Pentax has today announced a new addition to the S series with the six megapixel Optio S6. The aluminum alloy-bodied compact is even slimmer than its siblings at just 19 mm wide and sports a 2.5-inch Beau-Reflective monitor, which means it can be viewed outdoors in bright light. It also offers simultaneous display of mode icons, a 640x480-pixel movie function with anti-shake (although the format DivX MPEG-4 is not supported by Macs) plus tracking AF. It is available this month.
Press Release:
Incorporating a newly developed, compact 3X optical zoom lens, the PENTAX OptioS6 packs 6.0 effective megapixels and a large 2.5-inch LCD into exceptionally slim dimensions.
Pentax Optio S6
Through taking an entirely new approach to lens design, PENTAX presents the OptioS6 with an impressively slim body depth of a mere 19mm. Yet despite being exceptionally slim, the OptioS6 also features a powerful 3X optical zoom lens and delivers the shooting performance of 6.0 effective megapixels.
Major features
1. A new design for new, slimmer dimensions
A fresh approach to the design of the lens unit including the PENTAX Sliding Lens System* has enabled the OptioS6 to be created with exceptionally compact dimensions. In fact, through the use of glass-molded aspherical lenses which are concave on both sides, a thinner CCD, a fully flat backside of the lens unit and other advances, the entire lens unit has a depth that is a full 2mm thinner than our conventional unit. High-level engineering expertise has also been applied to influencing the dimensions of the body, with high-density mounting and the strategic use of internal space realizing a body depth of only 19mm.
*PENTAX’s proprietary lens system which offsets the central lens groups from the optical lens axis and houses the lens in two steps in the lens cylinder for minimized overall body depth.
2. Large, easy-to-view LCD monitor
Despite its new slim body design, the OptioS6 incorporates a large, 2.5-inch LCD monitor that offers the clarity of 232,000 total pixels. And because it is a Beau-Reflective monitor (low-reflection type) with a built-in backlighting mechanism, it can be viewed easily and clearly even outdoors in sunny weather. As a result, the OptioS6 makes it easy to compose shots, playback recorded images for confirmation and select functions through smooth menu navigation.
3. High image quality
Employing a 1/2.5-inch primary color CCD, the OptioS6 delivers outstanding 6.0 effective megapixel performance. It also boasts an smc PENTAX lens that makes use of PENTAX original coating to achieve minimized ghosting and flare, a high-performance ASIC* that delivers refined image processing, and new improved noise reduction with the power to deliver true-to-life color gradation and rich texture, even at high sensitivities.
*Application Specific Integrated Circuit.
4. Mode Palette displays all icons at once
The Mode palette enables the display of multiple mode icons for shooting and playback on the LCD monitor simultaneously – a factor that has earned it praise on other Optio models for the level of operational ease this entails.
On the OptioS6, it allows the user to select from the diverse range of 15 shooting mode icons and 14 playback icons in an instant. And because the Palette mode display is translucent, the user can make his or her selection while still being able to view the image on the screen.
5. Stylish design that exudes a sense of quality
Featuring a combination of fine spindle treatment, a unique blast process effect, and a metal band at its upper end, the aluminum alloy exterior of the OptioS6 exudes a sense of high quality while also feeling attractive to the touch. Plated parts have been added for the grip and the area surrounding the lens – adding an appealing luster which accentuates the camera’s overall elegance. And the connectors and battery compartment have all been grouped together on one side to minimize protrusions and maintain the clean, attractive lines. Stylish enough to be worn as an accessory, yet delivering the power to take impressive images, the OptioS6 is equally ideal for travel, leisure, snapshots and business use.
6. Movie anti-shake function for high-quality action
Offering movie shooting with 640x480 recording pixels at a swift rate of 30fps (frames per second), the OptioS6 delivers smooth movies with camcorder quality. The OptioS6 also offers the advantage of DivX MPEG-4* image compression that makes it possible to shoot movies of a longer duration, while a useful movie anti-shake** function makes results noticeably more stable.
* Movie playback is not supported by Macintosh.
** Selection of the movie anti-shake function results in an angle of view narrower than that experienced in normal shooting.
7. Tracking AF
Not all subjects are willing to stand still and say “Cheese!” Fortunately, the OptioS6 features tracking AF* which can track a moving subject around the frame, while maintaining precise focus for pin-sharp results. Adding further convenience, this mode is automatically activated upon selection of Sport and Pet modes.
* Tracking AF continually detects both horizontal and vertical movement of the main subject to ensure sharp focus at the desired moment. Confirmation of the focus area can be done on the focus frame on the LCD monitor.
8. Other features
1) High-speed continuous shooting at up to 1.6 frames per second
2) Approx. 23MB built-in memory; SD memory card compatible
3) Candlelight mode allows high-sensitivity shooting at a Standard Output Sensitivity of 800.
4) Built-in AF spotbeam (on/off switching possible)
5) Frame composite function allows frames to be added at time of shooting
6) Pan focus function for easy snapshots
7) Convenient image rotation function for easy confirmation of vertical shots
8) Standard image viewer, ACDSee for PENTAX software
9) FotoNation’s red-eye compensation function for flash shots
10) UBS2.0 (HI-SPEED) compatible
11) DPOF function, Exif Print, and PRINT Image Matching III compatible
12) PictBridge compatible
Pentax Optio S6 specifications
Pentax Optio S6
• 1/2.5" Type CCD
• 6.4 million pixels total
• 6.0 million effective pixels
Image sizes • 2816 x 2112
• 2560 x 1920
• 2304 x 1728
• 2048 x 1536
• 1600 x 1200
• 1024 x 768
• 640 x 480
Movie clips • 640 x 480 @ 30 fps
• 320 x 240 @ 30 fps
• With sound, movie anti-shake, limited by the capacity of the memory card
File formats
• Still: JPEG
• Movie: AVI (MPEG-4)
• Sound: WAV
Lens • 37.5 - 112.5 mm (35 mm equiv) 3x optical zoom
• F 2.7 - 5.2
Digital zoom Up to 4x
Focus TTL contrast detection autofocus system with AF spotbeam
AF area modes • 5-point multi AF
• Tracking AF switchable
• Spot AF
AF assist lamp Yes
Focus distance • Normal: 0.4 m (1.31ft) - infinity
• Macro: 0.15 m - 0.5 m (0.49 ft - 1.64 ft)
• Pan focus: 1.1m (3.6 ft) to infinity at wide-angle setting/ 4.5m (15 ft) to infinity at telephoto setting
Metering • Multi-segment
• Center-weighted
• Spot
ISO sensitivity • Auto
• ISO 64
• ISO 100
• ISO 200
• ISO 400
Exposure compensation • +/- 2EV
• 1/3 EV steps
Shutter speed 1/2000 - 4 secs
Modes Program
Scene modes
• Auto
• Night Scene
• Panorama assist
• Landscape
• Flower
• Portrait
• Sport
• Surf & Snow
• Food
• Pet
• Text
• Candlelight*1 **2
• Frame composite*
*1 Recorded size is fixed to 3M (2048 x 1536)
**2 Sensitivity is set at 800.
White balance • Auto
• Daylight
• Tungsten
• Fluorescent
• Manual
Self timer Yes
Continuous shooting Yes
Flash • Built-in
• Modes: Auto, on, off, soft flash, red-eye reduction
• Range: Approx. 0.15 m - 5.1 m (0.49 ft -17 ft) at 5.8 mm, Sensitivity
• Approx. 0.4 m -2.7 m (1.31 ft -8.9 ft) at 17.4 mm, Sensitivity Auto
Viewfinder No
LCD monitor • 2.5" TFT LCD
• 232,000 pixels
Connectivity • USB
• AV out
• DC in
Print compliance • DPOF
• EXIF 2.2
• PictBridge
Storage • SD card
• 23 MB internal memory
Power • Rechargeable D-LI8 lithium-ion battery
• AC adapter optional
Weight • 100 g (3.5 oz) (no battery or card)
• 120 g (4.2 oz) (loaded and ready)
Dimensions 86 x 54 x 19 mm (3.4 x 2.1 x 0.7 in)
