Mamiya has announced the first medium format digital SLR, the 22 megapixel Mamiya ZD and a digital back of the same name. The ZD has a large 36 x 48mm sensor, is compatible with 645AF lenses and has a 1.8-inch LCD. It stores 12-bit colour images on to either CompactFlash or SD cards. The Mamiya ZD Back realizes full interactive communications through the MSCE (Mamiya Serial Communication for External) to bring out the best of all the advanced functions of these cameras.
Jump to:
Press Release:
Mamiya Lens-interchangeable Digital SLR Camera & Mamiya Digital Back
We are very proud to announce development of a lens-interchangeable digital SLR camera “Mamiya ZD” and a digital back “Mamiya ZD Back”.
Since 1940, Mamiya has been pursuing to design and realize high images quality, high reliability and ease of use. Mamiya cameras ever produced have been well received by professional photographers and advanced amateurs, and that has made Mamiya the leader in high-end imaging. Inheriting the high quality, in order to meet the needs of digital photographers, the Mamiya ZD and Mamiya ZD Back are being created.
The Mamiya ZD is a lens-interchangeable digital SLR, and accepts the range of the Mamiya 645AF interchangeable lenses. The Mamiya ZD Back is a digital camera back compatible with the Mamiya 645AFD which is favourably reputed in the market and the Mamiya RZ67Pro-IID which just has become available.
The Mamiya ZD and the Mamiya ZD Back come with a 36x48mm, 22 million-pixel CCD and generate stunning high resolution images with both rich and smooth tonal ranges. The 14 bit A/D (Analog to Digital) conversion records information as 12-bit per colour channel. The ASIC (Application Specific Integrated Circuit), which was developed exclusively for the Mamiya ZD and Mamiya ZD Back, processes in realtime, optimisation of image data from CCD.
With the built-in slots for media cards, the Mamiya ZD and the Mamiya ZD Back can be used without tether. Low-pass filter is optionally available and a photographer can shoot with or without it depending on shooting conditions. An innovative cartridge type low-pass filter makes it a snap to exchange the filters (Mamiya ZD only). For these models Mamiya is developing “Mamiya Digital PhotoStudio” software which provides a simple, yet powerful interface from image capture & editing, to processing. When connected to a computer by an IEEE1394 cable, many functions of the cameras can be operated from computer.
Mamiya is committed to develop these new models and desires to bring them as soon as possible to you!
This press release is based on the current plans and beliefs of Mamiya-OP Co., Ltd. and involves known and unknown potential risks and uncertainties.
Mamiya ZD:
Type: Lens-Interchangeable Digital SLR AF/AE Camera
Features: 36x48 mm 22 million pixel CCD, Mamiya 645AF Lenses compatible
Mamiya ZD Back:
Type: Digital Back
Features: 36x48mm 22 million pixel CCD, Compatible with Mamiya 645AFD & Mamiya RZ67Pro-IID
Mamiya ZD specifications
• Full Frame RGB square-structured 48 x 36 mm CCD
• 22 million pixels total
• 22 million effective pixels
Image sizes • Large
• Medium
• Small
Color Matrix • Adobe RGB
• sRGB
File formats • RAW
• Simultaneous recording
Lens mount 645AF
IR cut filter Built-in
Low-pass filter Optional (rechargeable)
Focus TTL Phase Difference Detection
Metering • Average
• Center-weighted
• Spot
• Variable ratio
ISO sensitivity ISO 50 - 400
Auto bracketing 2.3 or 5 frames (single and continuous)
Shutter speed 30 - 1/4000 sec
• Aperture priority
• Shutter priority
• Program AE
• Manual
• Bulb
White balance
• Auto
• Daylight
• Overcast
• Shade
• Fluorescent light
• Tungsten
• Preset 1
• Preset 2
• Fine Adjustment
• Colour temperature setting
Continuous shooting 1.5 fps up to 11 shots
LCD monitor • 1.8-inch LCD
• 130,000 pixels
Connectivity • AV out
• IEEE 1394
Storage CompactFlash and SD card
Power Rechargeable lithium ion battery
Weight (no batt) 1200 g (42.3 oz)
Dimensions 162 x 152 x 91 mm (6.4 x 6 x 3.6 in)
Additional images
