capability. This lens has a minimum focusing distance of 38cm/15in and a maximum magnification ratio of 1:5.3.
The rounded 9 blades diaphragm creates an attractive blur. It is possible to attach the included petal-type hood to block out extraneous light.
Features:
  • Large aperture standard zoom lens
  • ELD and SLD glass provides excellent correction of all types of aberrations
  • Super Multi Layer Coating reduces flare and ghosting
  • Equipped with HSM ensuring quiet and high speed AF
  • The rounded 9 blade diaphragm creates an attractive blur
24-70mm F2.8 EX DG HSM specifications
Focal length 24 - 70mm
Angle of view 84.1°-34.3°
Maximum aperture F2.8
Minimum aperture F22
Lens Construction
• 14 elements/12 groups
• 1 ELD (Extraordinary Low Dispersion) glass
• 2 SLD (Special Low Dispersion) glass elements
• 3 Aspherical elements
Number of diaphragm blades 9 (rounded)
Minimum focus 38 cm (15 in)
Maximum magnification 1 : 5.3
AF motor type • Ring-type HSM (Hyper Sonic Motor)
• Full-time manual focus
Image stabilization • None
Filter thread • 82 mm
Supplied accessories Petal-type lens hood
Case
Optional accessories
• DG UV 82 mm
• DG WIDE CIRCULAR PL 82mm
Weight TBD
Dimensions 88.6mm diameter x 94.7mm length
(3.5 x 3.7 in)
Lens Mount Sigma, Canon, Nikon, Pentax, Sony
