Panasonic has announced its Lumix DMC-FZ1000 superzoom camera, which features a 1"-type CMOS sensor and F2.8-4.0, 25-400mm equivalent lens. The sensor is not only the same size as on Sony's Cyber-shot DSC-RX10 - it's also the same resolution (20.1MP). The lens doesn't have a constant aperture like that of the Sony but it has a greater reach, topping out at 400mm rather than 200mm. The lens uses Panasonic's Depth from Defocus technology, which promises faster focusing.
The FZ1000 features both a fully articulating 921k dot LCD as well as a high resolution (2.36M dot) OLED viewfinder. A ring around the lens barrel can be used to zoom or manually focus. A full suite of manual controls are available, including highlight/shadow correction and in-camera Raw conversion.
The big story on the FZ1000 is really its ability to record 4K video (that's 3840 x 2160) at 30p, with a bit rate of 100Mbps. The high video resolution allows users to grab 8MP stills from a video clip. The FZ1000 can also record HD video at 1920 x 1080 (60p, 60i, 24p) and 1280 x 720 (30p). While there's a stereo mic built into the FZ1000, serious videographers can attach an external mic using a standard 3.5mm port.
As with most of Panasonic's high-end cameras, the FZ1000 has built-in Wi-Fi and NFC. The camera can be controlled from your smartphone, and image sharing is easy, as well.
The Lumix DMC-FZ1000 will be available this summer for $899 / £749.99.
Jump to:
Press Release:
Panasonic Announces LUMIX DMC-FZ1000 – The World’s First Digital Compact Camera with 4K Video Recording Capability
One-Inch, High Sensitivity MOS Sensor and 16x Optical Zoom for the Ultimate Picture Quality
NEWARK, NJ (June 12, 2014) - Panasonic announced today the new LUMIX DMC-FZ1000 (FZ1000) -- the world’s first digital compact camera to offer 4K video recording capability*.  The FZ1000 boasts a one-inch, High Sensitivity MOS Sensor and 4K video recording capability. The latest member of the popular LUMIX FZ series, the FZ1000 will be available at www.shop.panasonic.com and select channel partners in late July with an MSRP of $899.99.
*For a digital compact camera as of June 12, 2014
The integration of a newly developed LEICA DC VARIO-ELMARIT 16x optical zoom lens achieves high resolution edge to edge. It also produces stunningly beautiful defocus together with the large-sized MOS Sensor.
The 1-inch large 20.1-megapixel High Sensitivity MOS Sensor dramatically improves S/N (signal to noise) ratio, making it possible to capture a clear image with minimum noise even when it is shot at a high ISO. The Venus Engine is also newly developed to feature multiple noise reduction systems such as Multi Process NR, Random Filter and Aperture Filter, to achieve high color reproduction and high image quality with a natural look.
The FZ1000 incorporates 4K (QFHD 4K: 3840x2160, up to 30 fps in MP4) video recording capability for the first time with a digital compact camera*1. Panasonic is also proposing a new solution to capture 3840x2160 8-megapixel equivalent images from the 4K video footage which is normally difficult to photograph. Also, videos can be recorded in full-HD 1,920 x 1,080 60p in AVCHD Progressive (MPEG-4 / H.264) format or MP4 at 60p. A powerful 16x optical zoom with 5-step speed control enables smooth zoom adjustment even while video recording. The 5-axis HYBRID O.I.S. (Optical Image Stabilizer)+ with Active Mode effectively compensates for vibration.  Creative Video mode, High Speed video in full-HD at 120fps, Time Lapse Shot and Stop Motion Animation are all available for a variety of video effects..
The FZ1000 also features DFD (Depth From Defocus) technology, for its focusing accuracy and improved Light Speed AF of approx. 0.09 sec*2. Together with the quick start-up time of approx.0.66 sec, the DMC-FZ1000 never misses a  shooting opportunity.   High speed burst shooting can be shot at 12 fps in 20.1-megapixel full resolution. It also offers a max.1/4,000 (mechanical) and 1/16,000 (electronic) shutter speed.
The FZ1000 boasts a high-precision, high-speed OLED (Organic Light-Emitting Diode) LVF (Live View Finder). With 0.39-inch 2,359k-dot high resolution in 4:3 aspect ratio, the new LVF boasts approx.1.88x / 0.7x (35mm camera equiv.) magnification and 100% field of view. The 3.0-inch 921k-dot free-angle LCD with its wide-viewing angle rotates 180° to the side and tilts 270° up and down. Operability is also improved with a newly added zoom lever, zoom ring and drive mode dial for more intuitive operation.  For more creative freedom, Creative Control, Creative Panorama and Photo Style are available.
The FZ1000 integrates Wi-Fi® connectivity (IEEE 802.11 b/g/n) with NFC (Near Field Communication) to offer a more flexible shooting experience and instant image sharing with a simple operation. The FZ1000 also comes with a 3.5mm jack for an external microphone connection. In addition, RAW data can be processed in camera.
*1 As of June 12, 2014
*2 Based on the CIPA standard, when using Live View Finder.
1. Bright Leica DC Lens 25-400mm F2.8-4.0
Panasonic newly developed LEICA DC VARIO-ELMARIT lens system (F2.8-F4.0) with 16x optical zoom (35mm camera equivalent: 25-400mm). Comprised of 15 elements in 11 groups, including 4 ED lenses and 5 aspherical lenses with 8 aspherical surfaces, this advanced lens unit achieves high MTF value.
2. Large 1-inch 20.1MP MOS Sensor for Amazing Defocus Control
The DMC-FZ1000 incorporates a 1-inch large High Sensitivity MOS Sensor with 20.1-megapixel high resolution. The new 1-inch sensor is 4x larger than conventional 1/2.3-inch sensor in size. This new large MOS Sensor improves S/N ratio, resulting in dramatic reduction of noise even when shooting at ISO 12,800.
The Venus Engine image processor was developed for the DMC-FZ1000 to dramatically boost its performance with a new quad-core CPU providing high speed signal processing required for rich 4K video recording . The advanced Multi-process NR (Noise Reduction) applies effective noise reduction and detail processing according to each component frequency. Plus, newly added Random Filter granulates chromatic noise to be blended into the image even more naturally.
3. The World’s First Digital Compact Camera Recording High Quality Video in 4K
The LUMIX FZ1000 is not only for capturing still images but also high quality video in 4K. It features outstanding 4K video recording capability (QFHD 4K: 3840x2160, up to 30 fps (NTSC) / in MP4*1. Users can enjoy recording video in ultra high definition and even grab an 8-megapixel frame as still image. After recording video in 4K, users can cut out a single frame to choose the best still image in rich resolution of 3840 x 2160 pixels.  The FZ1000 should be used with UHS Speed Class 3 (U3).  The UHS Speed Class 3 (U3) guarantees a constant minimum write speed of 30MB/s to respond to market needs for 4K video.
*1 4K video can be recorded up to 29 minutes 59second. Use SDXC/SDHC Memory Card compatible with UHS Speed Class 3 (U3) when using high bitrate video recording mode of 100 Mbps or greater.
4. Super-fast LUMIX DFD Focusing Technology
For even faster response and higher mobility, the FZ1000 newly integrates a dedicated motor into the focus system to achieve extremely fast focusing. In addition, the Light Speed AF is further enhanced with an adoption of DFD (Depth From Defocus) technology which even shortens the time to set focus. It calculates the distance to the subject by evaluating 2 images with different sharpness level while consulting the data of optical characteristics of the current lens in a moment. As a result, the DMC-FZ1000 achieves ultra high speed AF of approx.0.09 sec*2 at wide end and even approx. 0.17 sec at tele-end.*3 Together with the quick start-up of approx.0.66 sec and short release time lag, the DMC-FZ1000 never lets photographers miss fleeting shooting opportunities.
*3 Panasonic in-house examination (infinity to 2m shooting time lag)
5. Integrated Smartphone/Tablet Wi-Fi® for Remote Imaging Control
The FZ1000 integrates Wi-Fi® connectivity (IEEE 802.11 b/g/n) with NFC (Near Field Communication) technology camera to offer more flexible shooting experience and instant image sharing. With the Panasonic "Image App", remote shooting of both stills and video is possible by using the smartphone/tablet for a remote shutter with a monitor. You can release the shutter, zoom, focus and set shutter speed, aperture, exposure compensation with a smartphone / tablet.
6. Other Features
3cm Macro Shooting
Stunning macro shots can be shot with minimum focusing distance of 3cm.
Highlight/Shadow Control
The Live View function is also advanced digitally making it possible to adjust highlight / shadow separately with the front/rear dial. 3 patterns of settings can be customized in addition to 3 patterns of preset.
RAW data development in Camera
The FZ1000 is capable of processing RAW images in camera.
Level Gauge
The DMC-FZ1000 is equipped with Level Gauge to detect the horizontal / vertical angle of view.
 iA+ (Intelligent Auto Plus) Mode for Photo and Video
For beginners, iA (Intelligent Auto) mode supports taking beautiful pictures with a variety of shooting-assist functions including AF Tracking, Intelligent Scene Selector, Face Recognition, Intelligent ISO Control and Food Recognition.
Optional Accessories
A GN58 powerful External Flash (DMW-FL580L) is newly added to the LUMIX optional accessories which allow high speed charging of approx.1.7 sec. Not only wireless control but also LED video light functions are available. The Stereo / Shotgun Microphone (DMW-MS2) which enables stereo/shotgun switch. The 62mm diameter of ND Filter (DMW-LND62), PL Filter (DMW-LPL62) and MC Protector (DMW-LMCH62) are also offered for more creative freedom.
Panasonic Lumix DMC-FZ1000 specifications
Price
MSRP$899 / £749
Body type
Body typeSLR-like (bridge)
Body materialMetal, composite
Sensor
Max resolution5472 x 3648
Other resolutions4864x3648, 5472x3080, 3648x3648, 3888x2592, 3456x2592, 3840x2160, 2592x2592, 2736x1824, 2736x1824, 2432x1824, 1824x1824, 1920x1080
Image ratio w:h1:1, 4:3, 3:2, 16:9
Effective pixels20 megapixels
Sensor photo detectors21 megapixels
Sensor size1″ (13.2 x 8.8 mm)
Sensor typeCMOS
ProcessorVenus Engine
Color spacesRGB
Color filter arrayPrimary color filter
ISOAuto, 125-12800 (expands to 80-25600)
Boosted ISO (minimum)80
Boosted ISO (maximum)25600
White balance presets5
Custom white balanceYes (4 slots)
Image stabilizationOptical
Image stabilization notes5-axis
Uncompressed formatRAW
JPEG quality levelsFine, standard
File format
  • JPEG (DCF, Exif v2.3)
  • RAW (ARW)
Optics & Focus
Focal length (equiv.)25–400 mm
Optical zoom16×
Maximum apertureF2.8 - F4.0
Autofocus
  • Contrast Detect (sensor)
  • Multi-area
  • Center
  • Selective single-point
  • Tracking
  • Single
  • Continuous
  • Face Detection
  • Live View
Autofocus assist lampYes
Digital zoomYes (4x)
Manual focusYes
Normal focus range30 cm (11.81)
Macro focus range3 cm (1.18)
Number of focus points49
Screen / viewfinder
Articulated LCDFully articulated
Screen size3
Screen dots921,000
Touch screenNo
Screen typeTFT-LCD
Live viewYes
Viewfinder typeElectronic
Viewfinder coverage100%
Viewfinder magnification0.7×
Viewfinder resolution2,359,000
Photography features
Minimum shutter speed60 sec
Maximum shutter speed1/4000 sec
Maximum shutter speed (electronic)1/16000 sec
Exposure modes
  • Program
  • Shutter priority
  • Aperture priority
  • Manual
Scene modes
  • Clear Portrait, Silky Skin, Backlit Softness, Clear in Backlight, Relaxing Tone, Sweet Child's Face, Distinct Scenery, Bright Blue Sky, Romantic Sunset Glow, Vivid Sunset Glow, Glistening Water, Clear Nightscape, Cool Night Sky, Warm Glowing Nightscape, Artistic Nightscape, Glittering Illuminations, Handheld Night Shot, Clear Night Portrait, Soft Image of a Flower, Appetizing Food, Cute Dessert, Freeze Animal Motion, Clear Sports Shot, Monochrome, Panorama
Built-in flashYes
Flash range13.50 m (at Auto ISO)
External flashYes (via hotshoe)
Flash modesAuto, Auto/Red-eye Reduction, Forced On, Forced On/Red-eye Reduction, Slow Sync, Slow Sync/Red-eye Reduction, Forced Off
Drive modes
  • Single-shot
  • Continuous
  • AE bracket
  • Self-timer
  • Interval
Continuous drive12.0 fps
Self-timerYes
Metering modes
  • Multi
  • Center-weighted
  • Spot
Exposure compensation±5 (at 1/3 EV steps)
AE Bracketing±3 (3, 5, 7 frames at 1/3 EV, 1/2 EV, 1 EV steps)
WB BracketingNo
Videography features
Resolutions3840x2160 (30p), 1920 x 1080 (60p, 60i, 30p, 24p) 1280x720 (30p), 640 x 480 (30p)
FormatMPEG-4, AVCHD
Videography notes4K video uses MP4 (100Mbps), 1080p/720p use AVCHD (10-28Mbps)
MicrophoneStereo
SpeakerMono
Connectivity
USB USB 2.0 (480 Mbit/sec)
HDMIYes (microHDMI)
Microphone portYes
Headphone portNo
WirelessBuilt-In
Wireless notes802.11b/g/n with NFC
Remote controlYes (wired)
Physical
Environmentally sealedNo
BatteryBattery Pack
Battery descriptionDMW-BLC12PP lithium-ion battery and charger
Battery Life (CIPA)360
Weight (inc. batteries)831 g (1.83 lb / 29.31 oz)
Dimensions137 x 99 x 131 mm (5.39 x 3.9 x 5.16)
Other features
Orientation sensorYes
Timelapse recordingYes
GPSNone
