Sigma has announced the 24-105mm F4 DG OS HSM - an image stabilized normal zoom for full frame DSLRs. The 24-105 becomes the latest addition to the company's 'Art' series of lenses designed to offer high image quality. The lens features a 19 element/14 group design including Sigma's FLD glass and both single- and double-sided aspherical elements which the company says will minimize aberrations. It has a minimum focusing distance of 45cm throughout its range, giving a maximum magnification of 1:4.6. Prices and availability have yet to be announced.
Jump to:
Press Release:
Sigma Corporation announces new, optically stabilized 24-105mm F4 DG OS HSM lens
Standard zoom with versatile focal range, features stabilization, outstanding image quality
RONKONKOMA, NY — October 16, 2013 — Sigma Corporation of America (www.sigmaphoto.com), a leading researcher, developer, manufacturer and service provider of some of the world's most impressive lines of lenses, cameras and flashes, today announced its newest addition to the Sigma Art line of lenses for full-frame cameras, the 24-105mm F4 DG OS HSM
True to its categorization as a Sigma Art lens, the new 24-105mm F4 DG OS HSM is designed for artistic expression and top-notch image quality. This versatile lens covers the basic shooting range from wide to medium tele with an inner focusing system that eliminates front lens rotation, enhancing the lens stability and allowing the use of circular polarizing filters. It also boasts a constant aperture of F4, and contains Sigma’s proprietary Optical Stabilizer (OS) technology to compensate for camera shake. Moreover, it was designed to surpass the required quality inspection of every Global Vision lens with Sigma’s own modulation transfer function (MTF) “A1” measuring system to create new optical standard to align with the high-spec cameras on today’s market.
“For many years, Sigma users have been seeking a standard zoom lens in this range,” said Mark Amir-Hamzeh, president of Sigma Corporation of America. “The 24-105mm F4 DG OS HSM is yet another example of Sigma listening to its users and delivering new and innovative products with the highest image quality.”
Amir-Hamzeh added that this new lens combines the largest possible fixed aperture to zoom ratio that will maintain optimal integrity for many kinds of photography, including landscapes, architecture, portraiture and still-life. With a minimum focusing distance of 45cm and a maximum magnification ratio of 1:4.6, this lens is also excellent for close-up photography.
High-performance glass elements, including SLD, FLD, which is equal to fluorite, and glass-molded single- and double-sided aspheric lenses have been included into the optical system to prevent aberration, field curvature, distortions and color aberration. The 24-105mm F4 DG OS HSM lens is also able to suppress chromatic aberration very effectively at the telephoto-end, and can achieve superior image quality throughout the zoom range. Unlike lenses with similar specifications, this lens overcomes low peripheral brightness. Although it is designed for full frame cameras, it also works with APS-C sensors, giving an increase to focal length.
The lens’ Hyper Sonic Motor (HSM) ensures a silent, high-speed auto focus function and enables full-time manual focusing capability. The 24-105mm is also compatible with Sigma’s USB dock allowing photographers to update its firmware and change focus parameters using Sigma's Optimization Pro software. It is also compatible with Sigma’s recently announced Mount Conversion Service.
Sigma 24-105 F4 DG OS HSM specifications
Principal specifications
Lens typeZoom lens
Max Format size35mm FF
Focal length24–105 mm
Image stabilisationYes
Lens mountCanon EF, Nikon F (FX), Sigma SA Bayonet, Sony/Minolta Alpha
Aperture
Maximum apertureF4
Minimum apertureF22
Number of diaphragm blades9
Aperture notesRounded diaphragm
Optics
Elements19
Groups14
Focus
Minimum focus0.45 m (17.72)
Maximum magnification0.22×
AutofocusYes
Motor typeRing-type ultrasonic
Full time manualYes
Focus methodInternal
Distance scaleYes
DoF scaleNo
Physical
Weight885 g (1.95 lb)
Diameter89 mm (3.5)
Length109 mm (4.29)
Zoom methodRotary (extending)
Filter thread82.0 mm
Hood suppliedYes
