Automating Photoshop
What if I told you that by the end of this article I could drastically boost your Photoshop productivity? Interested? That's actually not an exaggeration if you've never taken advantage of Photoshop's actions and batch processing tools. If you find yourself repeatedly performing the same (often mindless) tasks in Photoshop one step at a time, I'm going to show you a better way to work.
Actions are essentially a way to have Photoshop perform a series of predetermined steps on an image. You create them by first manually performing steps for Photoshop to record. But don't worry, Photoshop isn’t timing you when you record an action. No matter how long you take to perform the steps, once the action is created Photoshop will execute it as quickly as possible, which will always be faster than we mere humans could do it. Most Photoshop commands can be included as part of an action, and I'll show you how you can incorporate those that cannot.
We'll explore how to:
- Create a basic action
- Create an action with a modal control
- Create an action with a stop
- Batch process images
- Create a droplet
- Use Photoshop's Image Processor
In this article I'll be using Photoshop CS5. While Photoshop Elements cannot be used to create actions, it can import and run actions created in CS5.
Creating a basic action
Actions live in the Actions panel, available if you go to Window>Actions. Without creating a single action of your own you’ll see the list of default actions that ship with Photoshop. It's important to note that an action must reside in a folder, called an action set. You can name both the Action Set as well as the individual actions. Because Action Sets are the primary means of sorting and finding your actions, I recommend giving them descriptive names that relate to the actions contained within them.
Let's begin by creating a new action set to store our custom actions. Click the folder icon at the bottom of the Actions panel (shown below). A dialog then appears in which you name this new set. In the examples below I typed 'Ellen’s Actions'. This set is where I will store the actions I'll be demonstrating in this article. As you start to create additional actions on your own, however, I recommend that you create several distinct sets that are geared towards specific techniques such as resizing, editing or prepping for output and name them accordingly.
In this action we're going to add a copyright watermark to an image. Open an image in Photoshop (the simplest, though not the only way to begin) and then click the New Action icon (shown above). Because we're going to create a white watermark to use on images that are 1280 pixels wide, I name the action accordingly (shown below).
I've given the action a descriptive name and chosen to house it inside the 'Ellen's Actions' set. Notice that you can also assign a Fn key to invoke the action, as well as give it a color label. |
Press the Record button. To create the watermark perform these steps:
5. Go to Layer>Flatten Image.
6. Press the Stop recording icon.
7. Close your image (without saving it).
That's it. You’ve created a watermark action. To test it, open the same image you began with, select your newly created action from the Actions panel and click the Play button.
Before we go any further, you should know that by default the actions sets you create are stored in Photoshop's preferences. Should those get reset or corrupted, you've lost your actions. Fortunately you can save action sets to a more easily accesible location on your hard drive, which I strongly recommend.
Doing so allows you to export them to another computer, share them with others (including Elements users) and easily bring them into a newer version of Photoshop should you upgrade.
Click here to continue reading our Automating Photoshop article...
Comments
